uhd::transport Namespace Reference
Namespaces
namespace  vrt
Classes
class  bounded_buffer
class  bounded_buffer_detail
class  buffer_pool
class  frame_buff
struct  if_addrs_t
class  managed_buffer
class  managed_recv_buffer
class  managed_send_buffer
class  muxed_zero_copy_if
struct  tcp_zero_copy
class  udp_simple
class  udp_zero_copy
class  usb_control
class  usb_device_handle
class  usb_zero_copy
class  zero_copy_flow_ctrl
class  zero_copy_if
struct  zero_copy_xport_params
Typedefs
using adapter_id_t = size_t
 Host transport adapter ID. More...
typedef std::function< bool(managed_buffer::sptr buff)> flow_ctrl_func
Functions
UHD_API std::vector< if_addrs_tget_if_addrs (void)
UHD_INLINE void intrusive_ptr_add_ref (managed_buffer *p)
UHD_INLINE void intrusive_ptr_release (managed_buffer *p)
Typedef Documentation
◆ adapter_id_t
using uhd::transport::adapter_id_t = typedef size_t
◆ flow_ctrl_func
typedef std::function<bool(managed_buffer::sptr buff)> uhd::transport::flow_ctrl_func
Flow control function.
buffbuffer to be sent or receive buffer being released
true if OK, false if not
Function Documentation
◆ get_if_addrs()
UHD_API std::vector< if_addrs_t > uhd::transport::get_if_addrs ( void  )
Get a list of network interface addresses. The internal implementation is system-dependent.
a vector of if addrs
◆ intrusive_ptr_add_ref()
UHD_INLINE void uhd::transport::intrusive_ptr_add_ref ( managed_buffer p)
◆ intrusive_ptr_release()
UHD_INLINE void uhd::transport::intrusive_ptr_release ( managed_buffer p)
