uhd::rfnoc::chdr::chdr_header Class Reference
 chdr_header ()=default
 chdr_header (const chdr_header &rhs)=default
 chdr_header (chdr_header &&rhs)=default
 chdr_header (uint64_t flat_hdr)
 Unpack the header from a uint64_t. More...
uint8_t get_vc () const
 Get the virtual channel field (6 bits) More...
void set_vc (uint8_t vc)
 Set the virtual channel field (6 bits) More...
bool get_eob () const
 Get the end-of-burst flag (1 bit) More...
void set_eob (bool eob)
 Set the end-of-burst flag (1 bit) More...
bool get_eov () const
 Get the end-of-vector flag (1 bit) More...
void set_eov (bool eov)
 Set the end-of-vector flag (1 bit) More...
packet_type_t get_pkt_type () const
 Get the packet type field (3 bits) More...
void set_pkt_type (packet_type_t pkt_type)
 Set the packet type field (3 bits) More...
uint8_t get_num_mdata () const
 Get number of metadata words field (5 bits) More...
void set_num_mdata (uint8_t num_mdata)
 Set number of metadata words field (5 bits) More...
uint16_t get_seq_num () const
 Get the sequence number field (16 bits) More...
void set_seq_num (uint16_t seq_num)
 Set the sequence number field (16 bits) More...
uint16_t get_length () const
 Get the packet length field (16 bits) More...
void set_length (uint16_t length)
 Set the packet length field (16 bits) More...
uint16_t get_dst_epid () const
 Get the destination EPID field (16 bits) More...
void set_dst_epid (uint16_t dst_epid)
 Set the destination EPID field (16 bits) More...
uint64_t pack () const
 Pack the header into a uint64_t. More...
 operator uint64_t () const
 Pack the header into a uint64_t as an implicit cast. More...
bool operator== (const chdr_header &rhs) const
 Comparison operator (==) More...
bool operator!= (const chdr_header &rhs) const
 Comparison operator (!=) More...
const chdr_headeroperator= (const chdr_header &rhs)
 Assignment operator (=) from a chdr_header. More...
const chdr_headeroperator= (const uint64_t &rhs)
 Assignment operator (=) from a uint64_t. More...
const std::string to_string () const
 Return a string representation of this object. More...
◆ chdr_header() [1/4]
uhd::rfnoc::chdr::chdr_header::chdr_header ( )
default
◆ chdr_header() [2/4]
uhd::rfnoc::chdr::chdr_header::chdr_header ( const chdr_header rhs)
default
◆ chdr_header() [3/4]
uhd::rfnoc::chdr::chdr_header::chdr_header ( chdr_header &&  rhs)
default
◆ chdr_header() [4/4]
uhd::rfnoc::chdr::chdr_header::chdr_header ( uint64_t  flat_hdr)
◆ get_dst_epid()
uint16_t uhd::rfnoc::chdr::chdr_header::get_dst_epid ( ) const
◆ get_eob()
bool uhd::rfnoc::chdr::chdr_header::get_eob ( ) const
◆ get_eov()
bool uhd::rfnoc::chdr::chdr_header::get_eov ( ) const
◆ get_length()
uint16_t uhd::rfnoc::chdr::chdr_header::get_length ( ) const
◆ get_num_mdata()
uint8_t uhd::rfnoc::chdr::chdr_header::get_num_mdata ( ) const
◆ get_pkt_type()
packet_type_t uhd::rfnoc::chdr::chdr_header::get_pkt_type ( ) const
◆ get_seq_num()
uint16_t uhd::rfnoc::chdr::chdr_header::get_seq_num ( ) const
◆ get_vc()
uint8_t uhd::rfnoc::chdr::chdr_header::get_vc ( ) const
◆ operator uint64_t()
uhd::rfnoc::chdr::chdr_header::operator uint64_t ( ) const
◆ operator!=()
bool uhd::rfnoc::chdr::chdr_header::operator!= ( const chdr_header rhs) const
◆ operator=() [1/2]
const chdr_header& uhd::rfnoc::chdr::chdr_header::operator= ( const chdr_header rhs)
◆ operator=() [2/2]
const chdr_header& uhd::rfnoc::chdr::chdr_header::operator= ( const uint64_t &  rhs)
◆ operator==()
bool uhd::rfnoc::chdr::chdr_header::operator== ( const chdr_header rhs) const
◆ pack()
uint64_t uhd::rfnoc::chdr::chdr_header::pack ( ) const
◆ set_dst_epid()
void uhd::rfnoc::chdr::chdr_header::set_dst_epid ( uint16_t  dst_epid)
◆ set_eob()
void uhd::rfnoc::chdr::chdr_header::set_eob ( bool  eob)
◆ set_eov()
void uhd::rfnoc::chdr::chdr_header::set_eov ( bool  eov)
◆ set_length()
void uhd::rfnoc::chdr::chdr_header::set_length ( uint16_t  length)
◆ set_num_mdata()
void uhd::rfnoc::chdr::chdr_header::set_num_mdata ( uint8_t  num_mdata)
◆ set_pkt_type()
void uhd::rfnoc::chdr::chdr_header::set_pkt_type ( packet_type_t  pkt_type)
◆ set_seq_num()
void uhd::rfnoc::chdr::chdr_header::set_seq_num ( uint16_t  seq_num)
◆ set_vc()
void uhd::rfnoc::chdr::chdr_header::set_vc ( uint8_t  vc)
◆ to_string()
const std::string uhd::rfnoc::chdr::chdr_header::to_string ( void  ) const
