uhd::rfnoc::mock_block_container Struct Reference
#include <uhd/rfnoc/mock_block.hpp>
template<typename block_type = noc_block_base>
std::shared_ptr< block_type > get_block ()
 Use this to retrieve a reference to the block controller. Make sure that. More...
Public Attributes
std::shared_ptr< mock_reg_iface_treg_iface
 Reference to the register interface object. More...
uhd::property_tree::sptr tree
 Reference to the prop tree object the block sees. More...
std::function< noc_block_base::sptr(noc_block_base::make_args_ptr)> factory
 Factory to get the block. Use get_block() instead. More...
noc_block_base::make_args_ptr make_args
Friends
class get_mock_block
Container for all the items required for running a mock block
◆ get_block()
std::shared_ptr< block_type > uhd::rfnoc::mock_block_container::get_block ( )
Friends And Related Function Documentation
◆ get_mock_block
friend class get_mock_block
friend
◆ factory
std::function<noc_block_base::sptr(noc_block_base::make_args_ptr)> uhd::rfnoc::mock_block_container::factory
◆ make_args
noc_block_base::make_args_ptr uhd::rfnoc::mock_block_container::make_args
◆ reg_iface
std::shared_ptr<mock_reg_iface_t> uhd::rfnoc::mock_block_container::reg_iface
◆ tree
uhd::property_tree::sptr uhd::rfnoc::mock_block_container::tree
