uhd::rfnoc::replay_block_control Class Referenceabstract
#include <uhd/rfnoc/replay_block_control.hpp>
Inheritance diagram for uhd::rfnoc::replay_block_control:
virtual void record (const uint64_t offset, const uint64_t size, const size_t port=0)=0
virtual void record_restart (const size_t port=0)=0
virtual void play (const uint64_t offset, const uint64_t size, const size_t port=0, const uhd::time_spec_t time_spec=uhd::time_spec_t(0.0), const bool repeat=false)=0
virtual void stop (const size_t port=0)=0
virtual uint64_t get_mem_size () const =0
virtual uint64_t get_word_size () const =0
virtual uint64_t get_record_offset (const size_t port=0) const =0
virtual uint64_t get_record_size (const size_t port=0) const =0
virtual uint64_t get_record_fullness (const size_t port=0)=0
virtual uint64_t get_record_position (const size_t port=0)=0
virtual io_type_t get_record_type (const size_t port=0) const =0
virtual size_t get_record_item_size (const size_t port=0) const =0
virtual bool get_record_async_metadata (uhd::rx_metadata_t &metadata, const double timeout=0.1)=0
virtual uint64_t get_play_offset (const size_t port=0) const =0
virtual uint64_t get_play_size (const size_t port=0) const =0
virtual uint64_t get_play_position (const size_t port=0)=0
virtual uint32_t get_max_items_per_packet (const size_t port=0) const =0
virtual uint32_t get_max_packet_size (const size_t port=0) const =0
virtual io_type_t get_play_type (const size_t port=0) const =0
virtual size_t get_play_item_size (const size_t port=0) const =0
virtual bool get_play_async_metadata (uhd::async_metadata_t &metadata, const double timeout=0.1)=0
virtual void set_record_type (const io_type_t type, const size_t port=0)=0
virtual void config_play (const uint64_t offset, const uint64_t size, const size_t port=0)=0
virtual void set_play_type (const io_type_t type, const size_t port=0)=0
virtual void set_max_items_per_packet (const uint32_t ipp, const size_t port=0)=0
virtual void set_max_packet_size (const uint32_t size, const size_t port=0)=0
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port=0)=0
static const uint32_t REPLAY_ADDR_W
static const uint32_t REPLAY_BLOCK_OFFSET
static const uint32_t REG_COMPAT_ADDR
static const uint32_t REG_MEM_SIZE_ADDR
static const uint32_t REG_REC_RESTART_ADDR
static const uint32_t REG_REC_BASE_ADDR_LO_ADDR
static const uint32_t REG_REC_BASE_ADDR_HI_ADDR
static const uint32_t REG_REC_BUFFER_SIZE_LO_ADDR
static const uint32_t REG_REC_BUFFER_SIZE_HI_ADDR
static const uint32_t REG_REC_FULLNESS_LO_ADDR
static const uint32_t REG_REC_FULLNESS_HI_ADDR
static const uint32_t REG_PLAY_BASE_ADDR_LO_ADDR
static const uint32_t REG_PLAY_BASE_ADDR_HI_ADDR
static const uint32_t REG_PLAY_BUFFER_SIZE_LO_ADDR
static const uint32_t REG_PLAY_BUFFER_SIZE_HI_ADDR
static const uint32_t REG_PLAY_CMD_NUM_WORDS_LO_ADDR
static const uint32_t REG_PLAY_CMD_NUM_WORDS_HI_ADDR
static const uint32_t REG_PLAY_CMD_TIME_LO_ADDR
static const uint32_t REG_PLAY_CMD_TIME_HI_ADDR
static const uint32_t REG_PLAY_CMD_ADDR
static const uint32_t REG_PLAY_WORDS_PER_PKT_ADDR
static const uint32_t REG_PLAY_ITEM_SIZE_ADDR
static const uint32_t REG_REC_POS_LO_ADDR
static const uint32_t REG_REC_POS_HI_ADDR
static const uint32_t REG_PLAY_POS_LO_ADDR
static const uint32_t REG_PLAY_POS_HI_ADDR
static const uint32_t REG_PLAY_CMD_FIFO_SPACE_ADDR
static const uint32_t PLAY_CMD_STOP
static const uint32_t PLAY_CMD_FINITE
static const uint32_t PLAY_CMD_CONTINUOUS
Replay Block Control CLass
The Replay block records data to memory and plays back data from memory.
It is the responsibility of the user to manage the memory. Care must be taken to avoid unintentional overlaps in the memory across blocks and ports. Each port of the Replay block has access to the full memory space. This allows recording data on any input port of any Replay block and playback on any output port of any Replay block. The section of memory used by a record or play operation is controlled by setting the offset and size.
For both record and playback, the offset and the size must be aligned to the memory's word size. For playback, the size must also be aligned to the size of an item. An item is a single unit of data as defined by the data type of a port. For record, the data type is automatically determined by the connection to the upstream block by using the "type" edge property for the corresponding input port. For playback, this is automatically determined by the connection to the downstream block by using the "type" edge property for the corresponding output port. These can be explicitly set by the user, if necessary. It is the user's responsibility to manage the types of the individual record and the playback ports. Methods to get the word size and item sizes are provided to help calculate proper alignment.
One key configuration of playback is the packet size. Larger packet sizes provide for better throughput while smaller packet sizes provide for lower latency. By default, the "mtu" edge property of the output port is used to define the maximum packet size to achieve the best throughput to the downstream block without exceeding the supported packet size. The maximum packet size can be explicitly set in terms of bytes or number of items to allow users to tune the performance to suit their application.
Block Properties
User Properties:
Key Description
record_offset The base address for recordings (data will be written here). Will be set by record().
record_size Size of the record buffer. Will be set by record().
play_offset Base address for playback (streaming will start from here). Set by play() or config_play().
play_size Size of the playback buffer. Set by play() or config_play().
packet_size Size of outgoing packets (in bytes). Gets set by set_max_items_per_packet().
Edge properties:
Key Description
type Data type. On the input, it set by the upstream block (see get_record_type()). For output, it should be provided by set_play_type().
Recording Data
Before streaming data to the replay block, it must be configured to record by calling record(), which will also configure the size of the record buffer for the indicated input port. After calling this method, the block will accept incoming data until its record buffer is full (use the get_record_fullness() method to query the fullness). Unlike the radio, the replay block does not care about end-of-burst flags, and will not report underruns if subsequent packets are not streamed to this block back-to-back.
Once the record buffer is full, the block will no longer accept incoming data and will back-pressure. If, for example, the radio block is connected to the replay block, the radio could overrun in this scenario. By calling record() again, the write-pointer of the block is reset, and it will accept new data. To reset the write-pointer and buffer size to the same values as before, it is sufficient to call record_restart().
Playing back Data
To playback data from a given port, there are two options with basically the same functionality: Either call config_play() to configure the playback region on memory, and then call issue_stream_cmd() to start streaming.
A shorthand version of this is to call play(), which is equivalent to calling config_play() and issue_stream_cmd() together.
In either case, the replay block will start streaming the requested number of samples, or until it is stopped. If a specific number of samples is requested, then it will tag the last outgoing packet with an end-of-burst flag. If more samples were requested than stored in the playback buffer, it will wrap around.
To stop a continuous playback, either call stop(), or issue a stream command with uhd::stream_cmd_t::STREAM_MODE_STOP_CONTINUOUS.
Action Handling
If this block receives TX or RX actions (uhd::rfnoc::tx_event_action_info o uhd::rfnoc::rx_event_action_info), it will store them in a circular buffer. The API calls get_record_async_metadata() and get_play_async_metadata() can be used to read them back out asynchronously. To avoid the block controller continously expanding in memory, the total number of messages that will be stored is limited. If this block receives more event info objects than it can store before get_record_async_metadata() or get_play_async_metadata() is called, the oldest message will be dropped.
◆ config_play()
virtual void uhd::rfnoc::replay_block_control::config_play ( const uint64_t  offset,
const size_t  port = 0
Configure the offsets and size of the playback buffer region
Specifies a buffer area in the memory for playback. In order to begin playback on this region, a stream command must be issued.
offsetMemory offset of the data to be played. This value must be aligned to the size of the word in memory. Use get_word_size() to get the memory word size.
sizeSize of data to play back. This value must be aligned to the size of the memory word and item size. Use get_word_size() to get the memory word size and get_output_item_size() to get the item size.
portWhich output port of the replay block to use
Exceptions
uhd::value_errorif offset+size exceeds the available memory.
◆ get_max_items_per_packet()
virtual uint32_t uhd::rfnoc::replay_block_control::get_max_items_per_packet ( const size_t  port = 0) const
Get the maximum number of items in a packet
◆ get_max_packet_size()
virtual uint32_t uhd::rfnoc::replay_block_control::get_max_packet_size ( const size_t  port = 0) const
Get the maximum size of a packet
Returns the maximum size of a packet, inclusive of headers and payload.
◆ get_mem_size()
virtual uint64_t uhd::rfnoc::replay_block_control::get_mem_size ( ) const
Get the size of the memory
Returns the size of the shared memory space. Any record or playback buffers must be configured in this memory space.
the size of the shared Replay memory
◆ get_play_async_metadata()
virtual bool uhd::rfnoc::replay_block_control::get_play_async_metadata ( uhd::async_metadata_t metadata,
const double  timeout = 0.1
Return TX- (output-/playback-) related metadata.
The typical use case for this is when connecting Replay -> Radio for playback, the radio may produce information like 'underrun occurred'. When transmitting from a host using a uhd::tx_streamer, this information is returned as part of the uhd::tx_streamer::recv_async_msg() call, but when the data is streamed into the replay block, these metadata are stored inside the replay block until queried by this method.
metadataA metadata object to store the information in.
timeoutA timeout (in seconds) to wait before returning.
true if a message was available, and was popped into metadata.
◆ get_play_item_size()
virtual size_t uhd::rfnoc::replay_block_control::get_play_item_size ( const size_t  port = 0) const
Get the current play item size
the size of an item in the current play buffer
◆ get_play_offset()
virtual uint64_t uhd::rfnoc::replay_block_control::get_play_offset ( const size_t  port = 0) const
Get the offset of the current playback buffer
◆ get_play_position()
virtual uint64_t uhd::rfnoc::replay_block_control::get_play_position ( const size_t  port = 0)
Get the current playback position
the byte address of the current playback position
◆ get_play_size()
virtual uint64_t uhd::rfnoc::replay_block_control::get_play_size ( const size_t  port = 0) const
Get the current size of the playback space
◆ get_play_type()
virtual io_type_t uhd::rfnoc::replay_block_control::get_play_type ( const size_t  port = 0) const
Get the current play data type
◆ get_record_async_metadata()
virtual bool uhd::rfnoc::replay_block_control::get_record_async_metadata ( uhd::rx_metadata_t metadata,
Return RX- (input-/record-) related metadata.
The typical use case for this is when connecting Radio -> Replay for recording, the radio may produce information like 'overrun occurred'. When receiving to a host using a uhd::rx_streamer, this information is returned as part of the uhd::rx_streamer::recv() call, but when the data is streamed into the replay block, these metadata are stored inside the replay block until queried by this method.
◆ get_record_fullness()
virtual uint64_t uhd::rfnoc::replay_block_control::get_record_fullness ( const size_t  port = 0)
Get the fullness of the current record buffer
Returns the number of bytes that have been recorded in the record buffer. A record restart will reset this number back to 0.
portWhich input port of the replay block to use
fullness of the record buffer
◆ get_record_item_size()
virtual size_t uhd::rfnoc::replay_block_control::get_record_item_size ( const size_t  port = 0) const
Get the current record item size
the size of an item in the current record buffer
◆ get_record_offset()
virtual uint64_t uhd::rfnoc::replay_block_control::get_record_offset ( const size_t  port = 0) const
Get the starting offset of the current record buffer
starting offset of the record buffer
◆ get_record_position()
virtual uint64_t uhd::rfnoc::replay_block_control::get_record_position ( const size_t  port = 0)
Get the current record position
the byte address of the current record position
◆ get_record_size()
virtual uint64_t uhd::rfnoc::replay_block_control::get_record_size ( const size_t  port = 0) const
Get the current size of the record space
◆ get_record_type()
virtual io_type_t uhd::rfnoc::replay_block_control::get_record_type ( const size_t  port = 0) const
Get the current record data type
◆ get_word_size()
virtual uint64_t uhd::rfnoc::replay_block_control::get_word_size ( ) const
Get the size of a memory word
◆ issue_stream_cmd()
virtual void uhd::rfnoc::replay_block_control::issue_stream_cmd ( const uhd::stream_cmd_t stream_cmd,
Issue a stream command to the replay block
Issue stream commands to start or stop playback from the configured playback buffer. Supports STREAM_MODE_START_CONTINUOUS to start continuous repeating playback, STREAM_MODE_NUM_SAMPS_AND_DONE to play the given number of samples once, and STREAM_MODE_STOP_CONTINUOUS to stop all playback immediately. If a time_spec is supplied, it is placed in the header of the first packet produced for that command. Commands are queued and executed in order. A STREAM_MODE_STOP_CONTINUOUS command will halt all playback and purge all commands in the queue for a given output port.
stream_cmdThe command to execute
Exceptions
uhd::op_failedToo many commands are queued.
◆ play()
virtual void uhd::rfnoc::replay_block_control::play ( const uint64_t  offset,
const size_t  port = 0,
const uhd::time_spec_t  time_spec = uhd::time_spec_t(0.0),
const bool  repeat = false
Play back data.
The offset and size define what data is played back on an output port. It will stream out size bytes of data, starting at memory offset offset.
The data can be played once or repeated continuously until a stop command is issued. If a time_spec is supplied, it will be placed in the header of the first packet. Typically, this is used to tell a downstream Radio block when to start transmitting the data.
If the data type on the output port is not defined, this function will throw an error.
This is equivalent to calling config_play() with the same arguments for offset, size, and port, and then calling issue_stream_cmd() with the same time spec, and either continuous streaming (if repeat is true) or STREAM_MODE_START_NUM_SAMPS_AND_DONE if it is not.
sizeSize of data to play back. This value must be aligned to the size of the memory word and item size. Use get_word_size() to get the memory word size and get_output_item_size() to get the item size. This value will be used for the num_samps component of the underlying stream command.
time_specSet the time for the first item. Any non-zero value is used to set the time in the header of the first packet. Most commonly, this is used to set the start time of a transmission. Note that this block will not wait for a time to occur, rather, it will tag the first outgoing packet with this time stamp.
repeatDetermines whether the data should be played repeatedly or just once. If set to true, stop() must be called to stop the play back.
Exceptions
uhd::op_failedToo many play commands are queued.
◆ record()
virtual void uhd::rfnoc::replay_block_control::record ( const uint64_t  offset,
Record
Begin recording. The offset sets the starting location in memory and the size limits the length of the recording. The flow of data is controlled by upstream RFNoC blocks.
offsetMemory offset where to start recording the data. This value must be aligned to the memory word size. Use get_word_size() to get the size of the memory word.
sizeSize limit, in bytes. This value must be aligned to the memory word size and the item size. Use get_word_size() to get the size of the memory word and get_item_size() to get the item size. A value of 0 means to use all available space.
Exceptions
◆ record_restart()
virtual void uhd::rfnoc::replay_block_control::record_restart ( const size_t  port = 0)
Restarts recording from the record offset
This is a shortcut for calling record() again with the same arguments.
◆ set_max_items_per_packet()
virtual void uhd::rfnoc::replay_block_control::set_max_items_per_packet ( const uint32_t  ipp,
Set the maximum number of items in a packet
Sets the maximum number of items that can be in a packet's payload. An actual packet may be smaller in order to coerce to mtu values, or to align with memory word size.
ippNumber of items per packet
◆ set_max_packet_size()
virtual void uhd::rfnoc::replay_block_control::set_max_packet_size ( const uint32_t  size,
Set the maximum size of a packet
Sets the maximum packet size, inclusive of headers and payload. Cannot exceed the MTU for this block.
sizeThe size of the packet
◆ set_play_type()
virtual void uhd::rfnoc::replay_block_control::set_play_type ( const io_type_t  type,
Explicitly set the current play data type
Sets the data type for items in the current play buffer for the given output port.
typeThe data type
◆ set_record_type()
virtual void uhd::rfnoc::replay_block_control::set_record_type ( const io_type_t  type,
Explicitly set the current record data type
Sets the data type for items in the current record buffer for the given input port.
typeThe data type
◆ stop()
virtual void uhd::rfnoc::replay_block_control::stop ( const size_t  port = 0)
Stops playback
Halts any currently executing play commands and cancels any other play commands that are waiting to be executed for that output port.
◆ MAJOR_COMPAT
const uint16_t uhd::rfnoc::replay_block_control::MAJOR_COMPAT
◆ MINOR_COMPAT
const uint16_t uhd::rfnoc::replay_block_control::MINOR_COMPAT
◆ PLAY_CMD_CONTINUOUS
const uint32_t uhd::rfnoc::replay_block_control::PLAY_CMD_CONTINUOUS
◆ PLAY_CMD_FINITE
const uint32_t uhd::rfnoc::replay_block_control::PLAY_CMD_FINITE
◆ PLAY_CMD_STOP
const uint32_t uhd::rfnoc::replay_block_control::PLAY_CMD_STOP
◆ REG_COMPAT_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_COMPAT_ADDR
◆ REG_MEM_SIZE_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_MEM_SIZE_ADDR
◆ REG_PLAY_BASE_ADDR_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_BASE_ADDR_HI_ADDR
◆ REG_PLAY_BASE_ADDR_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_BASE_ADDR_LO_ADDR
◆ REG_PLAY_BUFFER_SIZE_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_BUFFER_SIZE_HI_ADDR
◆ REG_PLAY_BUFFER_SIZE_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_BUFFER_SIZE_LO_ADDR
◆ REG_PLAY_CMD_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_ADDR
◆ REG_PLAY_CMD_FIFO_SPACE_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_FIFO_SPACE_ADDR
◆ REG_PLAY_CMD_NUM_WORDS_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_NUM_WORDS_HI_ADDR
◆ REG_PLAY_CMD_NUM_WORDS_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_NUM_WORDS_LO_ADDR
◆ REG_PLAY_CMD_TIME_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_TIME_HI_ADDR
◆ REG_PLAY_CMD_TIME_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_CMD_TIME_LO_ADDR
◆ REG_PLAY_ITEM_SIZE_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_ITEM_SIZE_ADDR
◆ REG_PLAY_POS_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_POS_HI_ADDR
◆ REG_PLAY_POS_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_POS_LO_ADDR
◆ REG_PLAY_WORDS_PER_PKT_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_PLAY_WORDS_PER_PKT_ADDR
◆ REG_REC_BASE_ADDR_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_BASE_ADDR_HI_ADDR
◆ REG_REC_BASE_ADDR_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_BASE_ADDR_LO_ADDR
◆ REG_REC_BUFFER_SIZE_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_BUFFER_SIZE_HI_ADDR
◆ REG_REC_BUFFER_SIZE_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_BUFFER_SIZE_LO_ADDR
◆ REG_REC_FULLNESS_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_FULLNESS_HI_ADDR
◆ REG_REC_FULLNESS_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_FULLNESS_LO_ADDR
◆ REG_REC_POS_HI_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_POS_HI_ADDR
◆ REG_REC_POS_LO_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_POS_LO_ADDR
◆ REG_REC_RESTART_ADDR
const uint32_t uhd::rfnoc::replay_block_control::REG_REC_RESTART_ADDR
◆ REPLAY_ADDR_W
const uint32_t uhd::rfnoc::replay_block_control::REPLAY_ADDR_W
◆ REPLAY_BLOCK_OFFSET
const uint32_t uhd::rfnoc::replay_block_control::REPLAY_BLOCK_OFFSET
