Describes port options for a block definition.
 More...
#include <uhd/rfnoc/blockdef.hpp>
|   | port_t () |
| bool  | is_variable (const std::string &key) const |
|   | Checks if the value at key is a variable (e.g. '$fftlen')  More...
| bool  | is_keyword (const std::string &key) const |
|   | Checks if the value at key is a keyword (e.g. 'vlen')  More...
| bool  | is_valid () const |
|   | Basic validity check of this port definition. Variables and.  More...
| std::string  | to_string () const |
|   | Returns a string with the most important keys.  More...
|   | dict (void) |
|   | dict (InputIterator first, InputIterator last) |
| std::size_t  | size (void) const |
| std::vector< std::string >  | keys (void) const |
| std::vector< std::string >  | vals (void) const |
| bool  | has_key (const std::string &key) const |
| const std::string &  | get (const std::string &key, const std::string &other) const |
| const std::string &  | get (const std::string &key) const |
| void  | set (const std::string &key, const std::string &val) |
| const std::string &  | operator[] (const std::string &key) const |
| std::string &  | operator[] (const std::string &key) |
| bool  | operator== (const dict< std::string, std::string > &other) const |
| bool  | operator!= (const dict< std::string, std::string > &other) const |
| std::string  | pop (const std::string &key) |
| void  | update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true) |
|   | operator std::map< std::string, std::string > () const |
◆ port_t()
          | uhd::rfnoc::blockdef::port_t::port_t  |
◆ is_keyword()
          | bool uhd::rfnoc::blockdef::port_t::is_keyword  |
          key | ) |
           const |
◆ is_valid()
          | bool uhd::rfnoc::blockdef::port_t::is_valid  |
           const |
◆ is_variable()
          | bool uhd::rfnoc::blockdef::port_t::is_variable  |
          key | ) |
           const |
◆ to_string()
          | std::string uhd::rfnoc::blockdef::port_t::to_string  |
           const |
◆ PORT_ARGS
A list of args a port can have.
