uhd::extension::extension Class Referenceabstract
#include <uhd/extension/extension.hpp>
Inheritance diagram for uhd::extension::extension:
uhd::rfnoc::rf_control::core_iface uhd::rfnoc::rf_control::power_reference_iface
Classes
struct  factory_args
using sptr = std::shared_ptr< extension >
using factory_type = std::function< sptr(factory_args)>
- Public Types inherited from uhd::rfnoc::rf_control::core_iface
using sptr = std::shared_ptr< core_iface >
- Public Types inherited from uhd::rfnoc::rf_control::power_reference_iface
using sptr = std::shared_ptr< power_reference_iface >
virtual ~extension ()=default
virtual std::string get_name ()=0
- Public Member Functions inherited from uhd::rfnoc::rf_control::core_iface
virtual ~core_iface ()=default
virtual std::string get_tx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_tx_antennas (const size_t chan) const =0
virtual void set_tx_antenna (const std::string &ant, const size_t chan)=0
virtual std::string get_rx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_rx_antennas (const size_t chan) const =0
virtual void set_rx_antenna (const std::string &ant, const size_t chan)=0
virtual double get_tx_frequency (const size_t chan)=0
virtual double set_tx_frequency (const double freq, size_t chan)=0
virtual void set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range (const size_t chan) const =0
virtual double get_rx_frequency (const size_t chan)=0
virtual double set_rx_frequency (const double freq, const size_t chan)=0
virtual void set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range (const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_tx_gain (const size_t chan)=0
virtual double get_tx_gain (const std::string &name, const size_t chan)=0
virtual double set_tx_gain (const double gain, const size_t chan)=0
virtual double set_tx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_rx_gain (const size_t chan)=0
virtual double get_rx_gain (const std::string &name, const size_t chan)=0
virtual double set_rx_gain (const double gain, const size_t chan)=0
virtual double set_rx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_agc (const bool enable, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan) const =0
virtual double get_tx_bandwidth (const size_t chan)=0
virtual double set_tx_bandwidth (const double bandwidth, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan) const =0
virtual double get_rx_bandwidth (const size_t chan)=0
virtual double set_rx_bandwidth (const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0
virtual void set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_rx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq (const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_tx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan)=0
- Public Member Functions inherited from uhd::rfnoc::rf_control::power_reference_iface
virtual ~power_reference_iface ()=default
virtual bool has_rx_power_reference (const size_t chan=0)=0
virtual void set_rx_power_reference (const double power_dbm, const size_t chan=0)=0
virtual double get_rx_power_reference (const size_t chan=0)=0
virtual std::vector< std::string > get_rx_power_ref_keys (const size_t chan=0)=0
virtual meta_range_t get_rx_power_range (const size_t chan)=0
virtual bool has_tx_power_reference (const size_t chan=0)=0
virtual void set_tx_power_reference (const double power_dbm, const size_t chan=0)=0
virtual double get_tx_power_reference (const size_t chan=0)=0
virtual std::vector< std::string > get_tx_power_ref_keys (const size_t chan=0)=0
virtual meta_range_t get_tx_power_range (const size_t chan)=0
static void register_extension (const std::string &extension_name, extension::factory_type factory_fn)
Common base class for RF extensions
◆ factory_type
using uhd::extension::extension::sptr = std::shared_ptr<extension>
◆ ~extension()
virtual uhd::extension::extension::~extension ( )
virtualdefault
◆ get_name()
virtual std::string uhd::extension::extension::get_name ( )
◆ register_extension()
static void uhd::extension::extension::register_extension ( const std::string &  extension_name,
