#include <uhd/rfnoc/actions.hpp>
 Public Types | |
| using | sptr = std::shared_ptr< rx_event_action_info > |
  Public Types inherited from uhd::rfnoc::action_info | |
| using | sptr = std::shared_ptr< action_info > |
| static sptr | make (uhd::rx_metadata_t::error_code_t error_code) |
| Factory function.  More... | |
  Static Public Member Functions inherited from uhd::rfnoc::action_info | |
| static sptr | make (const std::string &key="", const uhd::device_addr_t &args=uhd::device_addr_t("")) |
Public Attributes | |
| uhd::rx_metadata_t::error_code_t | error_code |
| The error code that describes the event.  More... | |
  Public Attributes inherited from uhd::rfnoc::action_info | |
| const size_t | id |
| A unique counter for this action.  More... | |
| std::string | key |
| A string identifier for this action.  More... | |
| std::vector< uint8_t > | payload |
| An arbitrary payload. It is up to consumers and producers to.  More... | |
| uhd::device_addr_t | args |
| A dictionary of key-value pairs. May be used as desired.  More... | |
Protected Member Functions | |
| rx_event_action_info (uhd::rx_metadata_t::error_code_t error_code) | |
  Protected Member Functions inherited from uhd::rfnoc::action_info | |
| action_info (const std::string &key, const uhd::device_addr_t &args=uhd::device_addr_t("")) | |
| virtual | ~action_info () |
| using uhd::rfnoc::rx_event_action_info::sptr = std::shared_ptr<rx_event_action_info> |
  protected |
Factory function.
| uhd::rx_metadata_t::error_code_t uhd::rfnoc::rx_event_action_info::error_code |
