X4x0 GPIO API
The X4x0 Front Panel GPIO
Like other USRP devices (e.g., E310, X310), the X4x0 devices expose auxiliary GPIO connections through the motherboard. These GPIO pins can be controlled from either the user application in the FPGA or from the radio blocks.
There are 24 GPIO pins in total, split between two HDMI connectors (labelled GPIO0 and GPIO1) which each expose 12 pins.
Additionally, the X4x0 GPIO lines include a 3.3V power supply which is disabled by default, which can provide up to 450mA with overcurrent protection. See Configuring External Power Supply
The GPIO port is not meant to drive big loads.
Connector
HDMI pinout
Pin Mapping
  • Pin 1: Data[0]
  • Pin 2: 0V
  • Pin 3: Data[1]
  • Pin 4: Data[2]
  • Pin 5: 0V
  • Pin 6: Data[3]
  • Pin 7: Data[4]
  • Pin 8: 0V
  • Pin 9: Data[5]
  • Pin 10: Data[6]
  • Pin 11: 0V
  • Pin 12: Data[7]
  • Pin 13: Data[8]
  • Pin 14: N/C
  • Pin 15: Data[9]
  • Pin 16: Data[10]
  • Pin 17: 0V
  • Pin 18: +3.3V (see Configuring External Power Supply)
  • Pin 19: Data[11]
Setting GPIO Output
The GPIO lines can be configured according to the uhd::usrp::multi_usrp::set_gpio_attr() API, like can be seen at Explaining ATR.
The major difference is that in order to use that API, the GPIO source must be correctly configured. The source can be configured using uhd::usrp::multi_usrp::set_gpio_src(), which takes two arguments: A "bank" and a "src". The bank argument specifies the GPIO port to configure, and the src argument is a vector of twelve elements, each specifying the source for the given GPIO pin.
# Set every pin on GPIO0 to be controlled by DB1_RF0
usrp.set_gpio_src("GPIO0", ["DB1_RF0"]*12)
The bank can be either "GPIO0" or "GPIO1", and the sources can be any combination of:
  • DBx_RFy: Controlled by the slot-x radio block via the set_gpio_attr API, with ATR states derived from channel y on that slot if CTRL is set to 1. If CTRL is set to 0, y is ignored and can be either 0 or 1.
  • DBx_SPI: Controlled via the digital interface block in the slot-x radio block.
  • PS: Controlled directly via the Linux GPIO API on the embedded processor.
  • USER_APP: Controlled via user logic in the FPGA. Note that this only works with custom modifications to the FPGA codebase, and not with standard UHD FPGA images.
Once the source is set, using the GPIO proceeds identically to the usage on other devices. Note that the values and masks for the uhd::usrp::multi_usrp::set_gpio_attr() API combines all 24 pins, with bits [23:12] representing the GPIO1 port and bits [11:0] representing the GPIO0 port. For example, to configure the 4th bit on GPIO1 (HDMI pin number 7) as a high output, one would run:
pin_mask = 1 << (12 + 4) # 12 for GPIO1, 4 for the bit on that port
usrp.set_gpio_attr("GPIOA", "CTRL", 0, pin_mask) # Non-ATR mode
usrp.set_gpio_attr("GPIOA", "DDR", pin_mask, pin_mask) # Output
usrp.set_gpio_attr("GPIOA", "OUT", pin_mask, pin_mask) # Set value high
usrp.set_gpio_attr("GPIOA", "OUT", 0, pin_mask) # Set value low
The X410's GPIO ports each have 3.3V power supply pins, which is disabled by default. The GPIO lines will function correctly without the external power supply enabled, and the voltage of the power supply is independent of the selected GPIO line voltage. To enable the power supply, call the uhd::features::gpio_power_iface::set_external_power() method on the gpio_power discoverable feature attached to the mb_controller:
auto usrp = uhd::usrp::multi_usrp::make("type=x4xx");
auto& gpio = usrp->get_mb_controller().get_feature<uhd::features::gpio_power_iface>();
gpio.set_external_power("GPIO1", true); // Enable external power on GPIO1
The status of the external power supply can be queried using uhd::features::gpio_power_iface::get_external_power_status(), which will return one of the following values:
Configuring GPIO Voltage
The voltage level of the I/O lines can be selected as any of 1.8V, 2.5V, or 3.3V voltage levels on a per-bank basis. To do this use the uhd::features::gpio_power_iface::set_port_voltage() API:
gpio.set_port_voltage("GPIO0", "2V5"); // Set GPIO0 voltage to 2.5V
Valid values can be enumerated with the uhd::features::gpio_power_iface::supported_voltages() call, and are "1V8", "2V5", and "3V3".
The x4x0 SPI Mode
The GPIO ports of the x4x0 can be used with the Serial Peripheral Interface (SPI) to control external components. To use SPI mode, set the pins you need on the desired GPIO port to be controlled by the SPI engine and configure the data direction.
auto usrp = uhd::usrp::multi_usrp::make(args);
auto& spi_getter_iface =
usrp->get_radio_control().get_feature<uhd::features::spi_getter_iface>();
usrp->set_gpio_src("GPIO0",
{"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI",
"DB0_SPI"});
The example shows the usage of GPIO port 0 (GPIO0) for SPI and needs to be run for GPIO1 again to use that port with SPI, too.
Configuration of SPI lines
The x4x0 SPI mode supports up to 4 peripherals. All of these peripherals may have a different SPI pin configuration. The pins available for the usage with SPI are listed in Pin Mapping. For GPIO0 the available pins are enumerated from 0 through 11, for GPIO1 the available pins are from 12 through 23. The vector of peripheral configurations is passed to the spi_iface_getter to get the reference:
periph_cfg.periph_clk = 0;
periph_cfg.periph_sdi = 1;
periph_cfg.periph_sdo = 2;
periph_cfg.periph_cs = 3;
std::vector<uhd::features::spi_periph_config_t> periph_cfgs;
periph_cfgs.push_back(periph_cfg);
auto spi_ref = spi_getter_iface.get_spi_ref(periph_cfgs);
// Set data direction register (set all to outgoing except for SDI)
usrp->set_gpio_attr("GPIOA", "DDR", 0xD, 0xF);
Write and read on SPI
With the SPI reference read and write operations can be performed. For doing this, some characteristics of the SPI need to be configured:
config.divider = 4;
config.miso_edge = config.EDGE_RISE;
spi_ref->write_spi(0, config, 0xFEFE, 32);
uint32_t read_data = spi_ref->read_spi(0, config, 0xFEFE, 32);
The terms 'MISO' and 'MOSI' in the spi_config_t struct map to 'SDI' and 'SDO' respectively. They are legacy terms which will not be used in new code anymore following the resolution to redefine SPI signal names by the Open Source Hardware Association: https://www.oshwa.org/a-resolution-to-redefine-spi-signal-names/
The SPI clock \(SCLK\) is derived from the Radio clock and the SPI clock divider as follows:
\[SCLK = \frac{Radio\_Clk}{SPI\_CLK\_DIV + 1}\]
uhd::features::spi_periph_config_t::periph_sdi
uint8_t periph_sdi
Indicates which GPIO line to use for the SDI signal.
Definition: spi_getter_iface.hpp:26
virtual void set_external_power(const std::string &port, bool enable)=0
uhd::features::spi_periph_config_t::periph_clk
uint8_t periph_clk
Indicates which GPIO line to use for the SCLK signal.
Definition: spi_getter_iface.hpp:32
uhd::features::spi_periph_config_t::periph_sdo
uint8_t periph_sdo
Indicates which GPIO line to use for the SDO signal.
Definition: spi_getter_iface.hpp:29
Definition: spi_getter_iface.hpp:37
virtual void set_port_voltage(const std::string &port, const std::string &voltage)=0
uhd::spi_config_t::miso_edge
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:94
uhd::spi_config_t::divider
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:100
Definition: spi_getter_iface.hpp:20
uhd::spi_config_t
Definition: serial.hpp:82
uhd::features::spi_periph_config_t::periph_cs
uint8_t periph_cs
Indicates which GPIO line to use for the CS signal.
Definition: spi_getter_iface.hpp:23
uhd::spi_config_t::EDGE_RISE
@ EDGE_RISE
Definition: serial.hpp:88
Definition: gpio_power_iface.hpp:20
