uhd::soft_regmap_db_t Class Reference
Inheritance diagram for uhd::soft_regmap_db_t:
uhd::soft_regmap_accessor_t
typedef std::shared_ptr< soft_regmap_db_t > sptr
- Public Types inherited from uhd::soft_regmap_accessor_t
typedef std::shared_ptr< soft_regmap_accessor_t > sptr
 soft_regmap_db_t ()
 soft_regmap_db_t (const std::string &name)
const std::string & get_name () const override
void add (soft_regmap_t &regmap)
void add (soft_regmap_db_t &db)
soft_register_base & lookup (const std::string &path) const override
std::vector< std::string > enumerate () const override
- Public Member Functions inherited from uhd::soft_regmap_accessor_t
virtual ~soft_regmap_accessor_t ()
A regmap database is a collection of regmaps or other regmap databases this allows for efficient encapsulation for multiple registers in a hierarchical fashion. A regmap_db does not manage storage for regmaps. It is simply a wrapper.
◆ soft_regmap_db_t() [1/2]
uhd::soft_regmap_db_t::soft_regmap_db_t ( )
Use the default constructor if this is the top-level DB
◆ soft_regmap_db_t() [2/2]
uhd::soft_regmap_db_t::soft_regmap_db_t ( const std::string &  name)
Use this constructor if this is a nested DB
◆ add() [1/2]
void uhd::soft_regmap_db_t::add ( soft_regmap_t &  regmap)
Add a regmap to this map with an identifier "name" and visibility
◆ add() [2/2]
void uhd::soft_regmap_db_t::add ( soft_regmap_db_t &  db)
Add a level of regmap_db to this map with an identifier "name" and visibility
◆ enumerate()
std::vector<std::string> uhd::soft_regmap_db_t::enumerate ( ) const
inlineoverridevirtual
Enumerate the paths of all registers that this DB can access
◆ get_name()
const std::string& uhd::soft_regmap_db_t::get_name ( ) const
◆ lookup()
soft_register_base& uhd::soft_regmap_db_t::lookup ( const std::string &  path) const
Lookup a register by path. A path is defined as a string of "/" separated tokens that scope a register. The leaf (last token) is the name of the register The token immediately before the leaf is the name of the register map If a nested regmap_db is used, the token before the regmap is the db name. For every nested db, the path has an additional token. For example: radio0/spi_regmap/spi_control_reg
