13 #include <boost/numeric/conversion/bounds.hpp>    15 #if BOOST_VERSION >= 106700    16 #    include <boost/integer/common_factor.hpp>    18 namespace _bmint = boost::integer;
    20 #    include <boost/math/common_factor.hpp>    21 namespace _bmint = boost::math;
    33 static const double PI = 3.14159265358979323846;
    51 static const float SINGLE_PRECISION_EPSILON  = 1.19e-7f;
    52 static const double DOUBLE_PRECISION_EPSILON = 2.22e-16;
    62 static constexpr
double FREQ_COMPARE_EPSILON = 1e-12;
    64 namespace fp_compare {
    79 template <
typename float_t>
   108 template <
typename float_t>
   111 template <
typename float_t>
   114 template <
typename float_t>
   117 template <
typename float_t>
   120 template <
typename float_t>
   123 template <
typename float_t>
   129 template <
typename float_t>
   131 template <
typename float_t>
   133 template <
typename float_t>
   134 UHD_INLINE bool operator<(fp_compare_epsilon<float_t> lhs,
double rhs);
   135 template <
typename float_t>
   136 UHD_INLINE bool operator<=(fp_compare_epsilon<float_t> lhs,
double rhs);
   137 template <
typename float_t>
   139 template <
typename float_t>
   142 template <
typename float_t>
   144 template <
typename float_t>
   146 template <
typename float_t>
   147 UHD_INLINE bool operator<(double lhs, fp_compare_epsilon<float_t> rhs);
   148 template <
typename float_t>
   149 UHD_INLINE bool operator<=(double lhs, fp_compare_epsilon<float_t> rhs);
   150 template <
typename float_t>
   152 template <
typename float_t>
   180 static const float SINGLE_PRECISION_DELTA  = 1e-3f;
   181 static const double DOUBLE_PRECISION_DELTA = 1e-5;
   184 static const double FREQ_COMPARISON_DELTA_HZ = 0.1;
   187 namespace fp_compare {
   202 template <
typename float_t>
   207     UHD_INLINE fp_compare_delta(float_t value, float_t delta);
   216 template <
typename float_t>
   218 template <
typename float_t>
   220 template <
typename float_t>
   222 template <
typename float_t>
   224 template <
typename float_t>
   226 template <
typename float_t>
   231 template <
typename float_t>
   233 template <
typename float_t>
   235 template <
typename float_t>
   236 UHD_INLINE bool operator<(fp_compare_delta<float_t> lhs,
double rhs);
   237 template <
typename float_t>
   238 UHD_INLINE bool operator<=(fp_compare_delta<float_t> lhs,
double rhs);
   239 template <
typename float_t>
   241 template <
typename float_t>
   244 template <
typename float_t>
   246 template <
typename float_t>
   248 template <
typename float_t>
   249 UHD_INLINE bool operator<(double lhs, fp_compare_delta<float_t> rhs);
   250 template <
typename float_t>
   251 UHD_INLINE bool operator<=(double lhs, fp_compare_delta<float_t> rhs);
   252 template <
typename float_t>
   254 template <
typename float_t>
   267     return std::pow(10, (dB_val) / 10.0);
   272     return 10 * std::log10(val);
   277 template <
typename IntegerType>
   278 inline IntegerType
lcm(IntegerType x, IntegerType y)
   281     return _bmint::lcm<IntegerType>(x, y);
   285 template <
   286 inline IntegerType
gcd(IntegerType x, IntegerType y)
   289     return _bmint::gcd<IntegerType>(x, y);
   299 template <
typename T>
   304     return (T(0) < x) - (x < T(0));
   319     double freq = std::fmod(requested_freq, rate);
   320     if (std::abs(freq) > rate / 2.0)
 UHD_INLINE bool frequencies_are_equal(double lhs, double rhs)
Definition: math.hpp:259
UHD_INLINE bool operator<=(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:84
float_t _value
Definition: math.hpp:212
UHD_INLINE freq_compare_epsilon(const freq_compare_epsilon ©)
Definition: math.hpp:164
UHD_INLINE bool operator>=(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:97
IntegerType gcd(IntegerType x, IntegerType y)
Portable version of gcd() across Boost versions.
Definition: math.hpp:286
UHD_INLINE bool operator>(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:90
Definition: fp_compare_delta.ipp:71
An alias for fp_compare_epsilon, but with defaults for frequencies.
Definition: math.hpp:156
double wrap_frequency(const double requested_freq, const double rate)
Return a wrapped frequency that is the equivalent frequency in the first.
Definition: math.hpp:317
float_t _delta
Definition: math.hpp:213
float_t _epsilon
Definition: math.hpp:90
UHD_INLINE freq_compare_epsilon(double value)
Definition: math.hpp:159
Definition: build_info.hpp:12
UHD_INLINE bool operator<(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:77
#define UHD_INLINE
Definition: config.h:65
double dB_to_lin(const double dB_val)
Definition: math.hpp:265
UHD_INLINE ~fp_compare_epsilon()
Definition: fp_compare_epsilon.ipp:46
constexpr int sign(T x)
Returns the sign of x.
Definition: math.hpp:300
float_t _value
Definition: math.hpp:89
UHD_INLINE void operator=(const fp_compare_epsilon ©)
Definition: fp_compare_epsilon.ipp:51
UHD_INLINE fp_compare_epsilon(float_t value)
UHD_INLINE bool operator==(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:64
double lin_to_dB(const double val)
Definition: math.hpp:270
IntegerType lcm(IntegerType x, IntegerType y)
Portable version of lcm() across Boost versions.
Definition: math.hpp:278
