Checklist:
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg, where <UHD_INSTALL_DIR> is the UHD installation directory.
The <YOUR_IMAGE> is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg).
$ ls /dev/serial/by-id usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0 usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to Linux, whereas the second connects to the STM32 microcontroller. If you have multiple N3XX devices connect, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
root@ni-n3xx-311FE00:~#
$ ssh [email protected]
Note: The device's hostname is derived from its serial number by default (ni-n3xx-$SERIAL). You can change the hostname by creating the file /data/network/hostname, saving the desired hostname in it, then rebooting.
The SFP+ (sfp0, sfp1) ports are configured with static addresses 192.168.10.2/24 and 192.168.20.2/24, respectively. Their default MTU value is 9000. These settings are independent of the image type (HG vs. XG), i.e., the defaults are the same for 1 GigE and 10 GigE (unlike the X310!).
The configuration for the sfpX port is stored in /data/network/sfpX.network.
eth0 (DHCP):
[Match]
Name=eth0
[Network]
DHCP=v4
[DHCPv4]
UseHostname=false
sfp0 (static):
[Match]
Name=sfp0
[Network]
Address=192.168.10.2/24
[Link]
MTUBytes=9000
sfp1 (static):
[Match]
Name=sfp1
[Network]
Address=192.168.20.2/24
[Link]
MTUBytes=9000
/data/network/sfp0.network~), that systemd-networkd might accidentally pick up.ifconfig or other command line tools will only change the value until the next reboot or reload of the FPGA image.The N3XX ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA follows the same procedure as other USRPs. Use the uhd_image_loader command line utility to upload a new FPGA image onto the device.
$ uhd_images_downloader
to update the FPGA using the default settings. If a custom FPGA image is targeted for uploading, use the --fpga-path command line argument. Run
$ uhd_image_loader --help
to see a full list of command line options. Note that updating the FPGA image will force a reload of the FPGA, which will temporarily take down the SFP network interfaces (and temporary settings, such as applied via ifconfig on the command line, will be lost).
| FPGA Image Flavor | SFP+ Port 0 Interface | SFP+ Port 1 Interface |
| HG (Default) | 1 Gigabit Ethernet | 10 Gigabit Ethernet |
| XG | 10 Gigabit Ethernet | 10 Gigabit Ethernet |
| HA | 1 Gigabit Ethernet | Aurora |
| XA | 10 Gigabit Ethernet | Aurora |
| AA | Aurora | Aurora |
| WX | White Rabbit | 10 Gigabit Ethernet |
| Key | Description | Supported Devices | Example Value |
| addr | IPv4 address of primary SFP+ port to connect to. | All N3xx | addr=192.168.30.2 |
| second_addr | IPv4 address of secondary SFP+ port to connect to. | All N3xx | second_addr=192.168.40.2 |
| mgmt_addr | IPv4 address or hostname which to connect the RPC client. Defaults to `addr'. | All N3xx | mgmt_addr=ni-sulfur-311FE00 (can also go to RJ45) |
| find_all | When using broadcast, find all devices, even if unreachable via CHDR. | All N3xx | find_all=1 |
| force_reinit | Force full reinitialization of all subsystems. Will increase init time. | N310 | force_reinit=1 |
| master_clock_rate | Master Clock Rate in Hz | N310 | master_clock_rate=125e6 |
| identify | Causes front-panel LEDs to blink. The duration is variable. | N310 | identify=5 (will blink for about 5 seconds) |
| serialize_init | Force serial initialization of motherboards. | All N3xx | serialize_init=1 |
| skip_init | Skip the initialization process for the device. | All N3xx | skip_init=1 |
| time_source | Specify the time (PPS) source. | All N3xx | time_source=internal |
| clock_source | Specify the reference clock source. | All N3xx | clock_source=internal |
| ref_clk_freq | Specify the external reference clock frequency, default is 10 MHz. | N310 | ref_clk_freq=20e6 |
| init_cals | Specify the bitmask for initial calibrations of the RFIC. | N310 | init_cals=BASIC |
| init_cals_timeout | Timeout for initial calibrations in milliseconds. | N310 | init_cals_timeout=45000 |
| discovery_port | Override default value for MPM discovery port. | All N3xx | discovery_port=49700 |
| rpc_port | Override default value for MPM RPC port. | All N3xx | rpc_port=49701 |
| tracking_cals | Specify the bitmask for tracking calibrations of the RFIC. | N310 | tracking_cals=ALL |
| rx_lo_source | Initialize the source for the RX LO. | N310 | rx_lo_source=external |
| tx_lo_source | Initialize the source for the TX LO. | N310 | tx_lo_source=external |
| rfic_digital_loopback | Digital data loopback inside the RFIC. | N310 | rfic_digital_loopback=1 |
| tx_gain_profile | Initialize device with a specific TX gain profile. | N310 | tx_gain_profile=manual |
| rx_gain_profile | Initialize device with a specific RX gain profile. | N310 | rx_gain_profile=manual |
| tx_band_map | Semicolon-separated list of TX band edges. | N310 | tx_band_map=0.0;723.18e6;1623.18e6;3323.18e6 |
| rx_band_map | Semicolon-separated list of RX band edges. | N310 | rx_band_map=0.0;431e6;601e6;1051e6;1601e6;2101e6;2701e6 |
To maximally speed up UHD, an initialization sequence is run when the device (or more accurately, the MPM service) starts. This means even on the first run of UHD, the device will already be initialized into a usable state. Note that it will always come up in a default state, which can be changed by modifying the configuration file in /etc/uhd/mpm.conf (see also Configuration Files), such as this:
If you prefer not to have the device initialize on boot, but rather have a fast boot time, add the line skip_boot_init=1 to your /etc/uhd/mpm.conf file. This will force a full initialization of the device the first time a UHD session is started, rather than during device boot.
| Label | Subdev Spec |
| RF0 | A:0 |
| RF1 | A:1 |
| RF2 | B:0 (N310 only) |
| RF3 | B:1 (N310 only) |
| RF0 | A:0 |
| RF1 | B:0 |
ref_locked: This will check that all the daughterboards have locked to the external reference.temp: The temperature of the die itselffan: The current fan speedgps_locked: GPS lockgps_time: GPS time in seconds sin ce the epchgps_tpv: A TPV report from GPSd serialized as JSONgps_sky: A SKY report from GPSd serialized as JSONMender is a third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Mender servers can be self-hosted, or hosted by Mender (see mender.io for pricing and availability).
$ reboot
$ mender commit
$ systemctl start salt-minion
apt install salt-master if the server is an Ubuntu system), and make sure the Salt master is running./etc/salt/minion file on the device by editing the master: line.systemctl start salt-minion.salt-key -a $hostname where $hostname is the name of the minion.$ [sudo] salt '*' test.ping
ni-n3xx-311FE00:
True
ni-n3xx-311FE00:
eth0:
hwaddr:
02:00:03:11:fe:00
inet:
|_
address:
10.16.32.113
broadcast:
10.16.33.255
label:
eth0
netmask:
255.255.254.0
up:
True
The N3xx series has an onboard GPSDO as well as a 25 MHz reference oscillator, which can both be used as time- and clock references. The GPSDO will function as a reference even when there is no GPS reception. It can be powered off to reduce power usage and interference by supplying the enable_gps=0 option in the configuration file (in this case, gpsdo cannot be used as a time or clock reference).
To reduce phase noise, it may be necessary to power down the GPSDO when using an external reference. To do this, just add enable_gps=False to the configuration file in /etc/uhd/mpm.conf (see also Configuration Files).
Note: When disabling the GPS with enable_gps=0 in the configuration file, or when manually launching MPM, the gpsdo reference source is not available.
Then, you can install the WX (or WA) image using uhd_image_loader:
$ uhd_image_loader \
--args type=n3xx,addr=ni-n3xx-<DEVICE_SERIAL>,WX
Once the image is loaded, select internal as the clock source and sfp0 as the time source (note: this will fail if the WX or WA image is not currently loaded):
The default MTU for the N3x0 series is 9000. The simplest solution is often to set the host computer MTU to 9000 as well:
$ [sudo] ifconfig eth0 mtu 9000 # Replace eth0 with the device you're using
The N3x0 series devices have a built-in self-test that can be used to verify the hardware. It is not automatically run, but it can be invoked anytime by running the n3xx_bist executable. Calling
n3xx_bist -h
n3xx_bist gpsdo
will test the functionality of the GPSDO. Calling n3xx_bist standard will run a standard set of tests, verifying some base peripherals such as the RTC, the fan and temperature sensors, etc.
Some tests require special hardware connected. For example, there are multiple tests to verify the SFP+ adapters. There are two types of test for those: For the sfp0_loopback and sfp1_loopback tests, a loopback module must be plugged into the SFP+. For the sfp_loopback test, the two ports need to be connected together.
$ mkdir uhd # Create a new, empty directory called uhd $ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the N3xx
$ mkdir build_mpm $ cd build_mpm # You are now in /home/root/build_mpm $ cmake ../uhd/mpm $ make -j2 install # This will take several minutes
$ $CC -dumpmachine
Note: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your N3xx.
This sequence can take a while, depending on the master clock rate and the calibration sequence. To speed things up, the device will retain a state between sessions, but only if no relevant settings were touched. In particular, changing the master clock rate, the clock source, or the calibration masks will force a full re-initialization which is very slow compared to the fast re-initialization. By setting the log level to DEBUG you will be able to observe the exact settings that cause fast vs. slow re-initialization. If you require a full re-initialization every time a UHD session is spawned, specify the force_reinit flag as a device arg. Specifying it will always do the full, slow initialization, but will guarantee a full reset of the RFIC.
If there are multiple N3x0 devices in a single UHD session, they will be initialized in parallel. Note that this behaviour can be changed serial initialization by adding serialize_init=1 to the device args (see Device arguments).
Not all calibrations available on the AD9371 are applicable to the USRP N310. However, those calibrations that are applicable can be enabled/disabled at initialization time using the tracking_cals and init_cals device args (see also Device arguments). These device can be set to the precise bit mask the chip uses to set those calibrations (e.g., init_cals=0x4DFF,tracking_cals=0xC3) or they can use the following descriptive keys provided by UHD (e.g.init_cals=DEFAULT,tracking_cals=TX_QEC|RX_QEC). The | symbol can be used to combine keys (equivalent to a bitwise OR).
Key (init_cal) | Function |
| TX_BB_FILTER | Tx baseband filter calibration |
| ADC_TUNER | ADC tuner calibration |
| TIA_3DB_CORNER | Rx TIA filter calibration |
| DC_OFFSET | Rx DC offset calibration |
| TX_ATTENUATION_DELAY | Tx attenuation delay |
| RX_GAIN_DELAY | Rx gain delay calibration |
| FLASH_CAL | ADC flash calibration |
| PATH_DELAY | Path delay calibration |
| TX_LO_LEAKAGE_INTERNAL | Tx LO leakage internal initial calibration |
| TX_LO_LEAKAGE_EXTERNAL | Tx LO leakage external initial calibration (requires external LO) |
| TX_QEC_INIT | Tx QEC initial |
| LOOPBACK_RX_LO_DELAY | Loopback ORx LO delay (ORx not connected by default!) |
| LOOPBACK_RX_RX_QEC_INIT | Loopback Rx QEC initial calibration |
| RX_LO_DELAY | Rx LO delay |
| RX_QEC_INIT | Rx QEC initial calibration |
| BASIC | Preset for minimal calibrations (TX_BB_FILTER, ADC_TUNER, TIA_3DB_CORNER, DC_OFFSET and FLASH_CAL) |
| OFF | Preset for disabling all initial calibrations |
| DEFAULT | Preset for enabling most calibrations (BASIC plus TX_ATTENUATION_DELAY, RX_GAIN_DELAY, PATH_DELAY, RX_QEC_INIT, TX_LO_LEAKAGE_INTERNAL, TX_QEC_INIT, LOOPBACK_RX_LO_DELAY) |
| ALL | Enable all applicable calibrations |
Key (tracking_cal) | Function |
| TRACK_RX1_QEC | Rx1 QEC tracking |
| TRACK_RX2_QEC | Rx2 QEC tracking |
| TRACK_ORX1_QEC | ORx1 QEC tracking |
| TRACK_ORX2_QEC | ORx1 QEC tracking |
| TRACK_TX1_LOL | Tx1 LO leakage tracking |
| TRACK_TX2_LOL | Tx2 LO leakage tracking |
| TRACK_TX1_QEC | Tx1 QEC tracking |
| TRACK_TX2_QEC | Tx2 QEC tracking |
| OFF | Disable all tracking |
| RX_QEC | Enable all RX QEC tracking |
| TX_QEC | Enable all TX QEC tracking |
| TX_LOL | Enable all TX LO leakage tracking |
| DEFAULT | Enable all QEC tracking |
| ALL | Enable all tracking (except ORx) |
| Module Revision | Motherboard Revision | Daughterboard Revision | Minimum UHD Version |
| A | D | D | 3.11.0.0 |
| B | F | E | 3.12.0.0 |
| C | G | E | 3.13.0.2 |
| D | H | E | 3.14.0.0 |
| Slave 0 | 4000_0000 - 4000_3fff | - | Ethernet DMA SFP0 |
| Slave 1 | 4000_4000 - 4000_4fff | misc-enet-regs0 | Ethernet registers SFP0 |
| Slave 2 | 4000_8000 - 4000_bfff | - | Ethernet DMA SFP1 |
| Slave 3 | 4000_c000 - 4000_cfff | misc-enet-regs1 | Ethernet registers SFP1 |
| Slave 4 | 4001_0000 - 4001_3fff | mboard-regs | Motherboard control |
| Slave 5 | 4001_4000 - 4001_41ff | dboard-regs0 | Daughterboard control, slot A |
| Slave 6 | 4001_8000 - 4001_bfff | dboard-regs1 | Daughterboard control, slot B |
| Slave 0 | axi_eth_dma0 | 4000_0000 - 4000_4fff | Ethernet DMA | RW | See Linux Driver |
| Slave 1 | n3xx_mgt_io_core | 4000_4000 | PORT_INFO | RO | SFP port information |
| n3xx_mgt_io_core | 4000_4004 | MAC_CTRL_STATUS | RW | Control 10gE and Aurora mac | |
| n3xx_mgt_io_core | 4000_4008 | PHY_CTRL_STATUS | RW | Phy reset control | |
| n3xx_mgt_io_core | 4000_400C | MAC_LED_CTL | RW | Used by ethtool to indicate port | |
| n3xx_mgt_io_core | 4000_4020 | AURORA_OVERUNS | RO | - | |
| 4000_600c | [1] my_icmp_type, [0] my_icmp_code | ||||
| Slave 2 | axi_eth_dma1 | 4000_8000 | - | Same as Slave 0, different base address | |
| Slave 3 | n3xx_mgt_io_core | 4000_c001 - 4000_cfff | - | - | Same as Slave 1, different base address |
| eth_dispatch | 4000_d000 - 4000_dfff | - | - | Same as Slave 1, different base address | |
| eth_switch | 4000_e000 - 4000_efff | - | - | Same as Slave 1, different base address | |
| Slave 4 | n3xx_core | 4001_0000 | COMPAT_NUM | R | FPGA Compat Number |
| 4001_0018 | CLOCK_CTRL | ||||
| [0] | pps select (internal 10 MHz) | RW | One-hot encoded pps_select to use the external PPS input. | ||
| [1] | pps select (internal 25 MHz) | RW | One-hot encoded pps_select to use the internally generated PPS with a 10 MHz ref_clk. | ||
| [2] | pps select (external) | RW | One-hot encoded pps_select to use the internally generated PPS with a 25 MHz ref_clk. | ||
| [3] | pps select (GPSDO) | RW | One-hot encoded pps_select to use the PPS from the GPSDO input to the FPGA. | ||
| [4] | pps output enable | RW | |||
| [8] | ref clk mmcm reset | WO | - | ||
| [9] | ref clk mmcm locked | RO | - | ||
| [12] | meas clk mmcm reset | WO | - | ||
| [13] | meas clk mmcm locked | RO | - | ||
| [11:0] | FPGA temperature | RO | |||
| 4001_0028 | SFP_PORT0_INFO | RO | - | ||
| 4001_002C | SFP_PORT1_INFO | RO | - | ||
| 4001_0030 | FP_GPIO_MASTER | RO | GPIO master select bits. One bit per GPIO. LSB is for GPIO 0. Set bit to 0 for Radio, 1 for PS. | ||
| 4001_0034 | FP_GPIO_RADIO_SRC | RO | Radio channel source select bits. Two bits per GPIO. Bits [1:0] are for GPIO 0. Set to 00 for channel 0, 01 for channel 1, etc. | ||
| n3xx_mgt_io_core (NPIO0) | 4001_0200 | PORT_INFO | RO | ||
| 4001_0204 | MAC_CTRL_STATUS | RW | |||
| 4001_0208 | PHY_CTRL_STATUS | RW | |||
| 4001_0220 | AURORA_OVERUNS | RO | |||
| 4001_0224 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_0228 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_022c | AURORA_BIST_CHECKER_ERRORS | RO | |||
| n3xx_mgt_io_core (NPIO1) | 4001_0240 | PORT_INFO | RO | ||
| 4001_0244 | MAC_CTRL_STATUS | RW | |||
| 4001_0248 | PHY_CTRL_STATUS | RW | |||
| 4001_0260 | AURORA_OVERUNS | RO | |||
| 4001_0264 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_0268 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_026c | AURORA_BIST_CHECKER_ERRORS | RO | |||
| n3xx_mgt_io_core (QSFP0) | 4001_0280 | PORT_INFO | RO | ||
| 4001_0284 | MAC_CTRL_STATUS | RW | |||
| 4001_0288 | PHY_CTRL_STATUS | RW | |||
| 4001_02a0 | AURORA_OVERUNS | RO | |||
| 4001_02a4 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_02a8 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_02ac | AURORA_BIST_CHECKER_ERRORS | RO | |||
| n3xx_mgt_io_core (QSFP1) | 4001_02c0 | PORT_INFO | RO | ||
| 4001_02c4 | MAC_CTRL_STATUS | RW | |||
| 4001_02c8 | PHY_CTRL_STATUS | RW | |||
| 4001_02e0 | AURORA_OVERUNS | RO | |||
| 4001_02e4 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_02e8 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_02ec | AURORA_BIST_CHECKER_ERRORS | RO | |||
| n3xx_mgt_io_core (QSFP2) | 4001_0300 | PORT_INFO | RO | ||
| 4001_0304 | MAC_CTRL_STATUS | RW | |||
| 4001_0308 | PHY_CTRL_STATUS | RW | |||
| 4001_0320 | AURORA_OVERUNS | RO | |||
| 4001_0324 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_0328 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_032c | AURORA_BIST_CHECKER_ERRORS | RO | |||
| n3xx_mgt_io_core (QSFP3) | 4001_0340 | PORT_INFO | RO | ||
| 4001_0344 | MAC_CTRL_STATUS | RW | |||
| 4001_0348 | PHY_CTRL_STATUS | RW | |||
| 4001_0360 | AURORA_OVERUNS | RO | |||
| 4001_0364 | AURORA_CHECKSUM_ERRORS | RO | |||
| 4001_0368 | AURORA_BIST_CHECKER_SAMPS | RO | |||
| 4001_036C | AURORA_BIST_CHECKER_ERRORS | RO | |||
| Slave 5 | 4001_4000 | 4001_41FF | Clocking | see Clocking regmap | |
| 4001_4200 | 4001_43FF | Sync | see Sync regmap | ||
| 4001_4400 | 4001_45FF | open | open | open | |
| 4001_4600 | 4001_47FF | Daughterboard | see Daughterboard regmap (EISCAT) | ||
| 4001_6000 | 4001_6FFF | JESD Core 0 | see JESD regmap (EISCAT) | ||
| 4001_7000 | 4001_7FFF | JESD Core 1 | see JESD regmap (EISCAT) | ||
| Slave 6 | 4001_8000 - 4001_bfff | see above | - | same as Slave 5 |
EEPROM flags can be set with
$ eeprom-set-flags 0xFLAGS
| Bit | Description |
| 0 | Auto-boot (1=on) |
| 2 | TPM (0=present) |
$ eeprom-set-flags 0x1
The N310 supports four gain profiles: default, manual, default_rf_filter_bypass_always_on, and default_rf_filter_bypass_always_off.
Usually, UHD will program individual gain components to create an overall gain that is selected. The N310 daughterboards have three gain stages per path (two digital step attenuators (DSAs), and one amplifier). When using the manual profile, the DSAs and amplifiers can be programmed directly. In the other gain profiles, a single, overall gain can be given, and UHD will attempt to program the gain stages based on hard-coded gain tables. The difference between the three "default" profiles is how the amplifier is used: Either it is always on, always off, or it is switched on and off to optimize linearity.
Note: This is a highly advanced feature. Most users will not have to use this!
The N310 daughterboard splits the TX and RX paths into 4 and 7 different bands, respectively, to hardware-optimize the RF fidelity at all available frequencies.
See the schematics for more details.
Using the rx_band_map and tx_band_map device args, it is possible to move the band edges in software. This may be useful if the hardware was modified to use different filters, for example, because a signal of interest always falls onto a band edge. Using the tx_band_map or rx_band_map device arguments, you can provide a list of lower band edges for every band. Make sure to provide 4 (for Tx) or 7 (for Rx) floating-point values. The first value should always be zero (0.0). It may make sense to encode these values in your uhd.conf file:
The N300/N310 utilize the Analog Devices AD9371 AFE which contain programmable FIR filters in both the transmit and receive paths for each of the RF channels. These filters are available using the Digital Filter API in UHD.
| Filter Name | AD9371 Channel | Max Taps |
| RX1_FIR | 1 | 48 |
| RX2_FIR | 2 | 48 |
| RX1RX2_FIR | 1 and 2 | 48 |
| TX1_FIR | 1 | 32 |
| TX2_FIR | 2 | 32 |
| TX1TX2_FIR | 1 and 2 | 32 |
Each filter is applied at 2x the master_clock_rate, or 250 MHz by default.
The Filter API also allows to set some 3 dB analog filters on the AD9371 through the set_tx_bandwidth and set_rx_bandwidth UHD functions.
This is a small example on how to set the TX FIR and TX bandwidth.
This sequence can take a while, depending on the master clock rate and the calibration sequence. To speed things up, the device will retain a state between sessions, but only if no relevant settings were touched. In particular, changing the master clock rate or the clock source will force a full re-initialization which is slower compared to the fast re-initialization. By setting the log level to DEBUG you will be able to observe the exact settings that cause fast vs. slow re-initialization. If you require a full re-initialization every time a UHD session is spawned, specify the force_reinit flag as a device arg. Specifying it will always do the full, slow initialization, but will guarantee a full reset digital chains.
The N320/N321 can perform some simple calibration for I/Q imbalance and DC offset, the same way as the X300 series. Refer to Device Calibration and Frontend Correction for more details.
| Interface | HG | XG | WX | XQ | AQ |
| SFP+ 0 | 1 GbE | 10 GbE | White Rabbit | White Rabbit | 10 GbE |
| SFP+ 1 | 10 GbE | 10 GbE | 10 GbE | Unused | 10 GbE |
| QSFP+ lane 0 | Unused | Unused | Unused | 10 GbE | Aurora |
| QSFP+ lane 1 | Unused | Unused | Unused | 10 GbE | Aurora |
| QSFP+ lane 2 | Unused | Unused | Unused | Unused | Aurora |
| QSFP+ lane 3 | Unused | Unused | Unused | Unused | Aurora |
In an unmodified FPGA image, N320/N321 perform several steps of digital signal processing between the RFNoC Radio block and the ADC/DAC.
It should be noted that the DACs/ADCs run at twice the master clock rate (e.g., if the master clock rate is 250 MHz, the DACs/ADCs are clocked at 500 MHz). We perform a sample rate conversion to the master clock rate within the FPGA.
The IQ and DC offset compensation components can be controlled from the host side using the correction APIs. The following snippet shows the control of these APIs from the host side using the multi_usrp APIs:
When using the RFNoC API, use the uhd::rfnoc::radio_control API calls with the same names.
Notes:
The halfband decimators/interpolators are not configurable. They are 47-tap halfband filters with the following coefficients:
-62, 0, 194, 0, -440, 0, 855, 0, -1505, 0, 2478, 0, -3900, 0, 5990, 0, -9187, 0, 14632, 0, -26536, 0, 83009, 131071, 83009, 0, -26536, 0, 14632, 0, -9187, 0, 5990, 0, -3900, 0, 2478, 0, -1505, 0, 855, 0, -440, 0 194, 0, -62.
| Bit | Description |
