Loading [MathJax]/extensions/MathMenu.js
uhd::math::fp_compare::fp_compare_epsilon< float_t > Class Template Reference
#include <uhd/utils/math.hpp>
UHD_INLINE fp_compare_epsilon (float_t value)
UHD_INLINE fp_compare_epsilon (float_t value, float_t epsilon)
UHD_INLINE fp_compare_epsilon (const fp_compare_epsilon< float_t > &copy)
UHD_INLINE ~fp_compare_epsilon ()
UHD_INLINE void operator= (const fp_compare_epsilon &copy)
template<>
UHD_INLINE fp_compare_epsilon (float value)
template<>
UHD_INLINE fp_compare_epsilon (double value)
Public Attributes
float_t _value
float_t _epsilon
template<typename float_t>
class uhd::math::fp_compare::fp_compare_epsilon< float_t >
Class for floating-point comparisons using an epsilon.
At construction, you can specify the epsilon to use for the comparisons. This class, combined with the operators under it, allow for epsilon-comparisons of floats. An example is:
// Compare floats 'x' and 'y'. bool x_equals_y = (fp_compare_epsilon<float>(x) == y);
// Compare doubles 'x' and 'y'. bool x_equals_y = (fp_compare_epsilon<double>(x) == y);
◆ fp_compare_epsilon() [1/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_epsilon< float_t >::fp_compare_epsilon ( float_t  value)
◆ fp_compare_epsilon() [2/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_epsilon< float_t >::fp_compare_epsilon ( float_t  value,
float_t  epsilon
◆ fp_compare_epsilon() [3/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_epsilon< float_t >::fp_compare_epsilon ( const fp_compare_epsilon< float_t > &  copy)
◆ ~fp_compare_epsilon()
template<typename float_t >
UHD_INLINE uhd::math::fp_compare::fp_compare_epsilon< float_t >::~fp_compare_epsilon ( )
◆ fp_compare_epsilon() [4/5]
◆ fp_compare_epsilon() [5/5]
◆ operator=()
UHD_INLINE void uhd::math::fp_compare::fp_compare_epsilon< float_t >::operator= ( const fp_compare_epsilon< float_t > &  copy)
◆ _epsilon
float_t uhd::math::fp_compare::fp_compare_epsilon< float_t >::_epsilon
◆ _value
float_t uhd::math::fp_compare::fp_compare_epsilon< float_t >::_value
