uhd::transport::muxed_zero_copy_if Class Referenceabstract
#include <uhd/transport/muxed_zero_copy_if.hpp>
Inheritance diagram for uhd::transport::muxed_zero_copy_if:
typedef std::shared_ptr< muxed_zero_copy_ifsptr
typedef std::function< uint32_t(void *buff, size_t size)> stream_classifier_fn
virtual ~muxed_zero_copy_if ()
 virtual dtor More...
virtual zero_copy_if::sptr make_stream (const uint32_t stream_num)=0
 Make a virtual transport for the specified stream number. More...
virtual void remove_stream (const uint32_t stream_num)=0
 Unregister the stream number. All packets destined to the stream will be dropped. More...
virtual size_t get_num_dropped_frames () const =0
 Get number of frames dropped due to unregistered streams. More...
static sptr make (zero_copy_if::sptr base_xport, stream_classifier_fn classify_fn, size_t max_streams)
 Make a new demuxer from a transport and parameters. More...
Implements a software muxed-demuxed zero-copy transport This is a wrapper around a base transport that allows creation of virtual zero_copy_if streams that are indistinguishable from physical transport streams. This class handles demuxing receive streams into the appropriate virtual streams with the given classifier function. A worker therad is spawned to handle the demuxing.
◆ stream_classifier_fn
typedef std::function<uint32_t(void* buff, size_t size)> uhd::transport::muxed_zero_copy_if::stream_classifier_fn
Function to classify the stream based on the payload. The classifier must return a stream number, an arbitrary identifier for a virtual stream that is consistent with the stream number used in the make_stream and remove_stream fuctions
buffa pointer to the payload of the frame
sizenumber of bytes in the frame payload
stream number
◆ ~muxed_zero_copy_if()
virtual uhd::transport::muxed_zero_copy_if::~muxed_zero_copy_if ( )
virtual dtor
◆ get_num_dropped_frames()
virtual size_t uhd::transport::muxed_zero_copy_if::get_num_dropped_frames ( ) const
◆ make()
static sptr uhd::transport::muxed_zero_copy_if::make ( zero_copy_if::sptr  base_xport,
size_t  max_streams
◆ make_stream()
virtual zero_copy_if::sptr uhd::transport::muxed_zero_copy_if::make_stream ( const uint32_t  stream_num)
◆ remove_stream()
virtual void uhd::transport::muxed_zero_copy_if::remove_stream ( const uint32_t  stream_num)
