multi_usrp.hpp
1//
2// Copyright 2010-2012,2014-2015 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10// define API capabilities for compile time detection of new features
11#define UHD_USRP_MULTI_USRP_REF_SOURCES_API
12#define UHD_USRP_MULTI_USRP_GET_RATES_API
13#define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
14#define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
15#define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
16#define UHD_USRP_MULTI_USRP_BW_RANGE_API
17#define UHD_USRP_MULTI_USRP_USER_REGS_API
18#define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
19#define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
20#define UHD_USRP_MULTI_USRP_GPIO_API
21#define UHD_USRP_MULTI_USRP_REGISTER_API
22#define UHD_USRP_MULTI_USRP_FILTER_API
23#define UHD_USRP_MULTI_USRP_LO_CONFIG_API
24#define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
25#define UHD_USRP_MULTI_USRP_POWER_LEVEL
26
27#include <uhd/config.hpp>
28#include <uhd/device.hpp>
31#include <uhd/types/filters.hpp>
32#include <uhd/types/ranges.hpp>
33#include <uhd/types/sensors.hpp>
41#include <complex>
42#include <memory>
43#include <string>
44#include <vector>
45
46namespace uhd { namespace usrp {
47
95{
96public:
97 typedef std::shared_ptr<multi_usrp> sptr;
98
99 virtual ~multi_usrp(void) = 0;
100
102 static const size_t ALL_MBOARDS;
103
105 static const size_t ALL_CHANS;
106
108 static const std::string ALL_GAINS;
109
111 static const std::string ALL_LOS;
112
120 static sptr make(const device_addr_t& dev_addr);
121
136 virtual device::sptr get_device(void) = 0;
137
140 virtual uhd::property_tree::sptr get_tree(void) const = 0;
141
144
147
156
165
166 /*******************************************************************
167 * Mboard methods
168 ******************************************************************/
169
192 virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
193
199 virtual double get_master_clock_rate(size_t mboard = 0) = 0;
200
219 virtual meta_range_t get_master_clock_rate_range(const size_t mboard = 0) = 0;
220
225 virtual std::string get_pp_string(void) = 0;
226
232 virtual std::string get_mboard_name(size_t mboard = 0) = 0;
233
239 virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
240
246 virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
247
259 virtual void set_time_now(
260 const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
261
274 virtual void set_time_next_pps(
275 const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
276
292 virtual void set_time_unknown_pps(const time_spec_t& time_spec) = 0;
293
300 virtual bool get_time_synchronized(void) = 0;
301
312 virtual void set_command_time(
313 const uhd::time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
314
320 virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
321
334 virtual void issue_stream_cmd(
335 const stream_cmd_t& stream_cmd, size_t chan = ALL_CHANS) = 0;
336
379 virtual void set_time_source(
380 const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
381
387 virtual std::string get_time_source(const size_t mboard) = 0;
388
394 virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
395
438 virtual void set_clock_source(
439 const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
440
446 virtual std::string get_clock_source(const size_t mboard) = 0;
447
453 virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
454
465 virtual void set_sync_source(const std::string& clock_source,
466 const std::string& time_source,
467 const size_t mboard = ALL_MBOARDS) = 0;
468
491 virtual void set_sync_source(
492 const device_addr_t& sync_source, const size_t mboard = ALL_MBOARDS) = 0;
493
499 virtual device_addr_t get_sync_source(const size_t mboard) = 0;
500
506 virtual std::vector<device_addr_t> get_sync_sources(const size_t mboard) = 0;
507
523 const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
524
540 const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
541
545 virtual size_t get_num_mboards(void) = 0;
546
554 const std::string& name, size_t mboard = 0) = 0;
555
561 virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
562
572 virtual void set_user_register(
573 const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
574
599 virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan = 0) = 0;
600
618 virtual uhd::rfnoc::radio_control& get_radio_control(const size_t chan = 0) = 0;
619
620 /*******************************************************************
621 * RX methods
622 ******************************************************************/
633 virtual void set_rx_subdev_spec(
634 const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
635
641 virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
642
648 virtual size_t get_rx_num_channels(void) = 0;
649
655 virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
656
666 virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
667
677 virtual void set_rx_spp(const size_t spp, const size_t chan = ALL_CHANS) = 0;
678
684 virtual double get_rx_rate(size_t chan = 0) = 0;
685
691 virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
692
704 const tune_request_t& tune_request, size_t chan = 0) = 0;
705
711 virtual double get_rx_freq(size_t chan = 0) = 0;
712
722 virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
723
729 virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
730
731 /**************************************************************************
732 * LO controls
733 *************************************************************************/
747 virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
748
767 virtual void set_rx_lo_source(
768 const std::string& src, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
769
778 virtual const std::string get_rx_lo_source(
779 const std::string& name = ALL_LOS, size_t chan = 0) = 0;
780
793 virtual std::vector<std::string> get_rx_lo_sources(
794 const std::string& name = ALL_LOS, size_t chan = 0) = 0;
795
807 bool enabled, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
808
815 const std::string& name = ALL_LOS, size_t chan = 0) = 0;
816
841 virtual double set_rx_lo_freq(
842 double freq, const std::string& name, size_t chan = 0) = 0;
843
854 virtual double get_rx_lo_freq(const std::string& name, size_t chan = 0) = 0;
855
866 const std::string& name, size_t chan = 0) = 0;
867
880 virtual std::vector<std::string> get_tx_lo_names(size_t chan = 0) = 0;
881
897 virtual void set_tx_lo_source(const std::string& src,
898 const std::string& name = ALL_LOS,
899 const size_t chan = 0) = 0;
900
909 virtual const std::string get_tx_lo_source(
910 const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
911
922 virtual std::vector<std::string> get_tx_lo_sources(
923 const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
924
936 const bool enabled, const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
937
944 const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
945
970 virtual double set_tx_lo_freq(
971 const double freq, const std::string& name, const size_t chan = 0) = 0;
972
983 virtual double get_tx_lo_freq(const std::string& name, const size_t chan = 0) = 0;
984
995 const std::string& name, const size_t chan = 0) = 0;
996
997 /**************************************************************************
998 * Gain controls
999 *************************************************************************/
1013 virtual void set_rx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1014
1027 virtual std::vector<std::string> get_rx_gain_profile_names(const size_t chan = 0) = 0;
1028
1038 const std::string& profile, const size_t chan = 0) = 0;
1039
1045 virtual std::string get_rx_gain_profile(const size_t chan = 0) = 0;
1046
1048 void set_rx_gain(double gain, size_t chan = 0)
1049 {
1050 return this->set_rx_gain(gain, ALL_GAINS, chan);
1051 }
1052
1070 virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
1071
1089 virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
1090
1098 virtual double get_rx_gain(const std::string& name, size_t chan = 0) = 0;
1099
1101 double get_rx_gain(size_t chan = 0)
1102 {
1103 return this->get_rx_gain(ALL_GAINS, chan);
1104 }
1105
1116 virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
1117
1125 virtual gain_range_t get_rx_gain_range(const std::string& name, size_t chan = 0) = 0;
1126
1129 {
1130 return this->get_rx_gain_range(ALL_GAINS, chan);
1131 }
1132
1139 virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
1140
1149 virtual void set_rx_antenna(const std::string& ant, size_t chan = 0) = 0;
1150
1156 virtual std::string get_rx_antenna(size_t chan = 0) = 0;
1157
1163 virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
1164
1174 virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1175
1181 virtual double get_rx_bandwidth(size_t chan = 0) = 0;
1182
1188 virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
1189
1197 virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
1198
1205 virtual sensor_value_t get_rx_sensor(const std::string& name, size_t chan = 0) = 0;
1206
1212 virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
1213
1226 virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
1227
1235 virtual void set_rx_dc_offset(
1236 const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1237
1242 virtual meta_range_t get_rx_dc_offset_range(size_t chan = 0) = 0;
1243
1250 virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
1251
1259 virtual void set_rx_iq_balance(
1260 const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1261
1262
1263 /**************************************************************************
1264 * Power level controls
1265 *************************************************************************/
1282 virtual bool has_rx_power_reference(const size_t chan = 0) = 0;
1283
1299 const double power_dbm, const size_t chan = 0) = 0;
1300
1313 virtual double get_rx_power_reference(const size_t chan = 0) = 0;
1314
1324 virtual meta_range_t get_rx_power_range(const size_t chan) = 0;
1325
1326 /*******************************************************************
1327 * TX methods
1328 ******************************************************************/
1339 const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
1340
1346 virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
1347
1353 virtual size_t get_tx_num_channels(void) = 0;
1354
1360 virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
1361
1371 virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
1372
1378 virtual double get_tx_rate(size_t chan = 0) = 0;
1379
1385 virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
1386
1398 const tune_request_t& tune_request, size_t chan = 0) = 0;
1399
1405 virtual double get_tx_freq(size_t chan = 0) = 0;
1406
1416 virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
1417
1423 virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
1424
1438 virtual void set_tx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1439
1452 virtual std::vector<std::string> get_tx_gain_profile_names(const size_t chan = 0) = 0;
1453
1463 const std::string& profile, const size_t chan = 0) = 0;
1464
1470 virtual std::string get_tx_gain_profile(const size_t chan = 0) = 0;
1471
1473 void set_tx_gain(double gain, size_t chan = 0)
1474 {
1475 return this->set_tx_gain(gain, ALL_GAINS, chan);
1476 }
1477
1490 virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
1491
1499 virtual double get_tx_gain(const std::string& name, size_t chan = 0) = 0;
1500
1502 double get_tx_gain(size_t chan = 0)
1503 {
1504 return this->get_tx_gain(ALL_GAINS, chan);
1505 }
1506
1517 virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
1518
1526 virtual gain_range_t get_tx_gain_range(const std::string& name, size_t chan = 0) = 0;
1527
1530 {
1531 return this->get_tx_gain_range(ALL_GAINS, chan);
1532 }
1533
1540 virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
1541
1542 /**************************************************************************
1543 * Power level controls
1544 *************************************************************************/
1561 virtual bool has_tx_power_reference(const size_t chan = 0) = 0;
1562
1578 const double power_dbm, const size_t chan = 0) = 0;
1579
1592 virtual double get_tx_power_reference(const size_t chan = 0) = 0;
1593
1603 virtual meta_range_t get_tx_power_range(const size_t chan) = 0;
1604
1613 virtual void set_tx_antenna(const std::string& ant, size_t chan = 0) = 0;
1614
1620 virtual std::string get_tx_antenna(size_t chan = 0) = 0;
1621
1627 virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
1628
1638 virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1639
1645 virtual double get_tx_bandwidth(size_t chan = 0) = 0;
1646
1652 virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
1653
1661 virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
1662
1669 virtual sensor_value_t get_tx_sensor(const std::string& name, size_t chan = 0) = 0;
1670
1676 virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1677
1684 virtual void set_tx_dc_offset(
1685 const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1686
1691 virtual meta_range_t get_tx_dc_offset_range(size_t chan = 0) = 0;
1692
1700 virtual void set_tx_iq_balance(
1701 const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1702
1703 /*******************************************************************
1704 * GPIO methods
1705 ******************************************************************/
1706
1712 virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1713
1731 virtual void set_gpio_attr(const std::string& bank,
1732 const std::string& attr,
1733 const uint32_t value,
1734 const uint32_t mask = 0xffffffff,
1735 const size_t mboard = 0) = 0;
1736
1753 virtual uint32_t get_gpio_attr(
1754 const std::string& bank, const std::string& attr, const size_t mboard = 0) = 0;
1755
1769 virtual std::vector<std::string> get_gpio_src_banks(const size_t mboard = 0) = 0;
1770
1781 virtual std::vector<std::string> get_gpio_srcs(
1782 const std::string& bank, const size_t mboard = 0) = 0;
1783
1793 virtual std::vector<std::string> get_gpio_src(
1794 const std::string& bank, const size_t mboard = 0) = 0;
1795
1810 virtual void set_gpio_src(const std::string& bank,
1811 const std::vector<std::string>& src,
1812 const size_t mboard = 0) = 0;
1813
1814 /*******************************************************************
1815 * Filter API methods
1816 ******************************************************************/
1817 // TODO: This should be a const function, but I don't want to wrestle with the
1818 // compiler right now
1826 virtual std::vector<std::string> get_rx_filter_names(const size_t chan) = 0;
1827
1835 const std::string& name, const size_t chan) = 0;
1836
1844 virtual void set_rx_filter(const std::string& name,
1846 const size_t chan) = 0;
1847
1848 // TODO: This should be a const function, but I don't want to wrestle with the
1849 // compiler right now
1857 virtual std::vector<std::string> get_tx_filter_names(const size_t chan) = 0;
1858
1866 const std::string& name, const size_t chan) = 0;
1867
1875 virtual void set_tx_filter(const std::string& name,
1877 const size_t chan) = 0;
1878
1896 virtual uhd::rfnoc::mb_controller& get_mb_controller(const size_t mboard = 0) = 0;
1897};
1898
1899}} // namespace uhd::usrp
std::shared_ptr< device > sptr
Definition: device.hpp:29
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
Definition: property_tree.hpp:216
Definition: mb_controller.hpp:27
Definition: radio_control.hpp:29
Definition: stream.hpp:172
Definition: time_spec.hpp:31
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:250
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
Definition: multi_usrp.hpp:95
virtual void set_rx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard=0)=0
virtual meta_range_t get_rx_power_range(const size_t chan)=0
virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args)=0
Convenience method to get a TX streamer. See also uhd::device::get_tx_stream().
Definition: multi_usrp.hpp:1473
virtual std::string get_time_source(const size_t mboard)=0
virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_master_clock_rate_range(const size_t mboard=0)=0
A wildcard LO stage name.
Definition: multi_usrp.hpp:111
virtual std::vector< device_addr_t > get_sync_sources(const size_t mboard)=0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual std::string get_clock_source(const size_t mboard)=0
virtual void set_rx_spp(const size_t spp, const size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_rx_sensor_names(size_t chan=0)=0
A wildcard motherboard index.
Definition: multi_usrp.hpp:102
virtual std::vector< std::string > get_tx_filter_names(const size_t chan)=0
virtual double get_tx_bandwidth(size_t chan=0)=0
virtual void set_tx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual device_addr_t get_sync_source(const size_t mboard)=0
virtual double get_tx_rate(size_t chan=0)=0
virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard=0)=0
virtual void set_rx_gain_profile(const std::string &profile, const size_t chan=0)=0
virtual std::vector< std::string > get_rx_antennas(size_t chan=0)=0
virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan=0)=0
virtual std::string get_rx_subdev_name(size_t chan=0)=0
virtual void set_time_now(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_tx_rates(size_t chan=0)=0
virtual std::vector< std::string > get_tx_antennas(size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_names(size_t chan=0)=0
virtual void set_time_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual double get_rx_lo_freq(const std::string &name, size_t chan=0)=0
virtual double set_rx_lo_freq(double freq, const std::string &name, size_t chan=0)=0
virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual size_t get_tx_num_channels(void)=0
virtual double get_tx_power_reference(const size_t chan=0)=0
virtual std::vector< std::string > get_rx_lo_names(size_t chan=0)=0
virtual void set_time_unknown_pps(const time_spec_t &time_spec)=0
virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_rx_filter_names(const size_t chan)=0
virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_rx_lo_export_enabled(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual std::string get_tx_subdev_name(size_t chan=0)=0
virtual double get_rx_gain(const std::string &name, size_t chan=0)=0
virtual const std::string get_rx_lo_source(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual void set_rx_bandwidth(double bandwidth, size_t chan=0)=0
virtual void set_tx_antenna(const std::string &ant, size_t chan=0)=0
virtual meta_range_t get_tx_power_range(const size_t chan)=0
virtual void set_gpio_src(const std::string &bank, const std::vector< std::string > &src, const size_t mboard=0)=0
virtual bool get_tx_lo_export_enabled(const std::string &name=ALL_LOS, const size_t chan=0)=0
A wildcard gain element name.
Definition: multi_usrp.hpp:108
virtual std::string get_rx_gain_profile(const size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_names(size_t chan=0)=0
virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args)=0
Convenience method to get a RX streamer. See also uhd::device::get_rx_stream().
virtual time_spec_t get_time_last_pps(size_t mboard=0)=0
virtual void set_time_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0
virtual void set_rx_iq_balance(const bool enb, size_t chan)=0
virtual void set_rx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_time_sources(const size_t mboard)=0
virtual void set_clock_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual void clear_command_time(size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_dc_offset_range(size_t chan=0)=0
Definition: multi_usrp.hpp:1502
Definition: multi_usrp.hpp:1101
virtual std::vector< std::string > get_gpio_banks(const size_t mboard)=0
virtual double get_normalized_rx_gain(size_t chan=0)=0
virtual void set_sync_source(const device_addr_t &sync_source, const size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_rates(size_t chan=0)=0
virtual ~multi_usrp(void)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan=0)=0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan=0)=0
Definition: multi_usrp.hpp:1529
virtual std::vector< std::string > get_mboard_sensor_names(size_t mboard=0)=0
virtual std::vector< std::string > get_gpio_src(const std::string &bank, const size_t mboard=0)=0
virtual void set_rx_antenna(const std::string &ant, size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_profile_names(const size_t chan=0)=0
virtual void set_clock_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan=0)=0
virtual void set_rx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan=0)=0
Definition: multi_usrp.hpp:1128
virtual std::string get_tx_antenna(size_t chan=0)=0
virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain_profile(const std::string &profile, const size_t chan=0)=0
Definition: multi_usrp.hpp:1048
virtual const std::string get_tx_lo_source(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard=0)=0
virtual void set_rx_lo_source(const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan=0)=0
virtual freq_range_t get_tx_freq_range(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_rx_filter(const std::string &name, const size_t chan)=0
virtual void set_rx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard=0)=0
virtual double get_rx_bandwidth(size_t chan=0)=0
virtual void set_master_clock_rate(double rate, size_t mboard=ALL_MBOARDS)=0
virtual freq_range_t get_rx_freq_range(size_t chan=0)=0
virtual double get_tx_freq(size_t chan=0)=0
virtual tune_result_t set_rx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_rx_rate(size_t chan=0)=0
virtual double get_rx_power_reference(const size_t chan=0)=0
virtual std::string get_pp_string(void)=0
virtual std::vector< std::string > get_gpio_srcs(const std::string &bank, const size_t mboard=0)=0
virtual std::string get_tx_gain_profile(const size_t chan=0)=0
virtual double get_normalized_tx_gain(size_t chan=0)=0
virtual std::vector< std::string > get_clock_sources(const size_t mboard)=0
virtual uhd::rfnoc::radio_control & get_radio_control(const size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_normalized_tx_gain(double gain, size_t chan=0)=0
virtual meta_range_t get_tx_dc_offset_range(size_t chan=0)=0
virtual uhd::property_tree::sptr get_tree(void) const =0
virtual void set_normalized_rx_gain(double gain, size_t chan=0)=0
virtual void set_tx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual dict< std::string, std::string > get_usrp_rx_info(size_t chan=0)=0
virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan=0)=0
virtual void set_rx_agc(bool enable, size_t chan=0)=0
virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan=0)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan=0)=0
virtual std::string get_mboard_name(size_t mboard=0)=0
virtual void set_tx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual device::sptr get_device(void)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual freq_range_t get_fe_rx_freq_range(size_t chan=0)=0
virtual void set_sync_source(const std::string &clock_source, const std::string &time_source, const size_t mboard=ALL_MBOARDS)=0
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:97
virtual std::vector< std::string > get_gpio_src_banks(const size_t mboard=0)=0
virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_time_synchronized(void)=0
virtual void set_tx_bandwidth(double bandwidth, size_t chan=0)=0
virtual std::string get_rx_antenna(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_tx_filter(const std::string &name, const size_t chan)=0
virtual freq_range_t get_fe_tx_freq_range(size_t chan=0)=0
virtual void set_rx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual void set_tx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual double get_rx_freq(size_t chan=0)=0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, size_t chan=0)=0
virtual size_t get_num_mboards(void)=0
virtual tune_result_t set_tx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_tx_gain(const std::string &name, size_t chan=0)=0
virtual double get_master_clock_rate(size_t mboard=0)=0
virtual bool has_rx_power_reference(const size_t chan=0)=0
virtual bool has_tx_power_reference(const size_t chan=0)=0
virtual void set_tx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_names(size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_profile_names(const size_t chan=0)=0
virtual void set_tx_lo_source(const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_rx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual size_t get_rx_num_channels(void)=0
virtual time_spec_t get_time_now(size_t mboard=0)=0
virtual std::vector< std::string > get_tx_sensor_names(size_t chan=0)=0
virtual uhd::rfnoc::mb_controller & get_mb_controller(const size_t mboard=0)=0
virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0
virtual dict< std::string, std::string > get_usrp_tx_info(size_t chan=0)=0
A wildcard channel index.
Definition: multi_usrp.hpp:105
Definition: subdev_spec.hpp:60
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
Definition: config.h:70
Definition: soft_register.hpp:87
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:22
Definition: build_info.hpp:12
Definition: ranges.hpp:65
Definition: sensors.hpp:29
Definition: stream.hpp:59
Definition: stream_cmd.hpp:40
Definition: tune_request.hpp:25
Definition: tune_result.hpp:19
