uhd::soft_regmap_t Class Reference
Inheritance diagram for uhd::soft_regmap_t:
uhd::soft_regmap_accessor_t
 soft_regmap_t (const std::string &name)
 ~soft_regmap_t () override
UHD_INLINE const std::string & get_name () const override
void initialize (wb_iface &iface, bool sync=false)
void flush ()
void refresh ()
soft_register_base & lookup (const std::string &name) const override
std::vector< std::string > enumerate () const override
- Public Member Functions inherited from uhd::soft_regmap_accessor_t
virtual ~soft_regmap_accessor_t ()
Protected Types
enum  visibility_t { PUBLIC, PRIVATE }
UHD_INLINE void add_to_map (soft_register_base &reg, const std::string &name, const visibility_t visible=PRIVATE)
- Public Types inherited from uhd::soft_regmap_accessor_t
typedef std::shared_ptr< soft_regmap_accessor_t > sptr
A regmap is a collection of registers that share the same bus (control iface). A regmap must have an identifier. A regmap must manage storage for each register. The recommended way to use a regmap is to define individual registers within the scope of the regmap and instantiate them in the ragmap. Soft register object that holds offset, soft-copy and the control iface. Methods give convenient field-level access to soft-copy and the ability to do read-modify-write operations.
◆ visibility_t
Enumerator
PUBLIC
PRIVATE
◆ soft_regmap_t()
uhd::soft_regmap_t::soft_regmap_t ( const std::string &  name)
◆ ~soft_regmap_t()
uhd::soft_regmap_t::~soft_regmap_t ( )
inlineoverride
◆ add_to_map()
UHD_INLINE void uhd::soft_regmap_t::add_to_map ( soft_register_base &  reg,
const std::string &  name,
const visibility_t  visible = PRIVATE
inlineprotected
Add a register to this map with an identifier "name" and visibility
◆ enumerate()
std::vector<std::string> uhd::soft_regmap_t::enumerate ( ) const
inlineoverridevirtual
Enumerate all the registers in this map. Return fully qualified paths.
void uhd::soft_regmap_t::flush ( )
Flush all registers to hardware. The order of writing is the same as the order in which registers were added to the map.
◆ get_name()
UHD_INLINE const std::string& uhd::soft_regmap_t::get_name ( ) const
void uhd::soft_regmap_t::initialize ( wb_iface &  iface,
Initialize all registers in this register map using a bus. Optionally synchronize the register with hardware. The order of initialization is the same as the order in which registers were added to the map.
◆ lookup()
soft_register_base& uhd::soft_regmap_t::lookup ( const std::string &  name) const
Lookup a register object by name. If a register with "name" is not found, runtime_error is thrown
void uhd::soft_regmap_t::refresh ( )
Refresh all register soft-copies from hardware. The order of reading is the same as the order in which registers were added to the map.
