uhd::rfnoc::rf_control::core_iface Class Referenceabstract
#include <uhd/rfnoc/rf_control/core_iface.hpp>
Inheritance diagram for uhd::rfnoc::rf_control::core_iface:
uhd::rfnoc::radio_control
virtual ~core_iface ()=default
virtual std::string get_tx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_tx_antennas (const size_t chan) const =0
virtual void set_tx_antenna (const std::string &ant, const size_t chan)=0
virtual std::string get_rx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_rx_antennas (const size_t chan) const =0
virtual void set_rx_antenna (const std::string &ant, const size_t chan)=0
virtual double get_tx_frequency (const size_t chan)=0
virtual double set_tx_frequency (const double freq, size_t chan)=0
virtual void set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range (const size_t chan) const =0
virtual double get_rx_frequency (const size_t chan)=0
virtual double set_rx_frequency (const double freq, const size_t chan)=0
virtual void set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range (const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_tx_gain (const size_t chan)=0
virtual double get_tx_gain (const std::string &name, const size_t chan)=0
virtual double set_tx_gain (const double gain, const size_t chan)=0
virtual double set_tx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_rx_gain (const size_t chan)=0
virtual double get_rx_gain (const std::string &name, const size_t chan)=0
virtual double set_rx_gain (const double gain, const size_t chan)=0
virtual double set_rx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_agc (const bool enable, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan) const =0
virtual double get_tx_bandwidth (const size_t chan)=0
virtual double set_tx_bandwidth (const double bandwidth, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan) const =0
virtual double get_rx_bandwidth (const size_t chan)=0
virtual double set_rx_bandwidth (const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0
virtual void set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual const std::string get_rx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq (const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual const std::string get_tx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan)=0
Interface for generic RF control functions
This interface contains all methods related directly to RF control which aren't contained in a different rf_control class. These methods are not usually accessed via this interface, but are usually accessed via an instance of radio_control, which implements this class.
◆ ~core_iface()
virtual uhd::rfnoc::rf_control::core_iface::~core_iface ( )
virtualdefault
◆ get_rx_antenna()
virtual std::string uhd::rfnoc::rf_control::core_iface::get_rx_antenna ( const size_t  chan) const
Return the selected RX antenna for channel chan.
The selected antenna.
◆ get_rx_antennas()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_rx_antennas ( const size_t  chan) const
Return a list of valid RX antenna for channel chan.
◆ get_rx_bandwidth()
virtual double uhd::rfnoc::rf_control::core_iface::get_rx_bandwidth ( const size_t  chan)
Return the analog filter bandwidth channel chan
The actual bandwidth value
◆ get_rx_bandwidth_range()
virtual meta_range_t uhd::rfnoc::rf_control::core_iface::get_rx_bandwidth_range ( size_t  chan) const
Return a range of valid RX bandwidths
◆ get_rx_frequency()
virtual double uhd::rfnoc::rf_control::core_iface::get_rx_frequency ( const size_t  chan)
Return the current receive LO frequency on channel chan.
The current LO frequency.
◆ get_rx_frequency_range()
virtual uhd::freq_range_t uhd::rfnoc::rf_control::core_iface::get_rx_frequency_range ( const size_t  chan) const
Return the range of frequencies that chan can be tuned to.
The range of frequencies that we can tune the RX chan to
◆ get_rx_gain() [1/2]
virtual double uhd::rfnoc::rf_control::core_iface::get_rx_gain ( const size_t  chan)
Return the overall receive gain on channel chan
The actual gain value
◆ get_rx_gain() [2/2]
virtual double uhd::rfnoc::rf_control::core_iface::get_rx_gain ( const std::string &  name,
const size_t  chan
Return the receive gain name on channel chan
◆ get_rx_gain_names()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_rx_gain_names ( const size_t  chan) const
Return a list of valid RX gain names
◆ get_rx_gain_range() [1/2]
virtual uhd::gain_range_t uhd::rfnoc::rf_control::core_iface::get_rx_gain_range ( const size_t  chan) const
Return a range of valid RX gains
◆ get_rx_gain_range() [2/2]
virtual uhd::gain_range_t uhd::rfnoc::rf_control::core_iface::get_rx_gain_range ( const std::string &  name,
const size_t  chan
) const
◆ get_rx_lo_export_enabled()
virtual bool uhd::rfnoc::rf_control::core_iface::get_rx_lo_export_enabled ( const std::string &  name,
const size_t  chan
Returns true if the currently selected LO is being exported.
namethe name of the LO stage to query
chanthe channel index 0 to N-1
◆ get_rx_lo_freq()
virtual double uhd::rfnoc::rf_control::core_iface::get_rx_lo_freq ( const std::string &  name,
const size_t  chan
Get the current RX LO frequency (Advanced). If the channel does not have independently configurable LOs the current rf frequency will be returned.
the configured LO frequency
◆ get_rx_lo_freq_range()
virtual freq_range_t uhd::rfnoc::rf_control::core_iface::get_rx_lo_freq_range ( const std::string &  name,
const size_t  chan
) const
Get the LO frequency range of the RX LO. If the channel does not have independently configurable LOs the rf frequency range will be returned.
a frequency range object
◆ get_rx_lo_names()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_rx_lo_names ( const size_t  chan) const
Get a list of possible LO stage names
a vector of strings for possible LO names
◆ get_rx_lo_source()
virtual const std::string uhd::rfnoc::rf_control::core_iface::get_rx_lo_source ( const std::string &  name,
const size_t  chan
Get the currently set LO source. Channels without controllable LO sources will return "internal"
the configured LO source
◆ get_rx_lo_sources()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_rx_lo_sources ( const std::string &  name,
const size_t  chan
) const
Get a list of possible LO sources.
Channels which do not have controllable LO sources will return "internal".
a vector of strings for possible settings
◆ get_tx_antenna()
virtual std::string uhd::rfnoc::rf_control::core_iface::get_tx_antenna ( const size_t  chan) const
Return the selected TX antenna for channel chan.
◆ get_tx_antennas()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_tx_antennas ( const size_t  chan) const
Return a list of valid TX antenna for channel chan.
◆ get_tx_bandwidth()
virtual double uhd::rfnoc::rf_control::core_iface::get_tx_bandwidth ( const size_t  chan)
◆ get_tx_bandwidth_range()
virtual meta_range_t uhd::rfnoc::rf_control::core_iface::get_tx_bandwidth_range ( size_t  chan) const
Return a range of valid TX bandwidths
◆ get_tx_frequency()
virtual double uhd::rfnoc::rf_control::core_iface::get_tx_frequency ( const size_t  chan)
Return the current transmit LO frequency on channel chan.
◆ get_tx_frequency_range()
virtual uhd::freq_range_t uhd::rfnoc::rf_control::core_iface::get_tx_frequency_range ( const size_t  chan) const
The range of frequencies that we can tune the TX chan to
◆ get_tx_gain() [1/2]
virtual double uhd::rfnoc::rf_control::core_iface::get_tx_gain ( const size_t  chan)
Return the overall transmit gain on channel chan
◆ get_tx_gain() [2/2]
virtual double uhd::rfnoc::rf_control::core_iface::get_tx_gain ( const std::string &  name,
const size_t  chan
Return the transmit gain name on channel chan
◆ get_tx_gain_names()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_tx_gain_names ( const size_t  chan) const
Return a list of valid TX gain names
◆ get_tx_gain_range() [1/2]
virtual uhd::gain_range_t uhd::rfnoc::rf_control::core_iface::get_tx_gain_range ( const size_t  chan) const
Return a range of valid TX gains
◆ get_tx_gain_range() [2/2]
virtual uhd::gain_range_t uhd::rfnoc::rf_control::core_iface::get_tx_gain_range ( const std::string &  name,
const size_t  chan
) const
◆ get_tx_lo_export_enabled()
virtual bool uhd::rfnoc::rf_control::core_iface::get_tx_lo_export_enabled ( const std::string &  name,
const size_t  chan
◆ get_tx_lo_freq()
virtual double uhd::rfnoc::rf_control::core_iface::get_tx_lo_freq ( const std::string &  name,
const size_t  chan
Get the current TX LO frequency (Advanced).
See also multi_usrp::get_tx_lo_freq()
If the channel does not have independently configurable LOs the current RF frequency will be returned.
◆ get_tx_lo_freq_range()
virtual freq_range_t uhd::rfnoc::rf_control::core_iface::get_tx_lo_freq_range ( const std::string &  name,
const size_t  chan
Get the LO frequency range of the tx LO. If the channel does not have independently configurable LOs the rf frequency range will be returned.
◆ get_tx_lo_names()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_tx_lo_names ( const size_t  chan) const
◆ get_tx_lo_source()
virtual const std::string uhd::rfnoc::rf_control::core_iface::get_tx_lo_source ( const std::string &  name,
const size_t  chan
◆ get_tx_lo_sources()
virtual std::vector< std::string > uhd::rfnoc::rf_control::core_iface::get_tx_lo_sources ( const std::string &  name,
const size_t  chan
) const
◆ set_rx_agc()
virtual void uhd::rfnoc::rf_control::core_iface::set_rx_agc ( const bool  enable,
const size_t  chan
Enable RX AGC on this radio
Exceptions
uhd::not_implemented_errorif this radio doesn't support RX AGC
◆ set_rx_antenna()
virtual void uhd::rfnoc::rf_control::core_iface::set_rx_antenna ( const std::string &  ant,
const size_t  chan
Select RX antenna for channel chan.
Exceptions
uhd::value_errorif ant is not a valid value.
◆ set_rx_bandwidth()
virtual double uhd::rfnoc::rf_control::core_iface::set_rx_bandwidth ( const double  bandwidth,
const size_t  chan
Set the analog filter bandwidth channel chan
This function will attempt to set the analog bandwidth.
◆ set_rx_frequency()
virtual double uhd::rfnoc::rf_control::core_iface::set_rx_frequency ( const double  freq,
const size_t  chan
Tune the RX frequency for channel chan.
This function will attempt to tune as close as possible, and return a coerced value of the actual tuning result.
If there is a single LO in this radio, and we're doing direct conversion, then this is the LO frequency.
freqRequested frequency
chanChannel number.
The actual frequency.
◆ set_rx_gain() [1/2]
virtual double uhd::rfnoc::rf_control::core_iface::set_rx_gain ( const double  gain,
const size_t  chan
Set the overall receive gain on channel chan
This function will attempt to set the gain as close as possible, and return a coerced value of the actual gain value.
◆ set_rx_gain() [2/2]
const size_t  chan
Set the receive gain on channel chan
◆ set_rx_lo_export_enabled()
virtual void uhd::rfnoc::rf_control::core_iface::set_rx_lo_export_enabled ( bool  enabled,
const size_t  chan
Set whether the LO used by the usrp device is exported For usrps that support exportable LOs, this function configures if the LO used by chan is exported or not.
enabledif true then export the LO
namethe name of the LO stage to update
chanthe channel index 0 to N-1 for the source channel
◆ set_rx_lo_freq()
virtual double uhd::rfnoc::rf_control::core_iface::set_rx_lo_freq ( double  freq,
const size_t  chan
Set the RX LO frequency (Advanced).
freqthe frequency to set the LO to
a coerced LO frequency
◆ set_rx_lo_source()
virtual void uhd::rfnoc::rf_control::core_iface::set_rx_lo_source ( const std::string &  src,
const size_t  chan
Set the LO source for a channel. For usrps that support selectable LOs, this function allows switching between them. Typical options for source: internal, external.
srca string representing the LO source
◆ set_rx_tune_args()
virtual void uhd::rfnoc::rf_control::core_iface::set_rx_tune_args ( const uhd::device_addr_t args,
const size_t  chan
Set the TX tune args, if supported by the hardware.
◆ set_tx_antenna()
virtual void uhd::rfnoc::rf_control::core_iface::set_tx_antenna ( const std::string &  ant,
const size_t  chan
Exceptions
◆ set_tx_bandwidth()
virtual double uhd::rfnoc::rf_control::core_iface::set_tx_bandwidth ( const double  bandwidth,
const size_t  chan
◆ set_tx_frequency()
virtual double uhd::rfnoc::rf_control::core_iface::set_tx_frequency ( const double  freq,
size_t  chan
Tune the TX frequency for channel chan.
freqFrequency in Hz
chanChannel to tune
◆ set_tx_gain() [1/2]
virtual double uhd::rfnoc::rf_control::core_iface::set_tx_gain ( const double  gain,
const size_t  chan
Set the transmit gain on channel chan
This method will set the overall gain. To set a specific gain, use set_tx_gain(const double, const std::string&, const size_t).
◆ set_tx_gain() [2/2]
const size_t  chan
Set the transmit gain name on channel chan
◆ set_tx_lo_export_enabled()
virtual void uhd::rfnoc::rf_control::core_iface::set_tx_lo_export_enabled ( const bool  enabled,
const size_t  chan
◆ set_tx_lo_freq()
virtual double uhd::rfnoc::rf_control::core_iface::set_tx_lo_freq ( const double  freq,
const size_t  chan
Set the tx LO frequency (Advanced).
See also multi_usrp::set_tx_lo_freq().
◆ set_tx_lo_source()
virtual void uhd::rfnoc::rf_control::core_iface::set_tx_lo_source ( const std::string &  src,
const size_t  chan
◆ set_tx_tune_args()
virtual void uhd::rfnoc::rf_control::core_iface::set_tx_tune_args ( const uhd::device_addr_t args,
const size_t  chan
