uhd::rfnoc::switchboard_block_control Class Referenceabstract
#include <uhd/rfnoc/switchboard_block_control.hpp>
Inheritance diagram for uhd::rfnoc::switchboard_block_control:
virtual void connect (const size_t input, const size_t output)=0
static const uint32_t REG_DEMUX_SELECT_ADDR
static const uint32_t REG_MUX_SELECT_ADDR
Switchboard Block Control Class
The Switchboard Block is an RFNoC block that routes any single input to any single output. Routing is 1 to 1, that is, an input port can only be connected to one output port, and vice versa.
INIT: This block is initialized with only input port 0 connected to output port 0.
NOTE: This block is not intended to switch during the transmission of packets. Data on disconnected inputs will stall.
◆ connect()
virtual void uhd::rfnoc::switchboard_block_control::connect ( const size_t  input,
const size_t  output
Connects an input to an output
Bridges an input to an output. Any existing connections on either the input or output will be dropped.
inputIndex of the input port.
outputIndex of the output port.
◆ REG_BLOCK_SIZE
const uint32_t uhd::rfnoc::switchboard_block_control::REG_BLOCK_SIZE
◆ REG_DEMUX_SELECT_ADDR
const uint32_t uhd::rfnoc::switchboard_block_control::REG_DEMUX_SELECT_ADDR
◆ REG_MUX_SELECT_ADDR
const uint32_t uhd::rfnoc::switchboard_block_control::REG_MUX_SELECT_ADDR
