14 #include <unordered_map>    15 #include <boost/tokenizer.hpp>    38 #define UHD_DEFINE_SOFT_REG_FIELD(name, width, shift) \    39     static const uhd::soft_reg_field_t name = (((shift & 0xFF) << 8) | (width & 0xFF))    49     return __builtin_expect(expr,
true);
    59     return __builtin_expect(expr,
false);
    74 namespace soft_reg_field {
    77     return (field & 0xFF);
    82     return ((field >> 8) & 0xFF);
    85 template <
typename data_t>
    88     constexpr data_t ONE      =
static_cast<data_t
>(1);
    89     constexpr data_t ALL_ONES = ~static_cast<data_t>(0);
    94         return ((ONE <<
width(field)) - ONE) <<
shift(field);
    96         return ALL_ONES <<
shift(field);
   106     virtual void initialize(
wb_iface& iface,
bool sync =
false) = 0;
   107     virtual void flush()                                        = 0;
   108     virtual void refresh()                                      = 0;
   109     virtual size_t get_bitwidth()                               = 0;
   110     virtual bool is_readable()                                  = 0;
   111     virtual bool is_writable()                                  = 0;
   116     template <
typename soft_reg_t>
   119         soft_reg_t* ptr =
dynamic_cast<soft_reg_t*
   135 template <
typename reg_data_t,
bool readable,
bool writable>
   139     typedef std::shared_ptr<soft_register_t<reg_data_t, readable, writable>>
sptr;
   164         : _iface(NULL), _wr_addr(addr), _rd_addr(addr), _soft_copy(0), _flush_mode(mode)
   178         if (sync && writable)
   180         if (sync && readable)
   189     UHD_INLINE void set(
const soft_reg_field_t field,
const reg_data_t value)
   191         _soft_copy = (_soft_copy & ~soft_reg_field::mask<reg_data_t>(field))
   193                          & soft_reg_field::mask<reg_data_t>(field));
   202         return (_soft_copy & soft_reg_field::mask<reg_data_t>(field))
   211         if (writable && _iface) {
   215             if (_flush_mode == ALWAYS_FLUSH || _soft_copy.is_dirty()) {
   216                 if (get_bitwidth() <= 32) {
   217                     _iface->poke32(_wr_addr, static_cast<uint32_t>(_soft_copy));
   218                 }
else if (get_bitwidth() <= 64) {
   219                     _iface->poke64(_wr_addr, static_cast<uint64_t>(_soft_copy));
   222                         "soft_register only supports up to 64 bits.");
   224                 _soft_copy.mark_clean();
   228                 "soft_register is not writable or uninitialized.");
   237         if (readable && _iface) {
   238             if (get_bitwidth() <= 32) {
   239                 _soft_copy =
static_cast<reg_data_t
>(_iface->peek32(_rd_addr));
   240             }
   241                 _soft_copy =
>(_iface->peek64(_rd_addr));
   244                     "soft_register only supports up to 64 bits.");
   246             _soft_copy.mark_clean();
   249                 "soft_register is not readable or uninitialized.");
   276         static const size_t BITS_IN_BYTE = 8;
   277         return sizeof(reg_data_t) * BITS_IN_BYTE;
   308 template <
bool readable,
bool writable>
   313     typedef std::shared_ptr<soft_register_sync_t<reg_data_t, readable, writable>>
sptr;
   318         :
soft_register_t<reg_data_t, readable, writable>(wr_addr, rd_addr, mode)
   325         :
soft_register_t<reg_data_t, readable, writable>(addr, mode), _mutex()
   331         std::lock_guard<std::mutex> lock(_mutex);
   335     UHD_INLINE void set(
   337         std::lock_guard<std::mutex> lock(_mutex);
   343         std::lock_guard<std::mutex> lock(_mutex);
   349         std::lock_guard<std::mutex> lock(_mutex);
   355         std::lock_guard<std::mutex> lock(_mutex);
   361         std::lock_guard<std::mutex> lock(_mutex);
   367         std::lock_guard<std::mutex> lock(_mutex);
   445     typedef std::shared_ptr<soft_regmap_accessor_t>
sptr;
   449     virtual std::vector<std::string> enumerate()
const                = 0;
   450     virtual const std::string& get_name()
const                       = 0;
   485         std::lock_guard<std::mutex> lock(_mutex);
   487             reg->initialize(iface, sync);
   498         std::lock_guard<std::mutex> lock(_mutex);
   511         std::lock_guard<std::mutex> lock(_mutex);
   523         regmap_t::const_iterator iter = _regmap.find(name);
   524         if (iter != _regmap.end()) {
   525             return *(iter->second);
   537         std::vector<std::string> temp;
   538         for (
const regmap_t::value_type& reg : _regmap) {
   539             temp.push_back(_name +
"/" + reg.first);
   554         const std::string& name,
   557         std::lock_guard<std::mutex> lock(_mutex);
   558         if (visible == PUBLIC) {
   560             if (not _regmap.insert(regmap_t::value_type(name, ®)).second) {
   562                     "cannot add two registers with the same name to regmap: " + name);
   565         _reglist.push_back(®);
   569     typedef std::unordered_map<std::string, soft_register_base*> regmap_t;
   570     typedef std::list<soft_register_base*> reglist_t;
   572     const std::string _name;
   588     typedef std::shared_ptr<soft_regmap_db_t>
sptr;
   613         std::lock_guard<std::mutex> lock(_mutex);
   614         _regmaps.push_back(®map);
   622         std::lock_guard<std::mutex> lock(_mutex);
   626             _regmap_dbs.push_back(&db);
   643         std::list<std::string> tokens;
   644         for (
const std::string& node : boost::tokenizer<boost::char_separator<char>>(
   645                  path, boost::char_separator<char>(
   646             tokens.push_back(node);
   648         if ((tokens.size() > 2 && tokens.front() == _name) ||
   649             (tokens.size() > 1 && _name.empty())) {
   652             if (tokens.size() == 2) {
   654                     if (regmap->get_name() == tokens.front()) {
   655                         return regmap->lookup(tokens.back());
   659             }
else if (not _regmap_dbs
   663                 for (
const std::string& node : tokens) {
   664                     newpath += (
"/" + node);
   669                         return db->lookup(newpath.substr(1));
   670                     }
catch (std::exception&) {
   684         std::vector<std::string> paths;
   686             const std::vector<std::string>& regs = regmap->enumerate();
   687             paths.insert(paths.end(), regs.begin(), regs.end());
   690             const std::vector<std::string>& regs = db->enumerate();
   691             paths.insert(paths.end(), regs.begin(), regs.end());
   697     typedef std::list<soft_regmap_accessor_t*> db_t;
   699     const std::string _name;
 void refresh()
Definition: soft_register.hpp:509
uint32_t soft_reg_field_t
Definition: soft_register.hpp:72
UHD_INLINE bool is_writable() override
Definition: soft_register.hpp:291
std::shared_ptr< soft_register_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:139
Definition: soft_register.hpp:128
soft_reg_flush_mode_t
UHD_INLINE void initialize(wb_iface &iface, bool sync=false) override
Definition: soft_register.hpp:173
Definition: soft_register.hpp:309
Definition: exception.hpp:156
soft_regmap_t(const std::string &name)
Definition: soft_register.hpp:466
UHD_INLINE bool unlikely(bool expr)
hint for the branch prediction
Definition: soft_register.hpp:56
std::vector< std::string > enumerate() const override
Definition: soft_register.hpp:535
soft_register_t< uint64_t, false, true > soft_reg64_wo_t
Definition: soft_register.hpp:395
soft_register_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:162
Definition: soft_register.hpp:38
soft_register_t< uint32_t, true, false > soft_reg32_ro_t
Definition: soft_register.hpp:389
UHD_INLINE const std::string & get_name() const override
Definition: soft_register.hpp:472
soft_register_sync_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:323
soft_register_sync_t< uint64_t, true, true > soft_reg64_rw_sync_t
Definition: soft_register.hpp:400
Definition: exception.hpp:131
Definition: soft_register.hpp:585
UHD_INLINE void flush() override
Definition: soft_register.hpp:209
soft_register_sync_t< uint32_t, false, true > soft_reg32_wo_sync_t
Definition: soft_register.hpp:391
soft_register_t< uint32_t, false, true > soft_reg32_wo_t
Definition: soft_register.hpp:388
UHD_INLINE size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:75
Definition: soft_register.hpp:546
UHD_INLINE void set(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:189
soft_regmap_db_t(const std::string &name)
Definition: soft_register.hpp:598
virtual ~soft_regmap_accessor_t()
Definition: soft_register.hpp:447
Definition: soft_register.hpp:136
UHD_INLINE reg_data_t get(const soft_reg_field_t field)
Definition: soft_register.hpp:200
Definition: build_info.hpp:12
soft_regmap_db_t()
Definition: soft_register.hpp:593
UHD_INLINE void write(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:359
virtual ~soft_register_base()
Definition: soft_register.hpp:104
void flush()
Definition: soft_register.hpp:496
~soft_regmap_t() override
Definition: soft_register.hpp:467
std::shared_ptr< soft_regmap_db_t > sptr
Definition: soft_register.hpp:588
visibility_t
Definition: soft_register.hpp:545
Definition: soft_register.hpp:603
Definition: soft_register.hpp:483
soft_register_sync_t< uint64_t, true, false > soft_reg64_ro_sync_t
Definition: soft_register.hpp:399
soft_register_sync_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:315
Definition: soft_register.hpp:442
#define UHD_INLINE
Definition: config.h:65
Definition: soft_register.hpp:347
UHD_INLINE reg_data_t read(const soft_reg_field_t field)
Definition: soft_register.hpp:265
soft_register_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:147
soft_register_t< uint64_t, true, false > soft_reg64_ro_t
Definition: soft_register.hpp:396
Definition: soft_register.hpp:463
Definition: soft_register.hpp:101
soft_register_sync_t< uint32_t, true, false > soft_reg32_ro_sync_t
Definition: soft_register.hpp:392
Definition: soft_register.hpp:682
Definition: exception.hpp:47
Definition: config.h:87
Definition: soft_register.hpp:86
UHD_INLINE bool is_readable() override
Definition: soft_register.hpp:283
void add(soft_regmap_t ®map)
Definition: soft_register.hpp:611
soft_register_base & lookup(const std::string &name) const override
Definition: soft_register.hpp:521
Definition: soft_register.hpp:365
UHD_INLINE void refresh()
Definition: soft_register.hpp:353
soft_register_t< uint64_t, true, true > soft_reg64_rw_t
Definition: soft_register.hpp:397
soft_register_base & lookup(const std::string &path) const override
Definition: soft_register.hpp:640
Definition: soft_register.hpp:256
UHD_INLINE void refresh() override
Definition: soft_register.hpp:235
Definition: exception.hpp:95
void add(soft_regmap_db_t &db)
Definition: soft_register.hpp:620
std::shared_ptr< soft_regmap_accessor_t > sptr
Definition: soft_register.hpp:445
UHD_INLINE size_t get_bitwidth() override
Definition: soft_register.hpp:274
soft_register_sync_t< uint64_t, false, true > soft_reg64_wo_sync_t
Definition: soft_register.hpp:398
std::shared_ptr< soft_register_sync_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:313
Definition: soft_register.hpp:329
UHD_INLINE bool likely(bool expr)
soft_register_sync_t< uint32_t, true, true > soft_reg32_rw_sync_t
Definition: soft_register.hpp:393
UHD_INLINE void add_to_map(soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE)
Definition: soft_register.hpp:553
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:80
uint32_t wb_addr_type
Definition: wb_iface.hpp:21
static UHD_INLINE soft_reg_t & cast(soft_register_base ®)
Definition: soft_register.hpp:117
Definition: wb_iface.hpp:17
soft_register_t< uint32_t, true, true > soft_reg32_rw_t
Definition: soft_register.hpp:390
