11 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
12 #define UHD_USRP_MULTI_USRP_GET_RATES_API
13 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
14 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
15 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
16 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
17 #define UHD_USRP_MULTI_USRP_USER_REGS_API
18 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
19 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
20 #define UHD_USRP_MULTI_USRP_GPIO_API
21 #define UHD_USRP_MULTI_USRP_REGISTER_API
22 #define UHD_USRP_MULTI_USRP_FILTER_API
23 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
24 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
25 #define UHD_USRP_MULTI_USRP_POWER_LEVEL
47 namespace uhd {
namespace usrp {
98 typedef std::shared_ptr<multi_usrp>
sptr;
269 const time_spec_t& time_spec,
size_t mboard = ALL_MBOARDS) = 0;
300 const time_spec_t& time_spec,
365 const stream_cmd_t& stream_cmd,
size_t chan = ALL_CHANS) = 0;
410 const std::string&
source,
const size_t mboard = ALL_MBOARDS) = 0;
477 const std::string&
source,
504 const std::string& time_source,
505 const size_t mboard = ALL_MBOARDS) = 0;
538 const device_addr_t& sync_source,
569 const bool enb,
586 const bool enb,
600 const std::string& name,
size_t mboard = 0) = 0;
619 const uint8_t addr,
const uint32_t data,
685 template <
typename T>
688 return std::dynamic_pointer_cast<T>(get_extension(trx, chan));
737 virtual void set_rx_rate(
double rate,
748 virtual void set_rx_spp(
const size_t spp,
const size_t chan = ALL_CHANS) = 0;
839 const std::string& src,
const std::string& name = ALL_LOS,
size_t chan = 0) = 0;
850 const std::string& name = ALL_LOS,
865 const std::string& name = ALL_LOS,
878 bool enabled,
886 const std::string& name = ALL_LOS,
913 double freq,
937 const std::string& name,
969 const std::string& name = ALL_LOS,
970 const size_t chan = 0) = 0;
981 const std::string& name = ALL_LOS,
994 const std::string& name = ALL_LOS,
1007 const bool enabled,
1015 const std::string& name = ALL_LOS,
1042 const double freq,
1066 const std::string& name,
1084 virtual void set_rx_gain(
double gain,
1109 const std::string& profile,
1121 return this->set_rx_gain(gain, ALL_GAINS, chan);
1169 virtual double get_rx_gain(
1174 return this->get_rx_gain(ALL_GAINS, chan);
1201 return this->get_rx_gain_range(ALL_GAINS, chan);
1307 const std::complex<double>& offset,
1331 const std::complex<double>& correction,
1370 const double power_dbm,
1509 virtual void set_tx_gain(
double gain,
1534 const std::string& profile,
1546 return this->set_tx_gain(gain, ALL_GAINS, chan);
1570 virtual double get_tx_gain(
1575 return this->get_tx_gain(ALL_GAINS, chan);
1602 return this->get_tx_gain_range(ALL_GAINS, chan);
1649 const double power_dbm,
1756 const std::complex<double>& offset,
1772 const std::complex<double>& correction,
1838 const std::string& attr,
1839 const uint32_t value,
1840 const uint32_t
mask = 0xffffffff,
1841 const size_t mboard = 0) = 0;
1863 const std::string& bank,
1894 const std::string& bank,
1906 const std::string& bank,
1923 const std::vector<std::string>& src,
1924 const size_t mboard = 0) = 0;
1947 const std::string& name,
const size_t chan) = 0;
1958 const size_t chan) = 0;
1978 const std::string& name,
1989 const size_t chan) = 0;
std::shared_ptr< device > sptr
Definition: device.hpp:29
std::shared_ptr< extension > sptr
Definition: extension.hpp:38
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
Definition: property_tree.hpp:223
Definition: mb_controller.hpp:28
Definition: radio_control.hpp:105
Definition: stream.hpp:169
Definition: time_spec.hpp:31
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:56
Definition: multi_usrp.hpp:96
virtual std::vector< std::string > get_gpio_src_banks(const size_t mboard=0)=0
virtual void set_rx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard=0)=0
virtual meta_range_t get_rx_power_range(const size_t chan)=0
virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args)=0
Convenience method to get a TX streamer. See also uhd::device::get_tx_stream().
virtual std::vector< std::string > get_rx_filter_names(const size_t chan)=0
virtual std::vector< std::string > get_gpio_src(const std::string &bank, const size_t mboard=0)=0
virtual std::vector< std::string > get_tx_gain_profile_names(const size_t chan=0)=0
Definition: multi_usrp.hpp:1544
virtual std::string get_time_source(const size_t mboard)=0
virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_master_clock_rate_range(const size_t mboard=0)=0
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
virtual dict< std::string, std::string > get_usrp_rx_info(size_t chan=0)=0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual std::string get_clock_source(const size_t mboard)=0
virtual void set_rx_spp(const size_t spp, const size_t chan=ALL_CHANS)=0
static const size_t ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
virtual double get_tx_bandwidth(size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_profile_names(const size_t chan=0)=0
virtual void set_tx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_tx_filter_names(const size_t chan)=0
virtual std::vector< std::string > get_gpio_srcs(const std::string &bank, const size_t mboard=0)=0
virtual device_addr_t get_sync_source(const size_t mboard)=0
virtual double get_tx_rate(size_t chan=0)=0
virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard=0)=0
virtual void set_rx_gain_profile(const std::string &profile, const size_t chan=0)=0
virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan=0)=0
virtual std::vector< std::string > get_tx_sensor_names(size_t chan=0)=0
virtual std::string get_rx_subdev_name(size_t chan=0)=0
virtual void set_time_now(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual std::vector< std::string > get_rx_lo_names(size_t chan=0)=0
virtual meta_range_t get_tx_rates(size_t chan=0)=0
virtual std::vector< std::string > get_tx_antennas(size_t chan=0)=0
virtual void set_time_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual std::vector< std::string > get_mboard_sensor_names(size_t mboard=0)=0
virtual double get_rx_lo_freq(const std::string &name, size_t chan=0)=0
virtual double set_rx_lo_freq(double freq, const std::string &name, size_t chan=0)=0
virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual size_t get_tx_num_channels(void)=0
virtual double get_tx_power_reference(const size_t chan=0)=0
virtual std::vector< std::string > get_clock_sources(const size_t mboard)=0
virtual void set_time_unknown_pps(const time_spec_t &time_spec)=0
virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_rx_lo_export_enabled(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_names(size_t chan=0)=0
virtual std::string get_tx_subdev_name(size_t chan=0)=0
virtual double get_rx_gain(const std::string &name, size_t chan=0)=0
virtual const std::string get_rx_lo_source(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual void set_rx_bandwidth(double bandwidth, size_t chan=0)=0
virtual void set_tx_antenna(const std::string &ant, size_t chan=0)=0
virtual meta_range_t get_tx_power_range(const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_gpio_src(const std::string &bank, const std::vector< std::string > &src, const size_t mboard=0)=0
virtual bool get_tx_lo_export_enabled(const std::string &name=ALL_LOS, const size_t chan=0)=0
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:109
virtual std::string get_rx_gain_profile(const size_t chan=0)=0
virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args)=0
Convenience method to get a RX streamer. See also uhd::device::get_rx_stream().
virtual time_spec_t get_time_last_pps(size_t mboard=0)=0
virtual void set_time_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0
virtual std::vector< std::string > get_tx_lo_names(size_t chan=0)=0
virtual void set_rx_iq_balance(const bool enb, size_t chan)=0
virtual void set_rx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_gpio_banks(const size_t mboard)=0
virtual void set_clock_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual void clear_command_time(size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_dc_offset_range(size_t chan=0)=0
Definition: multi_usrp.hpp:1573
Definition: multi_usrp.hpp:1172
virtual double get_normalized_rx_gain(size_t chan=0)=0
virtual void set_sync_source(const device_addr_t &sync_source, const size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_rates(size_t chan=0)=0
virtual ~multi_usrp(void)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan=0)=0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan=0)=0
Definition: multi_usrp.hpp:1600
virtual void set_rx_antenna(const std::string &ant, size_t chan=0)=0
virtual void set_clock_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual uhd::rfnoc::radio_control & get_radio_control(const size_t chan=0)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_rx_antennas(size_t chan=0)=0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan=0)=0
virtual void set_rx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan=0)=0
Definition: multi_usrp.hpp:1199
virtual std::string get_tx_antenna(size_t chan=0)=0
virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain_profile(const std::string &profile, const size_t chan=0)=0
Definition: multi_usrp.hpp:1119
virtual const std::string get_tx_lo_source(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard=0)=0
virtual void set_rx_lo_source(const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual std::vector< std::string > get_rx_sensor_names(size_t chan=0)=0
virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan=0)=0
virtual freq_range_t get_tx_freq_range(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_rx_filter(const std::string &name, const size_t chan)=0
virtual void set_rx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard=0)=0
virtual double get_rx_bandwidth(size_t chan=0)=0
virtual void set_master_clock_rate(double rate, size_t mboard=ALL_MBOARDS)=0
virtual freq_range_t get_rx_freq_range(size_t chan=0)=0
virtual double get_tx_freq(size_t chan=0)=0
virtual tune_result_t set_rx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_rx_rate(size_t chan=0)=0
virtual double get_rx_power_reference(const size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_names(size_t chan=0)=0
virtual std::string get_pp_string(void)=0
virtual std::string get_tx_gain_profile(const size_t chan=0)=0
virtual double get_normalized_tx_gain(size_t chan=0)=0
T::sptr get_extension(const direction_t trx, const size_t chan)
Definition: multi_usrp.hpp:686
virtual void set_normalized_tx_gain(double gain, size_t chan=0)=0
virtual meta_range_t get_tx_dc_offset_range(size_t chan=0)=0
virtual uhd::property_tree::sptr get_tree(void) const =0
virtual void set_normalized_rx_gain(double gain, size_t chan=0)=0
virtual void set_tx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan=0)=0
virtual void set_rx_agc(bool enable, size_t chan=0)=0
virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan=0)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan=0)=0
virtual std::string get_mboard_name(size_t mboard=0)=0
virtual void set_tx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual device::sptr get_device(void)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual freq_range_t get_fe_rx_freq_range(size_t chan=0)=0
virtual void set_sync_source(const std::string &clock_source, const std::string &time_source, const size_t mboard=ALL_MBOARDS)=0
virtual uhd::extension::extension::sptr get_extension(const direction_t trx, const size_t chan)=0
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_time_synchronized(void)=0
virtual void set_tx_bandwidth(double bandwidth, size_t chan=0)=0
virtual std::string get_rx_antenna(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_tx_filter(const std::string &name, const size_t chan)=0
virtual freq_range_t get_fe_tx_freq_range(size_t chan=0)=0
virtual void set_rx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual void set_tx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual double get_rx_freq(size_t chan=0)=0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, size_t chan=0)=0
virtual size_t get_num_mboards(void)=0
virtual tune_result_t set_tx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_tx_gain(const std::string &name, size_t chan=0)=0
virtual uhd::rfnoc::mb_controller & get_mb_controller(const size_t mboard=0)=0
virtual std::vector< std::string > get_time_sources(const size_t mboard)=0
virtual double get_master_clock_rate(size_t mboard=0)=0
virtual bool has_rx_power_reference(const size_t chan=0)=0
virtual dict< std::string, std::string > get_usrp_tx_info(size_t chan=0)=0
virtual bool has_tx_power_reference(const size_t chan=0)=0
virtual void set_tx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan=0)=0
virtual void set_tx_lo_source(const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_rx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual size_t get_rx_num_channels(void)=0
virtual time_spec_t get_time_now(size_t mboard=0)=0
virtual std::vector< device_addr_t > get_sync_sources(const size_t mboard)=0
virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0
static const size_t ALL_CHANS
A wildcard channel index.
Definition: multi_usrp.hpp:106
Definition: subdev_spec.hpp:60
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
Definition: config.h:87
Definition: soft_register.hpp:86
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
Definition: build_info.hpp:12
direction_t
Definition: direction.hpp:12
Definition: sensors.hpp:29
Definition: stream.hpp:48
Definition: stream_cmd.hpp:40
Definition: tune_request.hpp:25
Definition: tune_result.hpp:19
