uhd::usrp::cal::zbx_rx_dsa_cal Class Referenceabstract
#include <uhd/cal/dsa_cal.hpp>
Inheritance diagram for uhd::usrp::cal::zbx_rx_dsa_cal:
uhd::usrp::cal::container
using sptr = std::shared_ptr< zbx_rx_dsa_cal >
using step_settings = std::array< uint32_t, NUM_DSA >
virtual void add_frequency_band (const double max_freq, const std::string &name, std::array< step_settings, NUM_GAIN_STAGES > dsa_steps)=0
virtual bool is_same_band (double freq1, double freq2) const =0
virtual const step_settings get_dsa_setting (const double freq, const size_t gain_index) const =0
virtual std::vector< uint32_t > get_band_settings (double freq, uint8_t dsa) const =0
virtual void clear ()=0
- Public Member Functions inherited from uhd::usrp::cal::container
virtual ~container ()=default
virtual std::string get_name () const =0
 Return the name of this calibration table. More...
virtual std::string get_serial () const =0
 Return the device serial of this calibration table. More...
virtual uint64_t get_timestamp () const =0
 Timestamp of acquisition time. More...
virtual std::vector< uint8_t > serialize ()=0
 Return a serialized version of this container. More...
virtual void deserialize (const std::vector< uint8_t > &data)=0
 Populate this class from the serialized data. More...
static sptr make (const std::string &name, const std::string &serial, const uint64_t timestamp)
 Factory for new cal data sets. More...
static sptr make ()
 Default factory. More...
- Static Public Member Functions inherited from uhd::usrp::cal::container
template<typename container_type >
static std::shared_ptr< container_type > make (const std::vector< uint8_t > &data)
 Generic factory for cal data from serialized data. More...
static constexpr uint32_t NUM_DSA = 4
static constexpr uint32_t NUM_GAIN_STAGES = 61
Class that stores DSA indices for all ZBX TX bands.
◆ step_settings
◆ add_frequency_band()
virtual void uhd::usrp::cal::zbx_rx_dsa_cal::add_frequency_band ( const double  max_freq,
const std::string &  name,
std::array< step_settings, NUM_GAIN_STAGES dsa_steps
Add a new band description.
max_freq is the (inclusive) upper limit for the band (lower limit derives from the other bands). Name is an text representation (human readable) for the band. dsa_steps is an array of DSA settings for all gains in the band.
◆ clear()
virtual void uhd::usrp::cal::zbx_rx_dsa_cal::clear ( )
Clear all stored values
◆ get_band_settings()
virtual std::vector< uint32_t > uhd::usrp::cal::zbx_rx_dsa_cal::get_band_settings ( double  freq,
uint8_t  dsa
) const
Retrieves DSA settings as flat list. The values are flattend by frequency band, gain and values in that order. Use NUM_DSA and NUM_GAIN_STAGES to find values in the list.
◆ get_dsa_setting()
virtual const step_settings uhd::usrp::cal::zbx_rx_dsa_cal::get_dsa_setting ( const double  freq,
) const
Retrieves DSA settings for frequency and gain_index.
The settings are retrieved from the band with the biggest max_freq that is smaller or equal to freq. DSA settings are the settings at gain_index in that band. Value errors are thrown if freq is larger that the largest freq_max of all bands or gain_index is not within range.
◆ is_same_band()
virtual bool uhd::usrp::cal::zbx_rx_dsa_cal::is_same_band ( double  freq1,
double  freq2
) const
◆ make() [1/2]
static sptr uhd::usrp::cal::zbx_rx_dsa_cal::make ( )
Default factory.
◆ make() [2/2]
static sptr uhd::usrp::cal::zbx_rx_dsa_cal::make ( const std::string &  name,
const std::string &  serial,
◆ NUM_DSA
constexpr uint32_t uhd::usrp::cal::zbx_rx_dsa_cal::NUM_DSA = 4
staticconstexpr
◆ NUM_GAIN_STAGES
constexpr uint32_t uhd::usrp::cal::zbx_rx_dsa_cal::NUM_GAIN_STAGES = 61
staticconstexpr
