uhd::usrp_clock::multi_usrp_clock Class Referenceabstract
#include <uhd/usrp_clock/multi_usrp_clock.hpp>
Inheritance diagram for uhd::usrp_clock::multi_usrp_clock:
typedef std::shared_ptr< multi_usrp_clocksptr
virtual ~multi_usrp_clock (void)=0
virtual device::sptr get_device (void)=0
virtual std::string get_pp_string (void)=0
virtual size_t get_num_boards (void)=0
 Get the number of USRP Clocks in this configuration. More...
virtual uint32_t get_time (size_t board=0)=0
 Get time from device. More...
virtual sensor_value_t get_sensor (const std::string &name, size_t board=0)=0
virtual std::vector< std::string > get_sensor_names (size_t board=0)=0
static sptr make (const device_addr_t &dev_addr)
The Multi-USRP-Clock device class:
This class facilitates ease-of-use for must use-case scenarios when using clock devices with UHD. This class can be used with a single clock device or with multiple clock devices connected to the same host.
To create a multi_usrp_clock out of a single USRP Clock:
device_addr_t dev;
dev["addr"] = 192.168.10.3;
multi_usrp_clock::sptr clock = multi_usrp_clock::make(dev);
To create a multi_usrp_clock out of multiple clock devices:
device_addr_t dev;
dev["addr0"] = 192.168.10.3;
dev["addr1"] = 192.168.10.4;
◆ ~multi_usrp_clock()
virtual uhd::usrp_clock::multi_usrp_clock::~multi_usrp_clock ( void  )
◆ get_device()
virtual device::sptr uhd::usrp_clock::multi_usrp_clock::get_device ( void  )
Return the underlying device. This allows direct access to the EEPROM and sensors.
the device object within this Multi-USRP-Clock
◆ get_num_boards()
virtual size_t uhd::usrp_clock::multi_usrp_clock::get_num_boards ( void  )
◆ get_pp_string()
virtual std::string uhd::usrp_clock::multi_usrp_clock::get_pp_string ( void  )
Get a printable summary for this USRP Clock configuration.
a printable string
◆ get_sensor()
virtual sensor_value_t uhd::usrp_clock::multi_usrp_clock::get_sensor ( const std::string &  name,
size_t  board = 0
Get a USRP Clock sensor value.
namethe name of the sensor
boardthe board index (0 to M-1)
a sensor value object
◆ get_sensor_names()
virtual std::vector< std::string > uhd::usrp_clock::multi_usrp_clock::get_sensor_names ( size_t  board = 0)
Get a list of possible USRP Clock sensor names.
a vector of sensor names
◆ get_time()
virtual uint32_t uhd::usrp_clock::multi_usrp_clock::get_time ( size_t  board = 0)
◆ make()
static sptr uhd::usrp_clock::multi_usrp_clock::make ( const device_addr_t dev_addr)
Make a new Multi-USRP-Clock from the given device address.
dev_addrthe device address
a new Multi-USRP-Clock object
