12namespace uhd {
namespace rfnoc {
   47    static const uint16_t MINOR_COMPAT;
   48    static const uint16_t MAJOR_COMPAT;
   50    static const uint32_t REPLAY_ADDR_W;
   51    static const uint32_t REPLAY_BLOCK_OFFSET;
   53    static const uint32_t REG_COMPAT_ADDR;
   54    static const uint32_t REG_MEM_SIZE_ADDR;
   55    static const uint32_t REG_REC_RESTART_ADDR;
   56    static const uint32_t REG_REC_BASE_ADDR_LO_ADDR;
   57    static const uint32_t REG_REC_BASE_ADDR_HI_ADDR;
   58    static const uint32_t REG_REC_BUFFER_SIZE_LO_ADDR;
   59    static const uint32_t REG_REC_BUFFER_SIZE_HI_ADDR;
   60    static const uint32_t REG_REC_FULLNESS_LO_ADDR;
   61    static const uint32_t REG_REC_FULLNESS_HI_ADDR;
   62    static const uint32_t REG_PLAY_BASE_ADDR_LO_ADDR;
   63    static const uint32_t REG_PLAY_BASE_ADDR_HI_ADDR;
   64    static const uint32_t REG_PLAY_BUFFER_SIZE_LO_ADDR;
   65    static const uint32_t REG_PLAY_BUFFER_SIZE_HI_ADDR;
   66    static const uint32_t REG_PLAY_CMD_NUM_WORDS_LO_ADDR;
   67    static const uint32_t REG_PLAY_CMD_NUM_WORDS_HI_ADDR;
   68    static const uint32_t REG_PLAY_CMD_TIME_LO_ADDR;
   69    static const uint32_t REG_PLAY_CMD_TIME_HI_ADDR;
   70    static const uint32_t REG_PLAY_CMD_ADDR;
   71    static const uint32_t REG_PLAY_WORDS_PER_PKT_ADDR;
   72    static const uint32_t REG_PLAY_ITEM_SIZE_ADDR;
   74    static const uint32_t PLAY_CMD_STOP;
   75    static const uint32_t PLAY_CMD_FINITE;
   76    static const uint32_t PLAY_CMD_CONTINUOUS;
   97        const uint64_t offset, const uint64_t size, const
size_t port = 0) = 0;
  103    virtual
void record_restart(const
  127    virtual
void play(const uint64_t offset,
  129        const
size_t port                = 0,
  131        const
bool repeat                = false) = 0;
  140    virtual
void stop(const
  149    virtual uint64_t get_mem_size() const = 0;
  155    virtual uint64_t get_word_size() const = 0;
  165    virtual uint64_t get_record_offset(const
size_t port = 0) const = 0;
  172    virtual uint64_t get_record_size(const
  182    virtual uint64_t get_record_fullness(const
  189    virtual
io_type_t get_record_type(const
  196    virtual
size_t get_record_item_size(const
  206    virtual uint64_t get_play_offset(const
  213    virtual uint64_t get_play_size(const
  220    virtual uint32_t get_max_items_per_packet(const
  229    virtual uint32_t get_max_packet_size(const
  236    virtual
io_type_t get_play_type(const
  243    virtual
size_t get_play_item_size(const
  255    virtual
void set_record_type(const
io_type_t type, const
  273    virtual
void config_play(
  274        const uint64_t offset, const uint64_t size, const
  283    virtual
void set_play_type(const
  294    virtual
void set_max_items_per_packet(const uint32_t ipp, const
  303    virtual
void set_max_packet_size(const uint32_t size, const
  320    virtual
void issue_stream_cmd(
Definition: noc_block_base.hpp:42
Definition: replay_block_control.hpp:43
Definition: time_spec.hpp:31
Definition: config.h:67
std::string io_type_t
Definition: defaults.hpp:32
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
Definition: stream_cmd.hpp:36
