noc_block_make_args.hpp
2 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/property_tree.hpp>
13
14 namespace uhd { namespace rfnoc {
15
16 class clock_iface;
17 class mb_controller;
18
25 {
26  ~make_args_t();
27
30
33
36
39
41  size_t mtu;
42
45
48
50  std::shared_ptr<clock_iface> tb_clk_iface;
51
53  std::shared_ptr<clock_iface> ctrlport_clk_iface;
54
56  //
57  // Note that this may not be populated -- most blocks do not gain access to
58  // the motherboard controller.
59  std::shared_ptr<mb_controller> mb_control;
60
63
66 };
67
68 }} /* namespace uhd::rfnoc */
uhd::device_addr_t args
Additional args that can be parsed and used by this block.
Definition: noc_block_make_args.hpp:65
std::shared_ptr< mb_controller > mb_control
Reference to the motherboard controller associated with this block.
Definition: noc_block_make_args.hpp:59
size_t num_input_ports
Number of input ports (gets reported from the FPGA)
Definition: noc_block_make_args.hpp:35
uhd::property_tree::sptr tree
The subtree for this block.
Definition: noc_block_make_args.hpp:62
register_iface::sptr reg_iface
Register interface to this block&#39;s register space.
Definition: noc_block_make_args.hpp:47
std::shared_ptr< clock_iface > ctrlport_clk_iface
Controlport clock interface object that is shared with the reg_iface.
Definition: noc_block_make_args.hpp:53
std::shared_ptr< register_iface > sptr
Definition: register_iface.hpp:30
Definition: block_id.hpp:39
Definition: build_info.hpp:12
noc_id_t noc_id
Noc-ID.
Definition: noc_block_make_args.hpp:29
size_t mtu
Value of the MTU register, converted to bytes.
Definition: noc_block_make_args.hpp:41
std::shared_ptr< clock_iface > tb_clk_iface
Timebase clock interface object that is shared with the reg_iface.
Definition: noc_block_make_args.hpp:50
Definition: noc_block_make_args.hpp:24
uint32_t noc_id_t
Definition: defaults.hpp:50
size_t num_output_ports
Number of output ports (gets reported from the FPGA)
Definition: noc_block_make_args.hpp:38
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
Definition: property_tree.hpp:223
chdr_w_t chdr_w
CHDR width of this block.
Definition: noc_block_make_args.hpp:44
Definition: device_addr.hpp:37
block_id_t block_id
Block ID (e.g. 0/Radio#0)
Definition: noc_block_make_args.hpp:32
