soft_regmap_t (const std::string &name) | |
~soft_regmap_t () override | |
UHD_INLINE const std::string & | get_name () const override |
void | initialize (wb_iface &iface, bool sync=false) |
void | flush () |
void | refresh () |
soft_register_base & | lookup (const std::string &name) const override |
std::vector< std::string > | enumerate () const override |
Public Member Functions inherited from uhd::soft_regmap_accessor_t | |
virtual | ~soft_regmap_accessor_t () |
Protected Types | |
enum | visibility_t { PUBLIC , PRIVATE } |
Protected Member Functions | |
UHD_INLINE void | add_to_map (soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE) |
Public Types inherited from uhd::soft_regmap_accessor_t | |
typedef std::shared_ptr< soft_regmap_accessor_t > | sptr |
A regmap is a collection of registers that share the same bus (control iface). A regmap must have an identifier. A regmap must manage storage for each register. The recommended way to use a regmap is to define individual registers within the scope of the regmap and instantiate them in the ragmap. Soft register object that holds offset, soft-copy and the control iface. Methods give convenient field-level access to soft-copy and the ability to do read-modify-write operations.
protected |
inline |
inlineoverride |
inlineprotected |
Add a register to this map with an identifier "name" and visibility
inlineoverridevirtual |
Enumerate all the registers in this map. Return fully qualified paths.
inline |
Flush all registers to hardware. The order of writing is the same as the order in which registers were added to the map.
inline |
Initialize all registers in this register map using a bus. Optionally synchronize the register with hardware. The order of initialization is the same as the order in which registers were added to the map.
Lookup a register object by name. If a register with "name" is not found, runtime_error is thrown
inline |
Refresh all register soft-copies from hardware. The order of reading is the same as the order in which registers were added to the map.
