uhd::transport::usb_zero_copy Class Reference
#include <uhd/transport/usb_zero_copy.hpp>
Inheritance diagram for uhd::transport::usb_zero_copy:
uhd::transport::zero_copy_if
typedef std::shared_ptr< usb_zero_copysptr
- Public Types inherited from uhd::transport::zero_copy_if
typedef std::shared_ptr< zero_copy_ifsptr
 ~usb_zero_copy (void) override
- Public Member Functions inherited from uhd::transport::zero_copy_if
virtual ~zero_copy_if ()
static sptr make (usb_device_handle::sptr handle, const int recv_interface, const unsigned char recv_endpoint, const int send_interface, const unsigned char send_endpoint, const device_addr_t &hints=device_addr_t())
A zero copy USB transport provides an efficient way to handle data. by avoiding the extra copy when recv() or send() is called on the handle. Rather, the zero copy transport gives the caller memory references. The caller informs the transport when it is finished with the reference.
On Linux systems, the zero copy transport can use a kernel packet ring. If no platform specific solution is available, make returns a boost asio implementation that wraps functionality around standard send/recv calls.
◆ ~usb_zero_copy()
uhd::transport::usb_zero_copy::~usb_zero_copy ( void  )
override
◆ make()
static sptr uhd::transport::usb_zero_copy::make ( usb_device_handle::sptr  handle,
const device_addr_t hints = device_addr_t()
Make a new zero copy USB transport: This transport is for sending and receiving between the host and a pair of USB bulk transfer endpoints. The primary usage for this transport is data transactions. The underlying implementation may be platform specific.
handlea device handle that uniquely identifying the device
recv_interfacean integer specifying an IN interface number
recv_endpointan integer specifying an IN endpoint number
send_interfacean integer specifying an OUT interface number
send_endpointan integer specifying an OUT endpoint number
hintsoptional parameters to pass to the underlying transport
a new zero copy USB object
