USRP Hardware Driver and USRP Manual Version: 4.1.0.1
uhd::rfnoc::rfnoc_graph Class Referenceabstract
#include <uhd/rfnoc_graph.hpp>
Inheritance diagram for uhd::rfnoc::rfnoc_graph:
using sptr = std::shared_ptr< rfnoc_graph >
virtual ~rfnoc_graph ()
virtual std::vector< block_id_tfind_blocks (const std::string &block_id_hint) const =0
template<typename T >
virtual bool has_block (const block_id_t &block_id) const =0
 Checks if a specific NoC block exists on the device. More...
virtual noc_block_base::sptr get_block (const block_id_t &block_id) const =0
 Returns a block controller class for an NoC block. More...
std::shared_ptr< T > get_block (const block_id_t &block_id) const
virtual bool is_connectable (const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port)=0
virtual void connect (const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port, bool skip_property_propagation=false)=0
virtual void connect (uhd::tx_streamer::sptr streamer, size_t strm_port, const block_id_t &dst_blk, size_t dst_port, uhd::transport::adapter_id_t adapter_id=uhd::transport::NULL_ADAPTER_ID)=0
virtual void connect (const block_id_t &src_blk, size_t src_port, uhd::rx_streamer::sptr streamer, size_t strm_port, uhd::transport::adapter_id_t adapter_id=uhd::transport::NULL_ADAPTER_ID)=0
virtual void disconnect (const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port)=0
virtual void disconnect (const std::string &streamer_id)=0
virtual void disconnect (const std::string &streamer_id, size_t port)=0
virtual std::vector< uhd::transport::adapter_id_tenumerate_adapters_from_src (const block_id_t &src_blk, size_t src_port)=0
virtual std::vector< uhd::transport::adapter_id_tenumerate_adapters_to_dst (const block_id_t &dst_blk, size_t dst_port)=0
virtual std::vector< graph_edge_tenumerate_static_connections () const =0
virtual std::vector< graph_edge_tenumerate_active_connections ()=0
virtual void commit ()=0
virtual void release ()=0
virtual rx_streamer::sptr create_rx_streamer (const size_t num_ports, const stream_args_t &args)=0
virtual tx_streamer::sptr create_tx_streamer (const size_t num_ports, const stream_args_t &args)=0
virtual size_t get_num_mboards () const =0
virtual std::shared_ptr< mb_controllerget_mb_controller (const size_t mb_index=0)=0
 Return a reference to a motherboard controller. More...
virtual bool synchronize_devices (const uhd::time_spec_t &time_spec, const bool quiet)=0
virtual uhd::property_tree::sptr get_tree (void) const =0
 Return a reference to the property tree. More...
static sptr make (const device_addr_t &dev_addr)
The core class for a UHD session with (an) RFNoC device(s)
This class is a superset of uhd::device. It does not only hold a device session, but also manages the RFNoC blocks on those devices. Only devices compatible with a modern version of RFNoC can be addressed by this class.
using uhd::rfnoc::rfnoc_graph::sptr = std::shared_ptr<rfnoc_graph>
A shared pointer to allow easy access to this class and for automatic memory management.
◆ ~rfnoc_graph()
virtual uhd::rfnoc::rfnoc_graph::~rfnoc_graph ( )
◆ commit()
virtual void uhd::rfnoc::rfnoc_graph::commit ( )
Commit graph and run initial checks
This method needs to be called when the graph is ready for action. It will run checks on the graph and run a property propagation.
Exceptions
uhd::resolve_errorif the properties fail to resolve.
◆ connect() [1/3]
virtual void uhd::rfnoc::rfnoc_graph::connect ( const block_id_t src_blk,
size_t  src_port,
const block_id_t dst_blk,
size_t  dst_port,
bool  skip_property_propagation = false
Connect a RFNoC block with block ID src_block to another with block ID dst_block.
Note you need to also call this on statically connected blocks if you desire to use them.
src_blkThe block ID of the source block to connect.
src_portThe port of the source block to connect.
dst_blkThe block ID of the destination block to connect to.
dst_portThe port of the destination block to connect to.
skip_property_propagationSkip property propagation for this edge
Exceptions
uhd::routing_errorif the source or destination ports are statically connected to a different block
◆ connect() [2/3]
size_t  src_port,
size_t  strm_port,
uhd::transport::adapter_id_t  adapter_id = uhd::transport::NULL_ADAPTER_ID
Connect RX streamer to an output of an NoC block
streamerThe streamer to connect.
strm_portThe port of the streamer to connect.
adapter_idThe local device ID (transport) to use for this connection.
Exceptions
connect_disallowed_on_srcif the source port is statically connected to a different block
◆ connect() [3/3]
virtual void uhd::rfnoc::rfnoc_graph::connect ( uhd::tx_streamer::sptr  streamer,
size_t  strm_port,
size_t  dst_port,
Connect TX streamer to an input of an NoC block
Exceptions
connect_disallowed_on_dstif the destination port is statically connected to a different block
◆ create_rx_streamer()
virtual rx_streamer::sptr uhd::rfnoc::rfnoc_graph::create_rx_streamer ( const size_t  num_ports,
const stream_args_t args
Create a new receive streamer from the streamer arguments The created streamer is still not connected to anything yet. The graph::connect call has to be made on this streamer to start using it. If a different streamer is already connected to the intended source then that call may fail.
num_portsNumber of ports that will be connected to the streamer
argsArguments to aid the construction of the streamer
a shared pointer to a new streamer
◆ create_tx_streamer()
virtual tx_streamer::sptr uhd::rfnoc::rfnoc_graph::create_tx_streamer ( const size_t  num_ports,
Create a new transmit streamer from the streamer arguments The created streamer is still not connected to anything yet. The graph::connect call has to be made on this streamer to start using it. If a different streamer is already connected to the intended sink then that call may fail.
◆ disconnect() [1/3]
virtual void uhd::rfnoc::rfnoc_graph::disconnect ( const block_id_t src_blk,
size_t  src_port,
size_t  dst_port
Disconnect a RFNoC block with block ID src_blk from another with block ID dst_blk. This will logically disconnect the blocks, but the physical connection will not be changed until a new connection is made on the source port.
src_blkThe block ID of the source block to disconnect.
src_portThe port of the source block to disconnect.
dst_blkThe block ID of the destination block to disconnect from.
dst_portThe port of the destination block to disconnect from.
◆ disconnect() [2/3]
virtual void uhd::rfnoc::rfnoc_graph::disconnect ( const std::string &  streamer_id)
Disconnect a streamer with ID streamer_id. This will logically disconnect the streamer, but physical connection will not be changed. For RX streamers, the physical connection will be changed when a new connection is made to the upstream source port(s). For TX streamers, the physical connection will be changed when the TX streamer is destroyed or the port(s) are connected to another block.
streamer_idThe ID of the streamer to disconnect.
◆ disconnect() [3/3]
virtual void uhd::rfnoc::rfnoc_graph::disconnect ( const std::string &  streamer_id,
size_t  port
Disconnect port port of a streamer with ID streamer_id. This will logically disconnect the streamer, but physical connection will not be changed. For RX streamers, the physical connection will be changed when a new connection is made to the upstreame source port. For TX streamers, the physical connection will be changed when the TX streamer is destroyed or the port is connected to another block.
streamer_idThe ID of the streamer.
portThe port to disconnect.
◆ enumerate_active_connections()
virtual std::vector< graph_edge_t > uhd::rfnoc::rfnoc_graph::enumerate_active_connections ( )
Enumerate all the active connections in the graph
A vector containing all the active edges in the graph.
◆ enumerate_adapters_from_src()
virtual std::vector< uhd::transport::adapter_id_t > uhd::rfnoc::rfnoc_graph::enumerate_adapters_from_src ( const block_id_t src_blk,
size_t  src_port
Enumerate all the possible host transport adapters that can be used to receive from the specified block
If addr and second_addr were specified in device_args, the adapter_id_t associated with addr will come first in the vector, then second_addr.
src_blkThe block ID of the source block to connect to.
src_portThe port of the source block to connect to.
◆ enumerate_adapters_to_dst()
virtual std::vector< uhd::transport::adapter_id_t > uhd::rfnoc::rfnoc_graph::enumerate_adapters_to_dst ( const block_id_t dst_blk,
size_t  dst_port
Enumerate all the possible host transport adapters that can be used to send to the specified block
◆ enumerate_static_connections()
virtual std::vector< graph_edge_t > uhd::rfnoc::rfnoc_graph::enumerate_static_connections ( ) const
Enumerate all the possible static connections in the graph
A vector containing all the static edges in the graph.
◆ find_blocks() [1/2]
std::vector< block_id_t > uhd::rfnoc::rfnoc_graph::find_blocks ( const std::string &  block_id_hint) const
Type-cast version of find_blocks().
◆ find_blocks() [2/2]
virtual std::vector< block_id_t > uhd::rfnoc::rfnoc_graph::find_blocks ( const std::string &  block_id_hint) const
Returns the block ids of all blocks that match the specified hint
Uses block_id_t::match() internally. If no matching block is found, it returns an empty vector.
The returned vector is sorted lexicographically.
To access specialized block controller classes (i.e. derived from uhd::rfnoc::noc_block_base), use the templated version of this function:
// Assume DEV is an rfnoc_graph::sptr
auto null_blocks = DEV->find_blocks<null_block_control>("NullSrcSink");
if (null_blocks.empty()) { cout << "No null blocks found!" << endl; }
Note
this access is not thread safe if performed during block enumeration
A sorted list of block IDs that match the hint
◆ get_block() [1/2]
std::shared_ptr< T > uhd::rfnoc::rfnoc_graph::get_block ( const block_id_t block_id) const
Same as get_block(), but with a type cast.
If you have a block controller class that is derived from noc_block_base, use this function to access its specific methods. If the given block ID is not valid (i.e. such a block does not exist on this device) or if the type does not match, it will throw a uhd::lookup_error.
auto block_controller = DEV->get_block<my_noc_block>("0/MyBlock#0");
block_controller->my_own_block_method();
Note
◆ get_block() [2/2]
virtual noc_block_base::sptr uhd::rfnoc::rfnoc_graph::get_block ( const block_id_t block_id) const
If the given block ID is not valid (i.e. such a block does not exist on this device), it will throw a uhd::lookup_error.
block_idCanonical block name (e.g. "0/FFT#1").
Note
this access is not thread safe if peformed during block enumeration
◆ get_mb_controller()
virtual std::shared_ptr< mb_controller > uhd::rfnoc::rfnoc_graph::get_mb_controller ( const size_t  mb_index = 0)
◆ get_num_mboards()
virtual size_t uhd::rfnoc::rfnoc_graph::get_num_mboards ( ) const
◆ get_tree()
virtual uhd::property_tree::sptr uhd::rfnoc::rfnoc_graph::get_tree ( void  ) const
◆ has_block() [1/2]
bool uhd::rfnoc::rfnoc_graph::has_block ( const block_id_t block_id) const
Same as has_block(), but with a type check.
true if a block of type T with the specified id exists
Note
◆ has_block() [2/2]
virtual bool uhd::rfnoc::rfnoc_graph::has_block ( const block_id_t block_id) const
true if a block with the specified id exists
Note
◆ is_connectable()
virtual bool uhd::rfnoc::rfnoc_graph::is_connectable ( const block_id_t src_blk,
size_t  src_port,
size_t  dst_port
Verify if two blocks/ports are connectable.
If this call returns true, then connect() can be called with the same arguments. It does not, however, check if the block was already connnected.
true if the two blocks are connectable
◆ make()
static sptr uhd::rfnoc::rfnoc_graph::make ( const device_addr_t dev_addr)
Make a new USRP graph from the specified device address(es).
dev_addrthe device address
A new rfnoc_graph object
Exceptions
uhd::key_errorno device found
uhd::index_errorfewer devices found than expected
◆ release()
virtual void uhd::rfnoc::rfnoc_graph::release ( )
Release graph: Opposite of commit()
Calling this will disable property propagation until commit() has been called an equal number of times.
◆ synchronize_devices()
virtual bool uhd::rfnoc::rfnoc_graph::synchronize_devices ( const uhd::time_spec_t time_spec,
const bool  quiet
Run any routines necessary to synchronize devices
The specific implementation of this call are device-specific. In all cases, it will set the time to a common value.
Any application that requires any kind of phase or time alignment (if supported by the hardware) must call this before operation.
time_specThe timestamp to be used to sync the devices. It will be an input to set_time_next_pps() on the motherboard controllers.
quietIf true, there will be no errors or warnings printed if the synchronization happens. This call will always be called during initialization, but preconditions might not yet be met (e.g., the time and reference sources might still be internal), and will fail quietly in that case.
the success status of this call (true means devices are now synchronized)
