uhd::rfnoc::radio_control Class Referenceabstract
#include <uhd/rfnoc/radio_control.hpp>
Inheritance diagram for uhd::rfnoc::radio_control:
uhd::rfnoc::noc_block_base uhd::rfnoc::rf_control::core_iface uhd::rfnoc::rf_control::power_reference_iface uhd::features::discoverable_feature_getter_iface uhd::rfnoc::node_t uhd::rfnoc::register_iface_holder
virtual double set_rate (const double rate)=0
 Set the sample rate. More...
virtual double get_rate () const =0
 Get the sample rate. More...
virtual uhd::meta_range_t get_rate_range () const =0
 Return a list of valid rates. More...
virtual size_t get_spc () const =0
 Return the samples per clock (SPC) value of this radio. More...
virtual uint64_t get_ticks_now ()=0
virtual uhd::time_spec_t get_time_now ()=0
virtual std::vector< std::string > get_tx_gain_profile_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_gain_profile_names (const size_t chan) const =0
virtual void set_tx_gain_profile (const std::string &profile, const size_t chan)=0
virtual void set_rx_gain_profile (const std::string &profile, const size_t chan)=0
virtual std::string get_tx_gain_profile (const size_t chan) const =0
virtual std::string get_rx_gain_profile (const size_t chan) const =0
virtual void set_tx_dc_offset (const std::complex< double > &offset, size_t chan)=0
virtual meta_range_t get_tx_dc_offset_range (size_t chan) const =0
virtual void set_tx_iq_balance (const std::complex< double > &correction, size_t chan)=0
virtual void set_rx_dc_offset (const bool enb, size_t chan=ALL_CHANS)=0
virtual void set_rx_dc_offset (const std::complex< double > &offset, size_t chan)=0
virtual meta_range_t get_rx_dc_offset_range (size_t chan) const =0
virtual void set_rx_iq_balance (const bool enb, size_t chan)=0
virtual void set_rx_iq_balance (const std::complex< double > &correction, size_t chan)=0
virtual std::vector< std::string > get_gpio_banks () const =0
virtual void set_gpio_attr (const std::string &bank, const std::string &attr, const uint32_t value)=0
virtual uint32_t get_gpio_attr (const std::string &bank, const std::string &attr)=0
virtual std::vector< std::string > get_rx_sensor_names (size_t chan) const =0
virtual uhd::sensor_value_t get_rx_sensor (const std::string &name, size_t chan)=0
virtual std::vector< std::string > get_tx_sensor_names (size_t chan) const =0
virtual uhd::sensor_value_t get_tx_sensor (const std::string &name, size_t chan)=0
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port)=0
virtual void enable_rx_timestamps (const bool enable, const size_t chan)=0
virtual std::string get_slot_name () const =0
 Returns this radio's slot name (typically "A" or "B") More...
virtual size_t get_chan_from_dboard_fe (const std::string &fe, const uhd::direction_t direction) const =0
 Return the channel that corresponds to a frontend's name. More...
virtual std::string get_dboard_fe_from_chan (const size_t chan, const uhd::direction_t direction) const =0
 Return the frontend name for a channel index. More...
virtual std::string get_fe_name (const size_t chan, const uhd::direction_t direction) const =0
 Return the name of the frontend, as given by the dboard driver. More...
virtual void set_db_eeprom (const uhd::eeprom_map_t &db_eeprom)=0
 Update the daughterboard EEPROM. More...
virtual uhd::eeprom_map_t get_db_eeprom ()=0
 Return the content of the daughterboard EEPROM. More...
- Public Member Functions inherited from uhd::rfnoc::rf_control::core_iface
virtual ~core_iface ()=default
virtual std::string get_tx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_tx_antennas (const size_t chan) const =0
virtual void set_tx_antenna (const std::string &ant, const size_t chan)=0
virtual std::string get_rx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_rx_antennas (const size_t chan) const =0
virtual void set_rx_antenna (const std::string &ant, const size_t chan)=0
virtual double get_tx_frequency (const size_t chan)=0
virtual double set_tx_frequency (const double freq, size_t chan)=0
virtual void set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range (const size_t chan) const =0
virtual double get_rx_frequency (const size_t chan)=0
virtual double set_rx_frequency (const double freq, const size_t chan)=0
virtual void set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range (const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_tx_gain (const size_t chan)=0
virtual double get_tx_gain (const std::string &name, const size_t chan)=0
virtual double set_tx_gain (const double gain, const size_t chan)=0
virtual double set_tx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_rx_gain (const size_t chan)=0
virtual double get_rx_gain (const std::string &name, const size_t chan)=0
virtual double set_rx_gain (const double gain, const size_t chan)=0
virtual double set_rx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_agc (const bool enable, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan) const =0
virtual double get_tx_bandwidth (const size_t chan)=0
virtual double set_tx_bandwidth (const double bandwidth, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan) const =0
virtual double get_rx_bandwidth (const size_t chan)=0
virtual double set_rx_bandwidth (const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0
virtual void set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual const std::string get_rx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq (const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual const std::string get_tx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan)=0
- Public Member Functions inherited from uhd::rfnoc::rf_control::power_reference_iface
virtual ~power_reference_iface ()=default
virtual bool has_rx_power_reference (const size_t chan=0)=0
virtual void set_rx_power_reference (const double power_dbm, const size_t chan=0)=0
virtual double get_rx_power_reference (const size_t chan=0)=0
virtual std::vector< std::string > get_rx_power_ref_keys (const size_t chan=0)=0
virtual meta_range_t get_rx_power_range (const size_t chan)=0
virtual bool has_tx_power_reference (const size_t chan=0)=0
virtual void set_tx_power_reference (const double power_dbm, const size_t chan=0)=0
virtual double get_tx_power_reference (const size_t chan=0)=0
virtual std::vector< std::string > get_tx_power_ref_keys (const size_t chan=0)=0
virtual meta_range_t get_tx_power_range (const size_t chan)=0
- Public Member Functions inherited from uhd::features::discoverable_feature_getter_iface
virtual ~discoverable_feature_getter_iface ()=default
template<typename T >
T & get_feature ()
 Retrieves a feature of the specified type. More...
bool has_feature ()
 Determines whether a given feature exists. More...
virtual std::vector< std::string > enumerate_features ()=0
 Enumerate all discoverable features present on the device. More...
static const std::string ALL_LOS
static const std::string ALL_GAINS
static constexpr size_t ALL_CHANS = size_t(~0)
- Public Types inherited from uhd::rfnoc::rf_control::core_iface
using sptr = std::shared_ptr< core_iface >
- Public Types inherited from uhd::rfnoc::rf_control::power_reference_iface
using sptr = std::shared_ptr< power_reference_iface >
Parent class for radio block controllers
◆ enable_rx_timestamps()
virtual void uhd::rfnoc::radio_control::enable_rx_timestamps ( const bool  enable,
const size_t  chan
Enable or disable the setting of timestamps on Rx.
◆ get_chan_from_dboard_fe()
virtual size_t uhd::rfnoc::radio_control::get_chan_from_dboard_fe ( const std::string &  fe,
) const
◆ get_db_eeprom()
virtual uhd::eeprom_map_t uhd::rfnoc::radio_control::get_db_eeprom ( )
◆ get_dboard_fe_from_chan()
virtual std::string uhd::rfnoc::radio_control::get_dboard_fe_from_chan ( const size_t  chan,
) const
◆ get_fe_name()
virtual std::string uhd::rfnoc::radio_control::get_fe_name ( const size_t  chan,
) const
◆ get_gpio_attr()
virtual uint32_t uhd::rfnoc::radio_control::get_gpio_attr ( const std::string &  bank,
const std::string &  attr
Get a GPIO attribute on a particular GPIO bank. Possible attribute names:
  • CTRL - 1 for ATR mode 0 for GPIO mode
  • DDR - 1 for output 0 for input
  • OUT - GPIO output level (not ATR mode)
  • ATR_0X - ATR idle state
  • ATR_RX - ATR receive only state
  • ATR_TX - ATR transmit only state
  • ATR_XX - ATR full duplex state
  • READBACK - readback input GPIOs
    bankthe name of a GPIO bank
    attrthe name of a GPIO attribute
    the value set for this attribute
◆ get_gpio_banks()
virtual std::vector<std::string> uhd::rfnoc::radio_control::get_gpio_banks ( ) const
Returns the list of GPIO banks that are associated with this radio.
list of GPIO bank names
◆ get_rate()
virtual double uhd::rfnoc::radio_control::get_rate ( ) const
◆ get_rate_range()
virtual uhd::meta_range_t uhd::rfnoc::radio_control::get_rate_range ( ) const
◆ get_rx_dc_offset_range()
virtual meta_range_t uhd::rfnoc::radio_control::get_rx_dc_offset_range ( size_t  chan) const
Get the valid range for RX DC offset values.
chanthe channel index
◆ get_rx_gain_profile()
virtual std::string uhd::rfnoc::radio_control::get_rx_gain_profile ( const size_t  chan) const
Set the RX gain profile
◆ get_rx_gain_profile_names()
virtual std::vector<std::string> uhd::rfnoc::radio_control::get_rx_gain_profile_names ( const size_t  chan) const
Return a list of TX gain profiles for this radio
◆ get_rx_sensor()
virtual uhd::sensor_value_t uhd::rfnoc::radio_control::get_rx_sensor ( const std::string &  name,
size_t  chan
Return the sensor value for sensor name
nameSensor name (e.g. "lo_locked")
chanChannel index
Exceptions
uhd::key_errorif the sensor does not exist
◆ get_rx_sensor_names()
virtual std::vector<std::string> uhd::rfnoc::radio_control::get_rx_sensor_names ( size_t  chan) const
Return a list of RX sensors
The names returned in this list can be used as an input to get_rx_sensor()
◆ get_slot_name()
virtual std::string uhd::rfnoc::radio_control::get_slot_name ( ) const
◆ get_spc()
virtual size_t uhd::rfnoc::radio_control::get_spc ( ) const
◆ get_ticks_now()
virtual uint64_t uhd::rfnoc::radio_control::get_ticks_now ( )
Get tick count
tick count
Exceptions
uhd::not_implemented_errorif not implemented
◆ get_time_now()
virtual uhd::time_spec_t uhd::rfnoc::radio_control::get_time_now ( )
Get the time
time now
Exceptions
◆ get_tx_dc_offset_range()
virtual meta_range_t uhd::rfnoc::radio_control::get_tx_dc_offset_range ( size_t  chan) const
Get the valid range for TX DC offset values.
◆ get_tx_gain_profile()
virtual std::string uhd::rfnoc::radio_control::get_tx_gain_profile ( const size_t  chan) const
Return the TX gain profile
◆ get_tx_gain_profile_names()
virtual std::vector<std::string> uhd::rfnoc::radio_control::get_tx_gain_profile_names ( const size_t  chan) const
◆ get_tx_sensor()
virtual uhd::sensor_value_t uhd::rfnoc::radio_control::get_tx_sensor ( const std::string &  name,
size_t  chan
chanChannel index
Exceptions
◆ get_tx_sensor_names()
virtual std::vector<std::string> uhd::rfnoc::radio_control::get_tx_sensor_names ( size_t  chan) const
Return a list of TX sensors
The names returned in this list can be used as an input to get_tx_sensor()
◆ issue_stream_cmd()
virtual void uhd::rfnoc::radio_control::issue_stream_cmd ( const uhd::stream_cmd_t stream_cmd,
const size_t  port
Issue stream command: Instruct the RX part of the radio to send samples
When the radio is running at multiple samples per clock cycle, there are some restrictions in place:
  • When requesting a burst of length N, N must be an integer multiple of SPC. If it's not, the radio will round up to the next integer multiple.
  • When requesting a start time, the start time may be rounded down such that the first sample has a tick count value that is an integer multiple of SPC. That means the sample at the requested time will always be produced, but it might not be the first sample to be returned.
stream_cmdThe actual stream command to execute
portThe port for which the stream command is meant
◆ set_db_eeprom()
virtual void uhd::rfnoc::radio_control::set_db_eeprom ( const uhd::eeprom_map_t db_eeprom)
◆ set_gpio_attr()
virtual void uhd::rfnoc::radio_control::set_gpio_attr ( const std::string &  bank,
const std::string &  attr,
Set a GPIO attribute on a particular GPIO bank. Possible attribute names:
    bankthe name of a GPIO bank (e.g., FP0)
    attrthe name of a GPIO attribute (e.g., CTRL)
    valuethe new value for this GPIO bank
◆ set_rate()
virtual double uhd::rfnoc::radio_control::set_rate ( const double  rate)
◆ set_rx_dc_offset() [1/2]
virtual void uhd::rfnoc::radio_control::set_rx_dc_offset ( const bool  enb,
size_t  chan = ALL_CHANS
Enable/disable the automatic RX DC offset correction. The automatic correction subtracts out the long-run average.
When disabled, the averaging option operation is halted. Once halted, the average value will be held constant until the user re-enables the automatic correction or overrides the value by manually setting the offset.
enbtrue to enable automatic DC offset correction
◆ set_rx_dc_offset() [2/2]
virtual void uhd::rfnoc::radio_control::set_rx_dc_offset ( const std::complex< double > &  offset,
size_t  chan
Set a constant RX DC offset value.
The value is complex to control both I and Q. Only set this when automatic correction is disabled.
offsetthe dc offset (1.0 is full-scale)
chanthe channel index 0 to N-1
◆ set_rx_gain_profile()
virtual void uhd::rfnoc::radio_control::set_rx_gain_profile ( const std::string &  profile,
const size_t  chan
◆ set_rx_iq_balance() [1/2]
virtual void uhd::rfnoc::radio_control::set_rx_iq_balance ( const bool  enb,
size_t  chan
Enable/disable the automatic IQ imbalance correction.
enbtrue to enable automatic IQ balance correction
◆ set_rx_iq_balance() [2/2]
virtual void uhd::rfnoc::radio_control::set_rx_iq_balance ( const std::complex< double > &  correction,
size_t  chan
correctionthe complex correction (1.0 is full-scale)
◆ set_tx_dc_offset()
virtual void uhd::rfnoc::radio_control::set_tx_dc_offset ( const std::complex< double > &  offset,
size_t  chan
Set a constant TX DC offset value
◆ set_tx_gain_profile()
virtual void uhd::rfnoc::radio_control::set_tx_gain_profile ( const std::string &  profile,
const size_t  chan
Set the TX gain profile
◆ set_tx_iq_balance()
virtual void uhd::rfnoc::radio_control::set_tx_iq_balance ( const std::complex< double > &  correction,
size_t  chan
Set the TX frontend IQ imbalance correction.
Use this to adjust the magnitude and phase of I and Q.
◆ ALL_CHANS
constexpr size_t uhd::rfnoc::radio_control::ALL_CHANS = size_t(~0)
staticconstexpr
◆ ALL_GAINS
const std::string uhd::rfnoc::radio_control::ALL_GAINS
◆ ALL_LOS
const std::string uhd::rfnoc::radio_control::ALL_LOS
