Loading [MathJax]/jax/output/HTML-CSS/config.js
uhd::rfnoc::blockdef Class Referenceabstract
#include <uhd/rfnoc/blockdef.hpp>
Inheritance diagram for uhd::rfnoc::blockdef:
Classes
class  arg_t
 Describes arguments in a block definition. More...
class  port_t
 Describes port options for a block definition. More...
typedef std::shared_ptr< blockdefsptr
typedef std::vector< port_tports_t
typedef std::vector< arg_targs_t
typedef uhd::dict< std::string, size_t > registers_t
virtual bool is_block () const =0
 Returns true if this represents a NoC block. More...
virtual bool is_component () const =0
 Returns true if this represents a component. More...
virtual std::string get_key () const =0
 Returns block key (i.e. what is used for the registry) More...
virtual std::string get_name () const =0
 For blocks, returns the block name. For components, returns it's canonical name. More...
virtual uint64_t noc_id () const =0
 Return the one NoC that is valid for this block. More...
virtual ports_t get_input_ports ()=0
virtual ports_t get_output_ports ()=0
virtual std::vector< size_t > get_all_port_numbers ()=0
 Returns the full list of port numbers used. More...
virtual args_t get_args ()=0
 Returns the args for this block. Checks if args are valid. More...
virtual registers_t get_settings_registers ()=0
 Returns a list of settings registers by name. More...
virtual registers_t get_readback_registers ()=0
 Returns a list of readback (user) registers by name. More...
static sptr make_from_noc_id (uint64_t noc_id)
Reads and stores block definitions for blocks and components.
◆ args_t
typedef std::vector<arg_t> uhd::rfnoc::blockdef::args_t
◆ ports_t
typedef std::vector<port_t> uhd::rfnoc::blockdef::ports_t
◆ registers_t
typedef uhd::dict<std::string, size_t> uhd::rfnoc::blockdef::registers_t
typedef std::shared_ptr<blockdef> uhd::rfnoc::blockdef::sptr
◆ get_all_port_numbers()
virtual std::vector< size_t > uhd::rfnoc::blockdef::get_all_port_numbers ( )
◆ get_args()
virtual args_t uhd::rfnoc::blockdef::get_args ( )
◆ get_input_ports()
virtual ports_t uhd::rfnoc::blockdef::get_input_ports ( )
◆ get_key()
virtual std::string uhd::rfnoc::blockdef::get_key ( ) const
◆ get_name()
virtual std::string uhd::rfnoc::blockdef::get_name ( ) const
◆ get_output_ports()
virtual ports_t uhd::rfnoc::blockdef::get_output_ports ( )
◆ get_readback_registers()
virtual registers_t uhd::rfnoc::blockdef::get_readback_registers ( )
◆ get_settings_registers()
virtual registers_t uhd::rfnoc::blockdef::get_settings_registers ( )
◆ is_block()
virtual bool uhd::rfnoc::blockdef::is_block ( ) const
◆ is_component()
virtual bool uhd::rfnoc::blockdef::is_component ( ) const
◆ make_from_noc_id()
static sptr uhd::rfnoc::blockdef::make_from_noc_id ( uint64_t  noc_id)
Create a block definition object for a NoC block given a NoC ID. This cannot be used for components.
Note: If nothing is found, returns an empty sptr. Does not throw.
◆ noc_id()
virtual uint64_t uhd::rfnoc::blockdef::noc_id ( ) const
