uhd::device3 Class Referenceabstract
Extends uhd::device for third-generation USRP devices. More...
#include <uhd/device3.hpp>
Inheritance diagram for uhd::device3:
uhd::device
typedef boost::shared_ptr< device3 > sptr
- Public Types inherited from uhd::device
enum  device_filter_t { ANY, USRP, CLOCK }
 Device type, used as a filter in make. More...
typedef boost::shared_ptr< device > sptr
typedef boost::function< device_addrs_t(const device_addr_t &)> find_t
typedef boost::function< sptr(const device_addr_t &)> make_t
virtual rfnoc::graph::sptr create_graph (const std::string &name="")=0
void clear ()
bool has_block (const rfnoc::block_id_t &block_id) const
 Checks if an RFNoC block exists on the device. More...
template<typename T >
rfnoc::block_ctrl_base::sptr get_block_ctrl (const rfnoc::block_id_t &block_id) const
 Returns a block controller class for an RFNoC block. More...
boost::shared_ptr< T > get_block_ctrl (const rfnoc::block_id_t &block_id) const
std::vector< rfnoc::block_id_t > find_blocks (const std::string &block_id_hint) const
- Public Member Functions inherited from uhd::device
virtual ~device (void)=0
 Make a new receive streamer from the streamer arguments. More...
 Make a new transmit streamer from the streamer arguments. More...
uhd::property_tree::sptr get_tree (void) const
 Get access to the underlying property structure. More...
device_filter_t get_device_type () const
 Get device type. More...
static sptr make (const device_addr_t &hint, const size_t which=0)
 Same as uhd::device::make(), but will fail if not actually a device3. More...
- Static Public Member Functions inherited from uhd::device
static void register_device (const find_t &find, const make_t &make, const device_filter_t filter)
static device_addrs_t find (const device_addr_t &hint, device_filter_t filter=ANY)
 Find devices attached to the host. More...
static sptr make (const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0)
 Create a new device from the device address hint. More...
Protected Attributes
std::vector< rfnoc::block_ctrl_base::sptr > _rfnoc_block_ctrl
 List of all RFNoC blocks available on this device. More...
boost::mutex _block_ctrl_mutex
 Mutex to protect access to members. More...
- Protected Attributes inherited from uhd::device
uhd::property_tree::sptr _tree
device_filter_t _type
Generation-3 devices are characterized by the following traits:
  • They support RFNoC (RF Network-on-Chip).
  • Data transport uses the compressed VITA (CVITA/CHDR) data format.
typedef boost::shared_ptr<device3> uhd::device3::sptr
◆ clear()
void uhd::device3::clear ( )
Reset blocks after a stream.
TODO write docs
◆ create_graph()
virtual rfnoc::graph::sptr uhd::device3::create_graph ( const std::string &  name = "")
◆ find_blocks() [1/2]
std::vector<rfnoc::block_id_t> uhd::device3::find_blocks ( const std::string &  block_id_hint) const
Returns the block ids of all blocks that match the specified hint Uses block_ctrl_base::match() internally.
If no matching block is found, it returns an empty vector.
To return a list of all blocks, pass in an empty string as a hint.
To access specialized block controller classes (i.e. derived from block_ctrl_base), use the templated version of this function, e.g.
// Assume DEV is a device3::sptr
null_block_ctrl::sptr null_block =
DEV->find_blocks<null_block_ctrl>("NullSrcSink");
Note
this access is not thread safe if peformed during block enumeration
block_id_hintEither an empty string (will return all blocks), or block ID hint (e.g. "FFT"). This hint will be matched against the block IDs against all the blocks in this device using uhd::block_id_t::match().
a list of all block IDs that match the hint
◆ find_blocks() [2/2]
Type-cast version of find_blocks().
◆ get_block_ctrl() [1/2]
rfnoc::block_ctrl_base::sptr uhd::device3::get_block_ctrl ( const rfnoc::block_id_t &  block_id) const
If the given block ID is not valid (i.e. such a block does not exist on this device), it will throw a uhd::lookup_error.
block_idCanonical block name (e.g. "0/FFT_1").
Note
◆ get_block_ctrl() [2/2]
boost::shared_ptr<T> uhd::device3::get_block_ctrl ( const rfnoc::block_id_t &  block_id) const
Same as get_block_ctrl(), but with a type cast.
If you have a block controller class that is derived from block_ctrl_base, use this function to access its specific methods. If the given block ID is not valid (i.e. such a block does not exist on this device) or if the type does not match, it will throw a uhd::lookup_error.
uhd::rfnoc::my_block_ctrl::sptr block_controller =
get_block_ctrl<my_block_ctrl>("0/MyBlock_0");
block_controller->my_own_block_method();
Note
◆ has_block() [1/2]
bool uhd::device3::has_block ( const rfnoc::block_id_t &  block_id) const
true if a block with the specified id exists
Note
◆ has_block() [2/2]
Same as has_block(), but with a type check.
true if a block of type T with the specified id exists
Note
◆ make()
static sptr uhd::device3::make ( const device_addr_t &  hint,
const size_t  which = 0
◆ _block_ctrl_mutex
boost::mutex uhd::device3::_block_ctrl_mutex
◆ _rfnoc_block_ctrl
std::vector<rfnoc::block_ctrl_base::sptr> uhd::device3::_rfnoc_block_ctrl
