uhd::rfnoc::dirtifier_t Class Reference
#include <uhd/rfnoc/dirtifier.hpp>
Inheritance diagram for uhd::rfnoc::dirtifier_t:
uhd::rfnoc::property_base_t
 dirtifier_t ()
bool is_dirty () const override
 This property is always dirty. More...
bool is_valid () const override
 This property is always invalid. More...
bool equal (property_base_t *) const override
 This property is never equal to anything else. More...
void force_dirty () override
 Always dirty, so this can be called as often as we like. More...
void set_from_str (const std::string &) override
- Public Member Functions inherited from uhd::rfnoc::property_base_t
 property_base_t (const std::string &id, const res_source_info &source_info)
virtual ~property_base_t ()
const std::string & get_id () const
 Gets the ID (name) of this property. More...
const res_source_info & get_src_info () const
 Return the source info for this property. More...
bool read_access_granted () const
 Returns true if this property can be read. More...
bool write_access_granted () const
 Returns true if this property can be written to. More...
access_t get_access_mode () const
 Return the current access mode. More...
virtual std::unique_ptr< property_base_t > clone (res_source_info)
 Create a copy of this property. More...
- Public Types inherited from uhd::rfnoc::property_base_t
enum  access_t { NONE, RO = 0x1, RW = 0x3, RWLOCKED = 0x5 }
This is a special class for property that is always dirty. This is useful to force property resolutions in certain cases.
Note: This has nothing to do with 'dirtify' in the CGI/graphics sense.
◆ dirtifier_t()
uhd::rfnoc::dirtifier_t::dirtifier_t ( )
◆ equal()
bool uhd::rfnoc::dirtifier_t::equal ( property_base_t *  ) const
inlineoverridevirtual
Implements uhd::rfnoc::property_base_t.
◆ force_dirty()
void uhd::rfnoc::dirtifier_t::force_dirty ( )
◆ is_dirty()
bool uhd::rfnoc::dirtifier_t::is_dirty ( ) const
◆ is_valid()
bool uhd::rfnoc::dirtifier_t::is_valid ( ) const
◆ set_from_str()
void uhd::rfnoc::dirtifier_t::set_from_str ( const std::string &  new_val_str)
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
Exceptions
uhd::runtime_errorif the underlying type has no conversion from a string
