| template<typename float_t >  |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (fp_compare_epsilon< float_t > lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (fp_compare_epsilon< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (double lhs, fp_compare_epsilon< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (fp_compare_delta< float_t > lhs, double rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator== (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator!= (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator< (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator<= (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator> (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::fp_compare::operator>= (double lhs, fp_compare_delta< float_t > rhs) |
| UHD_INLINE bool  | uhd::math::frequencies_are_equal (double lhs, double rhs) |
| double  | uhd::math::dB_to_lin (const double dB_val) |
| double  | uhd::math::lin_to_dB (const double val) |
| template<typename IntegerType >  |
| IntegerType  | uhd::math::lcm (IntegerType x, IntegerType y) |
|   | Portable version of lcm() across Boost versions.  More...
| IntegerType  | uhd::math::gcd (IntegerType x, IntegerType y) |
|   | Portable version of gcd() across Boost versions.  More...
| template<typename T >  |
| constexpr int  | uhd::math::sign (T x) |
|   | Returns the sign of x.  More...
| double  | uhd::math::wrap_frequency (const double requested_freq, const double rate) |
|   | Return a wrapped frequency that is the equivalent frequency in the first.  More...
