uhd::rfnoc::noc_block_base::make_args_t Struct Reference
#include <uhd/rfnoc/noc_block_make_args.hpp>
 ~make_args_t ()
Public Attributes
noc_id_t noc_id
 Noc-ID. More...
block_id_t block_id
 Block ID (e.g. 0/Radio#0) More...
size_t num_input_ports
 Number of input ports (gets reported from the FPGA) More...
size_t num_output_ports
 Number of output ports (gets reported from the FPGA) More...
size_t mtu
 Value of the MTU register, converted to bytes. More...
chdr_w_t chdr_w
 CHDR width of this block. More...
register_iface::sptr reg_iface
 Register interface to this block's register space. More...
std::shared_ptr< clock_iface > tb_clk_iface
 Timebase clock interface object that is shared with the reg_iface. More...
std::shared_ptr< clock_iface > ctrlport_clk_iface
 Controlport clock interface object that is shared with the reg_iface. More...
std::shared_ptr< mb_controllermb_control
 Reference to the motherboard controller associated with this block. More...
uhd::property_tree::sptr tree
 The subtree for this block. More...
uhd::device_addr_t args
 Additional args that can be parsed and used by this block. More...
Data structure to hold the arguments passed into the noc_block_base ctor
We want to hide these from the user, so she can't futz around with them. Hence the opaque pointer, and non-UHD_API implementation.
◆ ~make_args_t()
uhd::rfnoc::noc_block_base::make_args_t::~make_args_t ( )
◆ args
uhd::device_addr_t uhd::rfnoc::noc_block_base::make_args_t::args
◆ block_id
block_id_t uhd::rfnoc::noc_block_base::make_args_t::block_id
◆ chdr_w
chdr_w_t uhd::rfnoc::noc_block_base::make_args_t::chdr_w
◆ ctrlport_clk_iface
std::shared_ptr<clock_iface> uhd::rfnoc::noc_block_base::make_args_t::ctrlport_clk_iface
◆ mb_control
std::shared_ptr<mb_controller> uhd::rfnoc::noc_block_base::make_args_t::mb_control
◆ mtu
size_t uhd::rfnoc::noc_block_base::make_args_t::mtu
◆ noc_id
noc_id_t uhd::rfnoc::noc_block_base::make_args_t::noc_id
Noc-ID.
◆ num_input_ports
size_t uhd::rfnoc::noc_block_base::make_args_t::num_input_ports
◆ num_output_ports
size_t uhd::rfnoc::noc_block_base::make_args_t::num_output_ports
◆ reg_iface
register_iface::sptr uhd::rfnoc::noc_block_base::make_args_t::reg_iface
◆ tb_clk_iface
std::shared_ptr<clock_iface> uhd::rfnoc::noc_block_base::make_args_t::tb_clk_iface
◆ tree
uhd::property_tree::sptr uhd::rfnoc::noc_block_base::make_args_t::tree
