uhd::rfnoc::chdr::mgmt_op_t Class Reference
A class that represents a single management operation. More...
Classes
struct  cfg_payload
struct  node_info_payload
 An interpretation class for the payload for MGMT_OP_INFO_RESP. More...
struct  sel_dest_payload
 An interpretation class for the payload for MGMT_OP_SEL_DEST. More...
enum  op_code_t {
  MGMT_OP_NOP = 0, MGMT_OP_ADVERTISE = 1, MGMT_OP_SEL_DEST = 2, MGMT_OP_RETURN = 3,
  MGMT_OP_INFO_REQ = 4, MGMT_OP_INFO_RESP = 5, MGMT_OP_CFG_WR_REQ = 6, MGMT_OP_CFG_RD_REQ = 7,
  MGMT_OP_CFG_RD_RESP = 8
using payload_t = uint64_t
 The payload for an operation is 48 bits wide. More...
 mgmt_op_t (const op_code_t op_code, const payload_t op_payload=0, const uint8_t ops_pending=0)
 mgmt_op_t (const mgmt_op_t &rhs)=default
uint8_t get_ops_pending () const
 Get the ops pending for this transaction. More...
op_code_t get_op_code () const
 Get the op-code for this transaction. More...
uint64_t get_op_payload () const
 Get the payload for this transaction. More...
bool operator== (const mgmt_op_t &rhs) const
 Comparison operator (==) More...
const std::string to_string () const
 Return a string representation of this object. More...
◆ payload_t
◆ op_code_t
Enumerator
MGMT_OP_NOP
Do nothing.
MGMT_OP_ADVERTISE
Advertise this operation to the outside logic.
MGMT_OP_SEL_DEST
Select the next destination for routing.
MGMT_OP_RETURN
Return the management packet back to its source.
MGMT_OP_INFO_REQ
Request information about the current node.
MGMT_OP_INFO_RESP
A response to an information request.
MGMT_OP_CFG_WR_REQ
Perform a configuration write on the node.
MGMT_OP_CFG_RD_REQ
Perform a configuration read on the node.
MGMT_OP_CFG_RD_RESP
A response to a configuration read.
◆ mgmt_op_t() [1/2]
uhd::rfnoc::chdr::mgmt_op_t::mgmt_op_t ( const op_code_t  op_code,
const payload_t  op_payload = 0,
const uint8_t  ops_pending = 0
◆ mgmt_op_t() [2/2]
uhd::rfnoc::chdr::mgmt_op_t::mgmt_op_t ( const mgmt_op_t &  rhs)
default
◆ get_op_code()
op_code_t uhd::rfnoc::chdr::mgmt_op_t::get_op_code ( ) const
◆ get_op_payload()
uint64_t uhd::rfnoc::chdr::mgmt_op_t::get_op_payload ( ) const
◆ get_ops_pending()
uint8_t uhd::rfnoc::chdr::mgmt_op_t::get_ops_pending ( ) const
◆ operator==()
bool uhd::rfnoc::chdr::mgmt_op_t::operator== ( const mgmt_op_t &  rhs) const
◆ to_string()
const std::string uhd::rfnoc::chdr::mgmt_op_t::to_string ( ) const
