uhd::rfnoc::moving_average_block_control Class Referenceabstract
#include <uhd/rfnoc/moving_average_block_control.hpp>
Inheritance diagram for uhd::rfnoc::moving_average_block_control:
virtual void set_sum_len (const uint8_t sum_len)=0
virtual uint8_t get_sum_len () const =0
virtual void set_divisor (const uint32_t divisor)=0
virtual uint32_t get_divisor () const =0
static const uint32_t REG_SUM_LEN_ADDR
static const uint32_t REG_DIVISOR_ADDR
Moving Average Block Control Class
The Moving Average block is an RFNoC block that computes the running average of an input data stream. The output is the sum of the last SUM_LEN samples divided by DIVISOR which may or may not be equal to SUM_LEN. For example, if SUM_LEN is set to 10 and DIVISOR is set to 10, the block will return a sample that is the average of the last 10 samples. If SUM_LEN is set to 10 and DIVISOR is set to 1, the block will return a sample that is equal to the sum of the last 10 samples.
◆ get_divisor()
virtual uint32_t uhd::rfnoc::moving_average_block_control::get_divisor ( ) const
Return the current divisor
The amount to divide the sum by
◆ get_sum_len()
virtual uint8_t uhd::rfnoc::moving_average_block_control::get_sum_len ( ) const
Return the current sum length
The number of samples to sum
◆ set_divisor()
virtual void uhd::rfnoc::moving_average_block_control::set_divisor ( const uint32_t  divisor)
Set the divisor
divisorThe amount to divide the sum by
◆ set_sum_len()
virtual void uhd::rfnoc::moving_average_block_control::set_sum_len ( const uint8_t  sum_len)
Set the Sum Length
Changing the sum length will clear the history and reset the accumulated sum to 0.
sum_lenThe number of samples to sum
◆ REG_DIVISOR_ADDR
const uint32_t uhd::rfnoc::moving_average_block_control::REG_DIVISOR_ADDR
◆ REG_SUM_LEN_ADDR
const uint32_t uhd::rfnoc::moving_average_block_control::REG_SUM_LEN_ADDR
