siggen_block_control.hpp
2 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
11 #include <uhd/utils/math.hpp>
12 #include <complex>
13
14 namespace uhd { namespace rfnoc {
15
29 {
30 public:
32
33  static const uint32_t REG_BLOCK_SIZE;
34  static const uint32_t REG_ENABLE_OFFSET;
35  static const uint32_t REG_SPP_OFFSET;
36  static const uint32_t REG_WAVEFORM_OFFSET;
37  static const uint32_t REG_GAIN_OFFSET;
38  static const uint32_t REG_CONSTANT_OFFSET;
39  static const uint32_t REG_PHASE_INC_OFFSET;
40  static const uint32_t REG_CARTESIAN_OFFSET;
41
50  virtual void set_enable(const bool enable, const size_t port) = 0;
51
60  virtual bool get_enable(const size_t port) const = 0;
61
70  virtual void set_waveform(const siggen_waveform type, const size_t port) = 0;
71
79  virtual siggen_waveform get_waveform(const size_t port) const = 0;
80
99  virtual void set_amplitude(const double amplitude, const size_t port) = 0;
100
111  virtual double get_amplitude(const size_t port) const = 0;
112
126  virtual void set_constant(const std::complex<double> constant, const size_t port) = 0;
127
137  virtual std::complex<double> get_constant(const size_t port) const = 0;
138
148  virtual void set_sine_phase_increment(const double phase_inc, const size_t port) = 0;
149
159  virtual double get_sine_phase_increment(const size_t port) const = 0;
160
170  virtual void set_samples_per_packet(const size_t spp, const size_t port) = 0;
171
180  virtual size_t get_samples_per_packet(const size_t port) const = 0;
181
192  inline void set_sine_frequency(
193  const double frequency, const double sample_rate, const size_t port)
194  {
195  if (sample_rate <= 0.0) {
196  throw uhd::value_error("sample_rate must be > 0.0");
197  }
198  const double phase_inc = (frequency / sample_rate) * 2.0 * uhd::math::PI;
199  if (phase_inc < -uhd::math::PI || phase_inc > uhd::math::PI) {
200  throw uhd::value_error("frequency must be in [-samp_rate/2, samp_rate/2]");
201  }
202  set_sine_phase_increment(phase_inc, port);
203  }
204 };
205
206 }} // namespace uhd::rfnoc
siggen_waveform
Definition: siggen_block_control.hpp:16
Definition: siggen_block_control.hpp:39
Definition: siggen_block_control.hpp:35
Definition: exception.hpp:107
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: siggen_block_control.hpp:34
Definition: build_info.hpp:12
void set_sine_frequency(const double frequency, const double sample_rate, const size_t port)
Definition: siggen_block_control.hpp:192
Definition: noc_block_base.hpp:42
Definition: siggen_block_control.hpp:37
Definition: config.h:87
Definition: siggen_block_control.hpp:38
Definition: siggen_block_control.hpp:40
Definition: siggen_block_control.hpp:28
Definition: siggen_block_control.hpp:33
Definition: siggen_block_control.hpp:36
