11 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
   12 #define UHD_USRP_MULTI_USRP_GET_RATES_API
   13 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
   14 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
   15 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
   16 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
   17 #define UHD_USRP_MULTI_USRP_USER_REGS_API
   18 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
   19 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
   20 #define UHD_USRP_MULTI_USRP_GPIO_API
   21 #define UHD_USRP_MULTI_USRP_REGISTER_API
   22 #define UHD_USRP_MULTI_USRP_FILTER_API
   23 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
   24 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
   25 #define UHD_USRP_MULTI_USRP_POWER_LEVEL
   47 namespace uhd {
namespace usrp {
   98     typedef std::shared_ptr<multi_usrp>
sptr;
  193     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
  200     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
  220     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
  226     virtual std::string get_pp_string(
void) = 0;
  233     virtual std::string get_mboard_name(
  240     virtual time_spec_t get_time_now(
  247     virtual time_spec_t get_time_last_pps(
  260     virtual void set_time_now(
  261         const time_spec_t& time_spec,
  275     virtual void set_time_next_pps(
  276         const time_spec_t& time_spec,
  293     virtual void set_time_unknown_pps(
const time_spec_t& time_spec) = 0;
  301     virtual bool get_time_synchronized(
void) = 0;
  313     virtual void set_command_time(
  321     virtual void clear_command_time(
  335     virtual void issue_stream_cmd(
  336         const stream_cmd_t& stream_cmd,
size_t chan = ALL_CHANS) = 0;
  380     virtual void set_time_source(
  381         const std::string&
source,
const size_t mboard = ALL_MBOARDS) = 0;
  388     virtual std::string get_time_source(
const size_t mboard) = 0;
  395     virtual std::vector<std::string> get_time_sources(
  439     virtual void set_clock_source(
  440         const std::string&
source,
  447     virtual std::string get_clock_source(
  454     virtual std::vector<std::string> get_clock_sources(
  466     virtual void set_sync_source(
const std::string& clock_source,
  467         const std::string& time_source,
  468         const size_t mboard = ALL_MBOARDS) = 0;
  492     virtual void set_sync_source(
  493         const device_addr_t& sync_source,
  500     virtual device_addr_t get_sync_source(
  507     virtual std::vector<device_addr_t> get_sync_sources(
  523     virtual void set_clock_source_out(
  524         const bool enb,
  540     virtual void set_time_source_out(
  541         const bool enb,
  546     virtual size_t get_num_mboards(
void) = 0;
  555         const std::string& name,
  562     virtual std::vector<std::string> get_mboard_sensor_names(
  573     virtual void set_user_register(
  574         const uint8_t addr,
const uint32_t data,
  640     template <
typename T>
  643         return std::dynamic_pointer_cast<T>(get_extension(trx, chan));
  659     virtual void set_rx_subdev_spec(
  674     virtual size_t get_rx_num_channels(
void) = 0;
  681     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
  692     virtual void set_rx_rate(
double rate,
  703     virtual void set_rx_spp(
const size_t spp,
const size_t chan = ALL_CHANS) = 0;
  710     virtual double get_rx_rate(
  737     virtual double get_rx_freq(
  748     virtual freq_range_t get_rx_freq_range(
  755     virtual freq_range_t get_fe_rx_freq_range(
  773     virtual std::vector<std::string> get_rx_lo_names(
  793     virtual void set_rx_lo_source(
  794         const std::string& src,
const std::string& name = ALL_LOS,
  804     virtual const std::string get_rx_lo_source(
  805         const std::string& name = ALL_LOS,
  819     virtual std::vector<std::string> get_rx_lo_sources(
  820         const std::string& name = ALL_LOS,
  832     virtual void set_rx_lo_export_enabled(
  833         bool enabled,
  840     virtual bool get_rx_lo_export_enabled(
  841         const std::string& name = ALL_LOS,
  867     virtual double set_rx_lo_freq(
  868         double freq,
  880     virtual double get_rx_lo_freq(
  892         const std::string& name,
  906     virtual std::vector<std::string> get_tx_lo_names(
  923     virtual void set_tx_lo_source(
  924         const std::string& name = ALL_LOS,
  925         const size_t chan       = 0) = 0;
  935     virtual const std::string get_tx_lo_source(
  936         const std::string& name = ALL_LOS,
  948     virtual std::vector<std::string> get_tx_lo_sources(
  949         const std::string& name = ALL_LOS,
  961     virtual void set_tx_lo_export_enabled(
  962         const bool enabled,
  969     virtual bool get_tx_lo_export_enabled(
  970         const std::string& name = ALL_LOS,
  996     virtual double set_tx_lo_freq(
  997         const double freq,
 1009     virtual double get_tx_lo_freq(
 1021         const std::string& name,
 1039     virtual void set_rx_gain(
double gain,
 1053     virtual std::vector<std::string> get_rx_gain_profile_names(
 1063     virtual void set_rx_gain_profile(
 1064         const std::string& profile,
 1071     virtual std::string get_rx_gain_profile(
 1076         return this->set_rx_gain(gain, ALL_GAINS, chan);
 1096     virtual void set_normalized_rx_gain(
double gain,
 1115     virtual void set_rx_agc(
bool enable,
 1124     virtual double get_rx_gain(
 1129         return this->get_rx_gain(ALL_GAINS, chan);
 1142     virtual double get_normalized_rx_gain(
 1151     virtual gain_range_t get_rx_gain_range(
 1156         return this->get_rx_gain_range(ALL_GAINS, chan);
 1165     virtual std::vector<std::string> get_rx_gain_names(
 1175     virtual void set_rx_antenna(
const std::string& ant,
 1182     virtual std::string get_rx_antenna(
 1189     virtual std::vector<std::string> get_rx_antennas(
 1200     virtual void set_rx_bandwidth(
double bandwidth,
 1207     virtual double get_rx_bandwidth(
 1214     virtual meta_range_t get_rx_bandwidth_range(
 1231     virtual sensor_value_t get_rx_sensor(
 1238     virtual std::vector<std::string> get_rx_sensor_names(
 1252     virtual void set_rx_dc_offset(
const bool enb,
 1261     virtual void set_rx_dc_offset(
 1262         const std::complex<double>& offset,
 1268     virtual meta_range_t get_rx_dc_offset_range(
 1276     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
 1285     virtual void set_rx_iq_balance(
 1286         const std::complex<double>& correction,
 1308     virtual bool has_rx_power_reference(
 1324     virtual void set_rx_power_reference(
 1325         const double power_dbm,
 1339     virtual double get_rx_power_reference(
 1350     virtual meta_range_t get_rx_power_range(
const size_t chan) = 0;
 1364     virtual void set_tx_subdev_spec(
 1379     virtual size_t get_tx_num_channels(
void) = 0;
 1386     virtual std::string get_tx_subdev_name(
 1397     virtual void set_tx_rate(
double rate,
 1404     virtual double get_tx_rate(
 1411     virtual meta_range_t get_tx_rates(
 1431     virtual double get_tx_freq(
 1442     virtual freq_range_t get_tx_freq_range(
 1449     virtual freq_range_t get_fe_tx_freq_range(
 1464     virtual void set_tx_gain(
double gain,
 1478     virtual std::vector<std::string> get_tx_gain_profile_names(
 1488     virtual void set_tx_gain_profile(
 1489         const std::string& profile,
 1496     virtual std::string get_tx_gain_profile(
 1501         return this->set_tx_gain(gain, ALL_GAINS, chan);
 1516     virtual void set_normalized_tx_gain(
double gain,
 1525     virtual double get_tx_gain(
 1530         return this->get_tx_gain(ALL_GAINS, chan);
 1543     virtual double get_normalized_tx_gain(
 1552     virtual gain_range_t get_tx_gain_range(
 1557         return this->get_tx_gain_range(ALL_GAINS, chan);
 1566     virtual std::vector<std::string> get_tx_gain_names(
 1587     virtual bool has_tx_power_reference(
 1603     virtual void set_tx_power_reference(
 1604         const double power_dbm,
 1618     virtual double get_tx_power_reference(
 1629     virtual meta_range_t get_tx_power_range(
 1639     virtual void set_tx_antenna(
 1646     virtual std::string get_tx_antenna(
 1653     virtual std::vector<std::string> get_tx_antennas(
 1664     virtual void set_tx_bandwidth(
double bandwidth,
 1671     virtual double get_tx_bandwidth(
 1678     virtual meta_range_t get_tx_bandwidth_range(
 1695     virtual sensor_value_t get_tx_sensor(
 1702     virtual std::vector<std::string> get_tx_sensor_names(
 1710     virtual void set_tx_dc_offset(
 1711         const std::complex<double>& offset,
 1717     virtual meta_range_t get_tx_dc_offset_range(
 1726     virtual void set_tx_iq_balance(
 1727         const std::complex<double>& correction,
 1738     virtual std::vector<std::string> get_gpio_banks(
 1792     virtual void set_gpio_attr(
const std::string& bank,
 1793         const std::string& attr,
 1794         const uint32_t value,
 1795         const uint32_t
mask = 0xffffffff,
 1796         const size_t mboard = 0) = 0;
 1817     virtual uint32_t get_gpio_attr(
 1818         const std::string& bank,
 1836     virtual std::vector<std::string> get_gpio_src_banks(
 1848     virtual std::vector<std::string> get_gpio_srcs(
 1849         const std::string& bank,
 1860     virtual std::vector<std::string> get_gpio_src(
 1861         const std::string& bank,
 1877     virtual void set_gpio_src(
 1878         const std::vector<std::string>& src,
 1879         const size_t mboard = 0) = 0;
 1893     virtual std::vector<std::string> get_rx_filter_names(
 1902         const std::string& name,
 1911     virtual void set_rx_filter(
 1913         const size_t chan) = 0;
 1924     virtual std::vector<std::string> get_tx_filter_names(
 1933         const std::string& name,
 1942     virtual void set_tx_filter(
 1944         const size_t chan) = 0;
