uhd::rfnoc::keep_one_in_n_block_control Class Referenceabstract
#include <uhd/rfnoc/keep_one_in_n_block_control.hpp>
Inheritance diagram for uhd::rfnoc::keep_one_in_n_block_control:
enum class  mode { SAMPLE_MODE , PACKET_MODE }
virtual size_t get_max_n () const =0
virtual size_t get_n (const size_t chan=0) const =0
virtual void set_n (const size_t n, const size_t chan=0)=0
virtual mode get_mode (const size_t chan=0) const =0
virtual void set_mode (const mode mode, const size_t chan=0)=0
static const uint32_t REG_N_OFFSET
static const uint32_t REG_MODE_OFFSET
static const uint32_t REG_WIDTH_N_OFFSET
Keep One in N Block Control Class
The Keep One in N block has two modes: sample mode and packet mode. In sample mode, the first sample is kept and then N-1 samples are dropped. Packet mode is similar to sample mode, except a packet of samples is kept and then N-1 packets are dropped. The packet size is determined automatically.
◆ mode
Enumerator
SAMPLE_MODE
PACKET_MODE
◆ get_max_n()
virtual size_t uhd::rfnoc::keep_one_in_n_block_control::get_max_n ( ) const
Get the maximum supported value for N
Get the maximum supported value for N for all channels
The maximum supported value for N
◆ get_mode()
virtual mode uhd::rfnoc::keep_one_in_n_block_control::get_mode ( const size_t  chan = 0) const
Get the current mode
Get the current mode (sample or packet mode, see mode enum)
chanThe block channel
The current mode
◆ get_n()
virtual size_t uhd::rfnoc::keep_one_in_n_block_control::get_n ( const size_t  chan = 0) const
Get the current value of N
The current value of N
◆ set_mode()
virtual void uhd::rfnoc::keep_one_in_n_block_control::set_mode ( const mode  mode,
Set the mode
Set the mode. There are two modes, sample mode (0) and packet mode (1). In sample mode, the block will keep 1 value and then drop N-1 values. In packet mode, the block will keep 1 packet and then drop N-1 packets.
modeThe mode of the block
◆ set_n()
virtual void uhd::rfnoc::keep_one_in_n_block_control::set_n ( const size_t  n,
Set the value of N
Set the value of N. See set_mode() for how the value of N is interpreted depending on the mode.
nThe number of samples or packets to drop (minus one)
◆ REG_MODE_OFFSET
const uint32_t uhd::rfnoc::keep_one_in_n_block_control::REG_MODE_OFFSET
◆ REG_N_OFFSET
const uint32_t uhd::rfnoc::keep_one_in_n_block_control::REG_N_OFFSET
◆ REG_WIDTH_N_OFFSET
const uint32_t uhd::rfnoc::keep_one_in_n_block_control::REG_WIDTH_N_OFFSET
