exception.hpp File Reference
#include <uhd/config.hpp>
#include <stdexcept>
#include <string>
Classes
struct  uhd::exception
struct  uhd::assertion_error
struct  uhd::lookup_error
struct  uhd::index_error
struct  uhd::key_error
struct  uhd::type_error
struct  uhd::value_error
struct  uhd::narrowing_error
struct  uhd::runtime_error
struct  uhd::usb_error
struct  uhd::not_implemented_error
struct  uhd::access_error
struct  uhd::environment_error
struct  uhd::io_error
struct  uhd::os_error
struct  uhd::system_error
struct  uhd::syntax_error
struct  uhd::rfnoc_error
struct  uhd::op_failed
struct  uhd::op_timeout
struct  uhd::op_seqerr
struct  uhd::op_timerr
struct  uhd::resolve_error
struct  uhd::routing_error
Namespaces
 uhd
Macros
#define UHD_THROW_SITE_INFO(what)
#define UHD_THROW_INVALID_CODE_PATH()    throw uhd::system_error(UHD_THROW_SITE_INFO("invalid code path"))
#define UHD_ASSERT_THROW(code)
◆ UHD_ASSERT_THROW
#define UHD_ASSERT_THROW (   code)
Value:
if (not(code)) \
Definition: exception.hpp:304
Definition: exception.hpp:48
codethe code that resolved to a boolean
◆ UHD_THROW_INVALID_CODE_PATH
#define UHD_THROW_INVALID_CODE_PATH ( )     throw uhd::system_error(UHD_THROW_SITE_INFO("invalid code path"))
◆ UHD_THROW_SITE_INFO
#define UHD_THROW_SITE_INFO (   what)
Value:
std::string(std::string(what) + "\n" + " in " + std::string(UHD_FUNCTION) + "\n" \
+ " at " + std::string(__FILE__) + ":" + BOOST_STRINGIZE(__LINE__) \
+ "\n")
#define UHD_FUNCTION
Definition: config.hpp:121
Create a formatted string with throw-site information. Fills in the function name, file name, and line number.
whatthe std::exception message
the formatted exception message
