#include <uhd/rfnoc/replay_block_control.hpp>
| virtual void | record (const uint64_t offset, const uint64_t size, const size_t port=0)=0 |
| virtual void | record_restart (const size_t port=0)=0 |
| virtual void | play (const uint64_t offset, const uint64_t size, const size_t port=0, const uhd::time_spec_t time_spec=uhd::time_spec_t(0.0), const bool repeat=false)=0 |
| virtual void | stop (const size_t port=0)=0 |
| virtual uint64_t | get_mem_size () const =0 |
| virtual uint64_t | get_word_size () const =0 |
| virtual uint64_t | get_record_offset (const size_t port=0) const =0 |
| virtual uint64_t | get_record_size (const size_t port=0) const =0 |
| virtual uint64_t | get_record_fullness (const size_t port=0)=0 |
| virtual io_type_t | get_record_type (const size_t port=0) const =0 |
| virtual size_t | get_record_item_size (const size_t port=0) const =0 |
| virtual uint64_t | get_play_offset (const size_t port=0) const =0 |
| virtual uint64_t | get_play_size (const size_t port=0) const =0 |
| virtual uint32_t | get_max_items_per_packet (const size_t port=0) const =0 |
| virtual uint32_t | get_max_packet_size (const size_t port=0) const =0 |
| virtual io_type_t | get_play_type (const size_t port=0) const =0 |
| virtual size_t | get_play_item_size (const size_t port=0) const =0 |
| virtual void | set_record_type (const io_type_t type, const size_t port=0)=0 |
| virtual void | config_play (const uint64_t offset, const uint64_t size, const size_t port=0)=0 |
| virtual void | set_play_type (const io_type_t type, const size_t port=0)=0 |
| virtual void | set_max_items_per_packet (const uint32_t ipp, const size_t port=0)=0 |
| virtual void | set_max_packet_size (const uint32_t size, const size_t port=0)=0 |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port=0)=0 |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
| static const uint16_t | MINOR_COMPAT |
| static const uint16_t | MAJOR_COMPAT |
| static const uint32_t | REPLAY_ADDR_W |
| static const uint32_t | REPLAY_BLOCK_OFFSET |
| static const uint32_t | REG_COMPAT_ADDR |
| static const uint32_t | REG_MEM_SIZE_ADDR |
| static const uint32_t | REG_REC_RESTART_ADDR |
| static const uint32_t | REG_REC_BASE_ADDR_LO_ADDR |
| static const uint32_t | REG_REC_BASE_ADDR_HI_ADDR |
| static const uint32_t | REG_REC_BUFFER_SIZE_LO_ADDR |
| static const uint32_t | REG_REC_BUFFER_SIZE_HI_ADDR |
| static const uint32_t | REG_REC_FULLNESS_LO_ADDR |
| static const uint32_t | REG_REC_FULLNESS_HI_ADDR |
| static const uint32_t | REG_PLAY_BASE_ADDR_LO_ADDR |
| static const uint32_t | REG_PLAY_BASE_ADDR_HI_ADDR |
| static const uint32_t | REG_PLAY_BUFFER_SIZE_LO_ADDR |
| static const uint32_t | REG_PLAY_BUFFER_SIZE_HI_ADDR |
| static const uint32_t | REG_PLAY_CMD_NUM_WORDS_LO_ADDR |
| static const uint32_t | REG_PLAY_CMD_NUM_WORDS_HI_ADDR |
| static const uint32_t | REG_PLAY_CMD_TIME_LO_ADDR |
| static const uint32_t | REG_PLAY_CMD_TIME_HI_ADDR |
| static const uint32_t | REG_PLAY_CMD_ADDR |
| static const uint32_t | REG_PLAY_WORDS_PER_PKT_ADDR |
| static const uint32_t | REG_PLAY_ITEM_SIZE_ADDR |
| static const uint32_t | PLAY_CMD_STOP |
| static const uint32_t | PLAY_CMD_FINITE |
| static const uint32_t | PLAY_CMD_CONTINUOUS |
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
Replay Block Control CLass
The Replay block records data to memory and plays back data from memory.
It is the responsibility of the user to manage the memory. Care must be taken to avoid unintentional overlaps in the memory across blocks and ports. Each port of the Replay block has access to the full memory space. This allows recording data on any input port of any Replay block and playback on any output port of any Replay block. The section of memory used by a record or play operation is controlled by setting the offset and size.
For both record and playback, the offset and the size must be aligned to the memory's word size. For playback, the size must also be aligned to the size of an item. An item is a single unit of data as defined by the data type of a port. For record, the data type is automatically determined by the connection to the upstream block by using the "type" edge property for the corresponding input port. For playback, this is automatically determined by the connection to the downstream block by using the "type" edge property for the corresponding output port. These can be explicitly set by the user, if necessary. It is the user's responsibility to manage the types of the individual record and the playback ports. Methods to get the word size and item sizes are provided to help calculate proper alignment.
One key configuration of playback is the packet size. Larger packet sizes provide for better throughput while smaller packet sizes provide for lower latency. By default, the "mtu" edge property of the output port is used to define the maximum packet size to achieve the best throughput to the downstream block without exceeding the supported packet size. The maximum packet size can be explicitly set in terms of bytes or number of items to allow users to tune the performance to suit their application.
Configure the offsets and size of the playback buffer region
Specifies a buffer area in the memory for playback. In order to begin playback on this region, a stream command must be issued.
| offset | Memory offset of the data to be played. This value must be aligned to the size of the word in memory. Use get_word_size() to get the memory word size. |
| size | Size of data to play back. This value must be aligned to the size of the memory word and item size. Use get_word_size() to get the memory word size and get_output_item_size() to get the item size. |
| port | Which output port of the replay block to use |
Get the maximum number of items in a packet
Get the maximum size of a packet
Returns the maximum size of a packet, inclusive of headers and payload.
Get the size of the memory
Returns the size of the shared memory space. Any record or playback buffers must be configured in this memory space.
Get the current play item size
Get the offset of the current playback buffer
Get the current size of the playback space
Get the current play data type
Get the fullness of the current record buffer
Returns the number of bytes that have been recorded in the record buffer. A record restart will reset this number back to 0.
| port | Which input port of the replay block to use |
Get the current record item size
Get the starting offset of the current record buffer
Get the current size of the record space
Get the current record data type
Get the size of a memory word
Issue a stream command to the replay block
Issue stream commands to start or stop playback from the configured playback buffer. Supports STREAM_MODE_START_CONTINUOUS to start continuous repeating playback, STREAM_MODE_START_NUM_SAMPS_AND_DONE to play the given number of samples once, and STREAM_MODE_STOP_CONTINUOUS to stop all playback immediately. If a time_spec is supplied, it is placed in the header of the first packet produced for that command. Commands are queued and executed in order. A STREAM_MODE_STOP_CONTINUOUS command will halt all playback and purge all commands in the queue for a given output port.
| stream_cmd | The command to execute |
Play
Play back data. The offset and size define what data is played back on an output port. The data can be played once or repeated continuously until a stop command is issued. If a time_spec is supplied, it will be placed in the header of the first packet. Typically, this is used to tell a downstream Radio block when to start transmitting the data. If the data type on the output port is not defined, this function will throw an error.
| time_spec | Set the time for the first item. Any non-zero value is used to set the time in the header of the first packet. Most commonly, this is used to set the start time of a transmission. |
| repeat | Determines whether the data should be played repeatedly or just once. If set to true, stop() must be called to stop the play back. |
Record
Begin recording. The offset sets the starting location in memory and the size limits the length of the recording. The flow of data is controlled by upstream RFNoC blocks.
| offset | Memory offset where to start recording the data. This value must be aligned to the memory word size. Use get_word_size() to get the size of the memory word. |
| size | Size limit, in bytes. This value must be aligned to the memory word size and the item size. Use get_word_size() to get the size of the memory word and get_item_size() to get the item size. A value of 0 means to use all available space. |
Restarts recording from the record offset
Set the maximum number of items in a packet
Sets the maximum number of items that can be in a packet's payload. An actual packet may be smaller in order to coerce to mtu values, or to align with memory word size.
| ipp | Number of items per packet |
Set the maximum size of a packet
Sets the maximum packet size, inclusive of headers and payload.
| size | The size of the packet |
Explicitly set the current play data type
Sets the data type for items in the current play buffer for the given output port.
| type | The data type |
Explicitly set the current record data type
Sets the data type for items in the current record buffer for the given input port.
Stops playback
Halts any currently executing play commands and cancels any other play commands that are waiting to be executed for that output port.
