Block controller for all RFNoC-based radio blocks. More...
#include <uhd/rfnoc/radio_ctrl.hpp>
| virtual | ~radio_ctrl () |
| virtual double | get_rate () const =0 |
| virtual double | set_rate (double rate)=0 |
| virtual std::string | get_tx_antenna (const size_t chan)=0 |
| virtual void | set_tx_antenna (const std::string &ant, const size_t chan)=0 |
| virtual std::string | get_rx_antenna (const size_t chan)=0 |
| virtual void | set_rx_antenna (const std::string &ant, const size_t chan)=0 |
| virtual double | get_tx_frequency (const size_t chan)=0 |
| virtual double | set_tx_frequency (const double freq, size_t chan)=0 |
| virtual double | get_rx_frequency (const size_t chan)=0 |
| virtual double | set_rx_frequency (const double freq, const size_t chan)=0 |
| virtual double | get_tx_gain (const size_t chan)=0 |
| virtual double | set_tx_gain (const double gain, const size_t chan)=0 |
| virtual double | get_rx_gain (const size_t chan)=0 |
| virtual double | set_rx_gain (const double gain, const size_t chan)=0 |
| virtual double | get_tx_bandwidth (const size_t chan)=0 |
| virtual double | set_tx_bandwidth (const double bandwidth, const size_t chan)=0 |
| virtual double | get_rx_bandwidth (const size_t chan)=0 |
| virtual double | set_rx_bandwidth (const double bandwidth, const size_t chan)=0 |
| virtual void | set_time_now (const time_spec_t &time_spec)=0 |
| virtual void | set_time_next_pps (const time_spec_t &time_spec)=0 |
| virtual time_spec_t | get_time_now ()=0 |
| virtual time_spec_t | get_time_last_pps ()=0 |
| virtual std::vector< std::string > | get_gpio_banks () const =0 |
| virtual void | set_gpio_attr (const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask)=0 |
| virtual uint32_t | get_gpio_attr (const std::string &bank, const std::string &attr)=0 |
| virtual std::vector< std::string > | get_rx_lo_names (const size_t chan)=0 |
| virtual std::vector< std::string > | get_rx_lo_sources (const std::string &name, const size_t chan)=0 |
| virtual freq_range_t | get_rx_lo_freq_range (const std::string &name, const size_t chan)=0 |
| virtual void | set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0 |
| virtual const std::string | get_rx_lo_source (const std::string &name, const size_t chan)=0 |
| virtual void | set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0 |
| virtual bool | get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0 |
| virtual double | set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0 |
| virtual double | get_rx_lo_freq (const std::string &name, const size_t chan)=0 |
| virtual std::vector< std::string > | get_tx_lo_names (const size_t chan)=0 |
| virtual std::vector< std::string > | get_tx_lo_sources (const std::string &name, const size_t chan)=0 |
| virtual freq_range_t | get_tx_lo_freq_range (const std::string &name, const size_t chan)=0 |
| virtual void | set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0 |
| virtual const std::string | get_tx_lo_source (const std::string &name, const size_t chan)=0 |
| virtual void | set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0 |
| virtual bool | get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0 |
| virtual double | set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0 |
| virtual double | get_tx_lo_freq (const std::string &name, const size_t chan)=0 |
| virtual void | set_time_source (const std::string &source)=0 |
| virtual std::string | get_time_source ()=0 |
| virtual std::vector< std::string > | get_time_sources ()=0 |
| virtual void | set_clock_source (const std::string &source)=0 |
| virtual std::string | get_clock_source ()=0 |
| virtual std::vector< std::string > | get_clock_sources ()=0 |
| virtual size_t | get_chan_from_dboard_fe (const std::string &fe, const uhd::direction_t dir)=0 |
| virtual std::string | get_dboard_fe_from_chan (const size_t chan, const uhd::direction_t dir)=0 |
| virtual void | enable_rx_timestamps (const bool enable, const size_t chan)=0 |
Public Member Functions inherited from uhd::rfnoc::source_block_ctrl_base | |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t chan=0) |
| stream_sig_t | get_output_signature (size_t block_port=0) const |
| std::vector< size_t > | get_output_ports () const |
| virtual void | set_destination (uint32_t next_address, size_t output_block_port=0) |
| virtual void | configure_flow_control_out (const bool enable_output, const bool lossless_link, const size_t buf_size_bytes, const size_t pkt_limit=0, const size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t()) |
| size_t | get_mtu (size_t block_port=0) const |
Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| uint32_t | get_address (size_t block_port=0) |
| block_id_t | get_block_id () const |
| std::string | unique_id () const |
| std::vector< size_t > | get_ctrl_ports () const |
| void | sr_write (const uint32_t reg, const uint32_t data, const size_t port=0) |
| void | sr_write (const std::string ®, const uint32_t data, const size_t port=0) |
| uint64_t | sr_read64 (const settingsbus_reg_t reg, const size_t port=0) |
| uint32_t | sr_read32 (const settingsbus_reg_t reg, const size_t port=0) |
| uint64_t | user_reg_read64 (const uint32_t addr, const size_t port=0) |
| uint64_t | user_reg_read64 (const std::string ®, const size_t port=0) |
| uint32_t | user_reg_read32 (const uint32_t addr, const size_t port=0) |
| uint32_t | user_reg_read32 (const std::string ®, const size_t port=0) |
| void | set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| time_spec_t | get_command_time (const size_t port=0) |
| void | set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT) |
| void | clear_command_time (const size_t port) |
| void | clear () |
| void | set_args (const uhd::device_addr_t &args, const size_t port=0) |
| void | set_arg (const std::string &key, const std::string &val, const size_t port=0) |
Set a specific block argument. val is converted to the corresponding. More... | |
| template<typename T > | |
| void | set_arg (const std::string &key, const T &val, const size_t port=0) |
| Direct access to set a block argument. More... | |
| uhd::device_addr_t | get_args (const size_t port=0) const |
| Return all block arguments as a device_addr_t. More... | |
| std::string | get_arg (const std::string &key, const size_t port=0) const |
| Return a single block argument in string format. More... | |
| T | get_arg (const std::string &key, const size_t port=0) const |
| Direct access to get a block argument. More... | |
| std::string | get_arg_type (const std::string &key, const size_t port=0) const |
Public Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | disconnect () |
| void | disconnect_output_port (const size_t output_port) |
| void | disconnect_input_port (const size_t input_port) |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node (bool active_only=false) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node (bool active_only=false) |
| template<typename T , typename value_type > | |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
Public Member Functions inherited from uhd::rfnoc::source_node_ctrl | |
| size_t | connect_downstream (node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_rx_streamer (bool active, const size_t port) |
Public Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base | |
| stream_sig_t | get_input_signature (size_t block_port=0) const |
| std::vector< size_t > | get_input_ports () const |
| size_t | get_fifo_size (size_t block_port=0) const |
| virtual void | configure_flow_control_in (const size_t bytes, const size_t block_port=0) |
| virtual void | set_error_policy (const std::string &policy) |
Public Member Functions inherited from uhd::rfnoc::sink_node_ctrl | |
| size_t | connect_upstream (node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_tx_streamer (bool active, const size_t port) |
Public Member Functions inherited from uhd::rfnoc::rate_node_ctrl | |
| virtual double | get_input_samp_rate (size_t port=ANY_PORT) |
| virtual double | get_output_samp_rate (size_t port=ANY_PORT) |
Public Member Functions inherited from uhd::rfnoc::tick_node_ctrl | |
| double | get_tick_rate (const std::set< node_ctrl_base::sptr > &_explored_nodes=std::set< node_ctrl_base::sptr >()) |
| static const size_t | ALL_CHANS = size_t(~0) |
| A wildcard channel index. More... | |
| static const std::string | ALL_GAINS |
| A wildcard gain element name. More... | |
| static const std::string | ALL_LOS |
| A wildcard local oscillator element name. More... | |
Static Public Attributes inherited from uhd::rfnoc::rate_node_ctrl | |
| static const double | RATE_UNDEFINED |
| This value is used by rate nodes that don't actually set a rate themselves. More... | |
Static Public Attributes inherited from uhd::rfnoc::tick_node_ctrl | |
Public Types inherited from uhd::rfnoc::source_block_ctrl_base | |
| typedef boost::shared_ptr< source_block_ctrl_base > | sptr |
Public Types inherited from uhd::rfnoc::block_ctrl_base | |
| typedef boost::shared_ptr< block_ctrl_base > | sptr |
| typedef boost::function< sptr(const make_args_t &)> | make_t |
Public Types inherited from uhd::rfnoc::node_ctrl_base | |
| typedef boost::shared_ptr< node_ctrl_base > | sptr |
| typedef boost::weak_ptr< node_ctrl_base > | wptr |
| typedef std::map< size_t, wptr > | node_map_t |
| typedef std::pair< size_t, wptr > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::source_node_ctrl | |
| typedef boost::shared_ptr< source_node_ctrl > | sptr |
| typedef std::map< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_t |
| typedef std::pair< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::sink_block_ctrl_base | |
| typedef boost::shared_ptr< sink_block_ctrl_base > | sptr |
Public Types inherited from uhd::rfnoc::sink_node_ctrl | |
| typedef boost::shared_ptr< sink_node_ctrl > | sptr |
| typedef std::map< size_t, boost::weak_ptr< sink_node_ctrl > > | node_map_t |
| typedef std::pair< size_t, boost::weak_ptr< sink_node_ctrl > > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::rate_node_ctrl | |
| typedef boost::shared_ptr< rate_node_ctrl > | sptr |
Public Types inherited from uhd::rfnoc::tick_node_ctrl | |
| typedef boost::shared_ptr< tick_node_ctrl > | sptr |
Public Types inherited from uhd::rfnoc::terminator_node_ctrl | |
| typedef boost::shared_ptr< terminator_node_ctrl > | sptr |
Static Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| static void | register_block (const make_t &make, const std::string &name) |
| static sptr | make (const make_args_t &make_args, uint64_t noc_id=~0) |
| Create a block controller class given a NoC-ID or a block name. More... | |
Protected Member Functions inherited from uhd::rfnoc::source_block_ctrl_base | |
| virtual size_t | _request_output_port (const size_t suggested_port, const uhd::device_addr_t &args) const |
Protected Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| block_ctrl_base (void) | |
| virtual | ~block_ctrl_base () |
| block_ctrl_base (const make_args_t &make_args) | |
| stream_sig_t | _resolve_port_def (const blockdef::port_t &port_def) const |
| uhd::fs_path | get_arg_path (const std::string &key, size_t port=0) const |
Return the property tree path to a block argument key on port. More... | |
| timed_wb_iface::sptr | get_ctrl_iface (const size_t block_port) |
Get a control interface object for block port block_port. More... | |
| virtual void | _clear (const size_t port=0) |
| Override this function if your block does something else. More... | |
| virtual void | _set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| Override this function if your block needs to specially handle. More... | |
Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_ctrl_base (void) | |
| virtual | ~node_ctrl_base () |
Protected Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base | |
| virtual size_t | _request_input_port (const size_t suggested_port, const uhd::device_addr_t &args) const |
Protected Member Functions inherited from uhd::rfnoc::tick_node_ctrl | |
| virtual double | _get_tick_rate () |
Protected Attributes inherited from uhd::rfnoc::block_ctrl_base | |
| uhd::property_tree::sptr | _tree |
| Property sub-tree. More... | |
| uhd::fs_path | _root_path |
| Root node of this block's properties. More... | |
| blockdef::sptr | _block_def |
| Block definition (stores info about the block such as ports) More... | |
Protected Attributes inherited from uhd::rfnoc::node_ctrl_base | |
| uhd::device_addr_t | _args |
| Stores default arguments. More... | |
| node_map_t | _upstream_nodes |
| List of upstream nodes. More... | |
| node_map_t | _downstream_nodes |
| List of downstream nodes. More... | |
| size_t | _num_input_ports |
| size_t | _num_output_ports |
| std::map< size_t, bool > | _rx_streamer_active |
| std::map< size_t, bool > | _tx_streamer_active |
inlinevirtual |
Enable or disable the setting of timestamps on Rx.
Given a frontend name, return the channel mapping.
E.g.: For a TwinRX board, there's two frontends, '0' and '1', which map to channels 0 and 1 respectively. A BasicRX boards has alphabetical frontends (A, B) which map to channels differently.
Get the currently set clock source.
Get a list of possible clock sources.
The inverse function to get_chan_from_dboard_fe()
Get a GPIO attribute on a particular GPIO bank. Possible attribute names:
| bank | the name of a GPIO bank |
| attr | the name of a GPIO attribute |
Returns the list of GPIO banks that are associated with this radio.
Return the tick rate on all channels (rx and tx).
Return the selected RX antenna for channel chan.
Return the analog filter bandwidth channel chan
Return the current receive LO frequency on channel chan.
Return the transmit gain on channel chan
Returns true if the currently selected LO is being exported.
| name | the name of the LO stage to query |
| chan | the channel index 0 to N-1 |
Get the current RX LO frequency (Advanced). If the channel does not have independently configurable LOs the current rf frequency will be returned.
Get the LO frequency range of the RX LO. If the channel does not have independently configurable LOs the rf frequency range will be returned.
Get a list of possible LO stage names
Get the currently set LO source. Channels without controllable LO sources will return "internal"
Get a list of possible LO sources.
Channels which do not have controllable LO sources will return "internal".
Get the time when the last PPS pulse occurred.
Get the current time in the timekeeper registers.
Note that there is a non-deterministic delay between the time the register is read and the time the function value is returned. To get the time with respect to a tick edge, use get_time_last_pps().
Get the currently set time source.
Get a list of possible time sources.
Return the selected TX antenna for channel chan.
Return the current transmit LO frequency on channel chan.
Note that the AD9361 only has one LO for all TX channels, and the chan parameter is thus only for API compatibility.
Get the current TX LO frequency (Advanced).
See also multi_usrp::get_tx_lo_freq()
If the channel does not have independently configurable LOs the current RF frequency will be returned.
Get the LO frequency range of the tx LO. If the channel does not have independently configurable LOs the rf frequency range will be returned.
Set the clock source for the usrp device (for reference clock).
Typical options for source: internal, external.
| source | a string representing the clock source |
Set a GPIO attribute on a particular GPIO bank. Possible attribute names:
| bank | the name of a GPIO bank (e.g., FP0) |
| attr | the name of a GPIO attribute (e.g., CTRL) |
| value | the new value for this GPIO bank |
| mask | the bit mask to effect which pins are changed |
Set the tick/sample rate on all channels (rx and tx).
Will coerce to the nearest possible rate and return the actual value.
Select RX antenna for channel chan.
| uhd::value_error | if ant is not a valid value. |
Set the analog filter bandwidth channel chan
This function will attempt to set the analog bandwidth.
Tune the RX LO for channel chan.
This function will attempt to tune as close as possible, and return a coerced value of the actual tuning result.
| freq | Requested LO frequency |
| chan | Channel number. |
Set the transmit gain on channel chan
This function will attempt to set the gain as close as possible, and return a coerced value of the actual gain value.
Set whether the LO used by the usrp device is exported For usrps that support exportable LOs, this function configures if the LO used by chan is exported or not.
| enabled | if true then export the LO |
| name | the name of the LO stage to update |
| chan | the channel index 0 to N-1 for the source channel |
Set the RX LO frequency (Advanced).
| freq | the frequency to set the LO to |
Set the LO source for a channel. For usrps that support selectable LOs, this function allows switching between them. Typical options for source: internal, external.
| src | a string representing the LO source |
Set the time registers at the next pps tick.
The values will not be latched in until the pulse occurs. It is recommended that the user sleep(1) after calling to ensure that the time registers will be in a known state prior to use.
Note: Because this call sets the time on the "next" pps, the seconds in the time spec should be current seconds + 1.
| time_spec | the time to latch into the timekeeper |
Sets the time in the radio's timekeeper to the given value.
Note that there is a non-deterministic delay between calling this function and the valung written to the register. For setting the time in alignment with a certain reference time, use set_time_next_pps().
Set the time source for this radio.
May affect other radio blocks.
| source | A string representing the time source |
| uhd::value_error | if the value can't be applied |
Tune the TX LO for channel chan.
| freq | Frequency in Hz |
| chan | Channel to tune |
Set the tx LO frequency (Advanced).
See also multi_usrp::set_tx_lo_freq().
