#include <uhd/rfnoc/null_block_control.hpp>
Public Types | |
| enum | port_type_t { SINK , SOURCE , LOOP } |
| enum | count_type_t { LINES , PACKETS } |
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd)=0 |
| virtual void | reset_counters ()=0 |
| virtual void | set_bytes_per_packet (const uint32_t bpp)=0 |
| virtual void | set_throttle_cycles (const uint32_t cycs)=0 |
| virtual uint32_t | get_item_width ()=0 |
| virtual uint32_t | get_nipc ()=0 |
| virtual uint32_t | get_lines_per_packet ()=0 |
| virtual uint32_t | get_bytes_per_packet ()=0 |
| virtual uint32_t | get_throttle_cycles ()=0 |
| virtual uint64_t | get_count (const port_type_t port_type, const count_type_t count_type)=0 |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
| static const uint32_t | REG_CTRL_STATUS |
| static const uint32_t | REG_SRC_LINES_PER_PKT |
| static const uint32_t | REG_SRC_BYTES_PER_PKT |
| static const uint32_t | REG_SRC_THROTTLE_CYC |
| static const uint32_t | REG_SNK_LINE_CNT_LO |
| static const uint32_t | REG_SNK_LINE_CNT_HI |
| static const uint32_t | REG_SNK_PKT_CNT_LO |
| static const uint32_t | REG_SNK_PKT_CNT_HI |
| static const uint32_t | REG_SRC_LINE_CNT_LO |
| static const uint32_t | REG_SRC_LINE_CNT_HI |
| static const uint32_t | REG_SRC_PKT_CNT_LO |
| static const uint32_t | REG_SRC_PKT_CNT_HI |
| static const uint32_t | REG_LOOP_LINE_CNT_LO |
| static const uint32_t | REG_LOOP_LINE_CNT_HI |
| static const uint32_t | REG_LOOP_PKT_CNT_LO |
| static const uint32_t | REG_LOOP_PKT_CNT_HI |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
Get bytes per packet
Returns the number of lines that have been consumed on port 0 since the last reset
| port_type | The port for which the counter value should be returned, sink, source, or loop. |
| count_type | If we want the packet count, or the line count |
Get item width (ITEM_W)
Get lines per packet (including the header!)
Get number of items per clock (NIPC)
Get throttle cycles
Start/stop the null source (port 0)
Reset the counters
Set bytes per packet
Note: This sets the entire packet size, including header.
Set throttle cycles
The block will wait this many cycles between packets. Useful for reducing the data output.
