◆ UHD_RFNOC_BLOCK_CONSTRUCTOR
| #define UHD_RFNOC_BLOCK_CONSTRUCTOR |
CLASS_NAME | ) |
CLASS_NAME##_impl(const make_args_t& make_args) : block_ctrl_base(make_args) |
Shorthand for block constructor.
◆ UHD_RFNOC_BLOCK_OBJECT
| #define UHD_RFNOC_BLOCK_OBJECT |
class_name | ) |
typedef boost::shared_ptr<class_name> sptr; |
This macro must be put in the public section of an RFNoC.
◆ UHD_RFNOC_BLOCK_REGISTER
| #define UHD_RFNOC_BLOCK_REGISTER |
CLASS_NAME, |
BLOCK_NAME |
Value:block_ctrl_base::sptr CLASS_NAME##_make(const make_args_t& make_args) \
return block_ctrl_base::sptr(new CLASS_NAME##_impl(make_args)); \
UHD_STATIC_BLOCK(register_rfnoc_##CLASS_NAME) \
static void register_block(const make_t &make, const std::string &name)
This macro must be placed inside a block implementation file.
