uhd::rfnoc::duc_block_control Class Referenceabstract
#include <uhd/rfnoc/duc_block_control.hpp>
Inheritance diagram for uhd::rfnoc::duc_block_control:
virtual double set_freq (const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0
virtual double get_freq (const size_t chan) const =0
virtual uhd::freq_range_t get_frequency_range (const size_t chan) const =0
virtual double get_input_rate (const size_t chan) const =0
virtual double get_output_rate (const size_t chan) const =0
virtual void set_output_rate (const double rate, const size_t chan)=0
virtual uhd::meta_range_t get_input_rates (const size_t chan) const =0
virtual double set_input_rate (const double rate, const size_t chan)=0
static const uint32_t RB_COMPAT_NUM
static const uint32_t RB_NUM_HB
static const uint32_t RB_CIC_MAX_INTERP
static const uint32_t SR_N_ADDR
static const uint32_t SR_M_ADDR
static const uint32_t SR_CONFIG_ADDR
static const uint32_t SR_FREQ_ADDR
static const uint32_t SR_SCALE_IQ_ADDR
static const uint32_t SR_INTERP_ADDR
static const uint32_t SR_TIME_INCR_ADDR
DUC Block Control Class
The DUC Block is a multi-channel digital upconverter (DUC) with built-in frequency shift. The number of channels as well as the maximum interpolation is configurable in the FPGA, the block controller will read out registers to identify the capabilities of this block.
  • freq: The frequency shift at the input. Note: A convenience method set_freq() is provided to set this property. It also takes care of the command time, which set_property() does not, and thus should be preferred.
  • interp: The interpolation value
◆ get_freq()
virtual double uhd::rfnoc::duc_block_control::get_freq ( const size_t  chan) const
Return the current DDS frequency
The current frequency of the DDS
◆ get_frequency_range()
virtual uhd::freq_range_t uhd::rfnoc::duc_block_control::get_frequency_range ( const size_t  chan) const
Return the range of frequencies that chan can be set to.
The frequency shifter is the last component in the DUC, and thus can shift frequencies (digitally) between -get_output_rate()/2 and +get_output_rate()/2.
The returned values are in Hz (not normalized frequencies) and are valid inputs for set_freq().
The range of frequencies that the DUC can shift the input by
◆ get_input_rate()
virtual double uhd::rfnoc::duc_block_control::get_input_rate ( const size_t  chan) const
Return the sampling rate at this block's input
chanThe channel for which the rate is being queried
◆ get_input_rates()
virtual uhd::meta_range_t uhd::rfnoc::duc_block_control::get_input_rates ( const size_t  chan) const
Return a range of valid input rates, based on the current output rate
Note the return value is only valid as long as the output rate does not change.
◆ get_output_rate()
virtual double uhd::rfnoc::duc_block_control::get_output_rate ( const size_t  chan) const
Return the sampling rate at this block's output
This is equivalent to calling get_input_rate() multiplied by the interpolation
◆ set_freq()
virtual double uhd::rfnoc::duc_block_control::set_freq ( const double  freq,
const size_t  chan,
const boost::optional< uhd::time_spec_t time = boost::none
Set the DDS frequency
freqThe frequency shift in Hz
chanThe channel to which this change shall be applied
timeWhen to apply the new frequency
The coerced, actual current frequency of the DDS
◆ set_input_rate()
virtual double uhd::rfnoc::duc_block_control::set_input_rate ( const double  rate,
const size_t  chan
Attempt to set the input rate of this block
This will set the interpolation such that the output rate is untouched, and that the output rate divided by the new interpolation is as close as possible to the requested rate.
rateThe requested rate
the coerced sampling rate at this block's output
◆ set_output_rate()
virtual void uhd::rfnoc::duc_block_control::set_output_rate ( const double  rate,
const size_t  chan
Manually set the sampling rate at this block's output
chanThe channel for which the rate is being set
◆ MAJOR_COMPAT
const uint16_t uhd::rfnoc::duc_block_control::MAJOR_COMPAT
◆ MINOR_COMPAT
const uint16_t uhd::rfnoc::duc_block_control::MINOR_COMPAT
◆ RB_CIC_MAX_INTERP
const uint32_t uhd::rfnoc::duc_block_control::RB_CIC_MAX_INTERP
◆ RB_COMPAT_NUM
const uint32_t uhd::rfnoc::duc_block_control::RB_COMPAT_NUM
◆ RB_NUM_HB
const uint32_t uhd::rfnoc::duc_block_control::RB_NUM_HB
◆ SR_CONFIG_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_CONFIG_ADDR
◆ SR_FREQ_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_FREQ_ADDR
◆ SR_INTERP_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_INTERP_ADDR
◆ SR_M_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_M_ADDR
◆ SR_N_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_N_ADDR
◆ SR_SCALE_IQ_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_SCALE_IQ_ADDR
◆ SR_TIME_INCR_ADDR
const uint32_t uhd::rfnoc::duc_block_control::SR_TIME_INCR_ADDR
