uhd::rfnoc::rx_event_action_info Struct Reference
#include <uhd/rfnoc/actions.hpp>
Inheritance diagram for uhd::rfnoc::rx_event_action_info:
uhd::rfnoc::action_info
using sptr = std::shared_ptr< rx_event_action_info >
- Public Types inherited from uhd::rfnoc::action_info
using sptr = std::shared_ptr< action_info >
static sptr make (uhd::rx_metadata_t::error_code_t error_code)
 Factory function. More...
- Static Public Member Functions inherited from uhd::rfnoc::action_info
static sptr make (const std::string &key="", const uhd::device_addr_t &args=uhd::device_addr_t(""))
Public Attributes
 The error code that describes the event. More...
- Public Attributes inherited from uhd::rfnoc::action_info
const size_t id
 A unique counter for this action. More...
std::string key
 A string identifier for this action. More...
std::vector< uint8_t > payload
 An arbitrary payload. It is up to consumers and producers to. More...
uhd::device_addr_t args
 A dictionary of key-value pairs. May be used as desired. More...
 rx_event_action_info (uhd::rx_metadata_t::error_code_t error_code)
- Protected Member Functions inherited from uhd::rfnoc::action_info
 action_info (const std::string &key, const uhd::device_addr_t &args=uhd::device_addr_t(""))
- Public Member Functions inherited from uhd::rfnoc::action_info
virtual ~action_info ()
◆ rx_event_action_info()
uhd::rfnoc::rx_event_action_info::rx_event_action_info ( uhd::rx_metadata_t::error_code_t  error_code)
◆ make()
static sptr uhd::rfnoc::rx_event_action_info::make ( uhd::rx_metadata_t::error_code_t  error_code)
Factory function.
◆ error_code
uhd::rx_metadata_t::error_code_t uhd::rfnoc::rx_event_action_info::error_code
