18 #include <boost/units/detail/utility.hpp>     22 namespace uhd {
namespace rfnoc {
    33                             public std::enable_shared_from_this<rfnoc_graph>
    39     using sptr = std::shared_ptr<rfnoc_graph>;
    78     virtual std::vector<block_id_t> find_blocks(
    79         const std::string& block_id_hint)
const = 0;
    84     std::vector<block_id_t>
find_blocks(
 const    86         std::vector<block_id_t> all_block_ids = find_blocks(block_id_hint);
    87         std::vector<block_id_t> filt_block_ids;
    88         for (
size_t i = 0; i < all_block_ids.size(); i++) {
    89             if (has_block<T>(all_block_ids[i])) {
    90                 filt_block_ids.push_back(all_block_ids[i]);
    93         return filt_block_ids;
   102     virtual bool has_block(
const block_id_t& block_id)
const = 0;
   109     template <
typename T>
   112         return has_block(block_id)
   113                && bool(std::dynamic_pointer_cast<T>(get_block(block_id)));
   140     template <
typename T>
   143         std::shared_ptr<T> blk = std::dynamic_pointer_cast<T>(get_block(block_id));
   148                 std::string(
"This device does not have a block of type ")
   149                 + boost::units::detail::demangle(
typeid(T).name())
   165     virtual bool is_connectable(
const block_id_t& src_blk,
   168         size_t dst_port) = 0;
   189     virtual void connect(
   193         bool is_back_edge =
false) = 0;
   223     virtual void connect(
   242     virtual void disconnect(
   245         size_t dst_port) = 0;
   256     virtual void disconnect(
const std::string& streamer_id) = 0;
   268     virtual void disconnect(
const std::string& streamer_id,
size_t port) = 0;
   279     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_from_src(
   280         const block_id_t& src_blk,
size_t src_port) = 0;
   291     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_to_dst(
   292         const block_id_t& dst_blk,
   303     virtual std::vector<graph_edge_t> enumerate_static_connections()
const = 0;
   312     virtual std::vector<graph_edge_t> enumerate_active_connections() = 0;
   321     virtual void commit() = 0;
   370     virtual size_t get_num_mboards()
const = 0;
   381     virtual std::shared_ptr<mb_controller> get_mb_controller(
   382         const size_t mb_index = 0) = 0;
   418     virtual bool synchronize_devices(
Definition: stream.hpp:169
bool has_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:110
std::string to_string() const
Return a string like this: "0/FFT#1" (includes all components, if set)
Definition: exception.hpp:58
Definition: time_spec.hpp:28
std::shared_ptr< T > get_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:141
size_t adapter_id_t
Host transport adapter ID.
Definition: adapter_id.hpp:17
Definition: block_id.hpp:39
std::shared_ptr< rfnoc_graph > sptr
Definition: rfnoc_graph.hpp:39
Definition: build_info.hpp:12
Definition: rfnoc_graph.hpp:32
Definition: stream.hpp:47
Definition: noc_block_base.hpp:48
Definition: config.h:87
string release
Definition: conf.py:29
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
virtual ~rfnoc_graph()
Definition: rfnoc_graph.hpp:41
std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const
Definition: rfnoc_graph.hpp:84
Definition: property_tree.hpp:223
Definition: device_addr.hpp:37
