#include <uhd/config.h>
#include <uhd/error.h>
#include <uhd/types/metadata.h>
#include <uhd/types/ranges.h>
#include <uhd/types/sensors.h>
#include <uhd/types/string_vector.h>
#include <uhd/types/tune_request.h>
#include <uhd/types/tune_result.h>
#include <uhd/types/usrp_info.h>
#include <uhd/usrp/dboard_eeprom.h>
#include <uhd/usrp/mboard_eeprom.h>
#include <uhd/usrp/subdev_spec.h>
#include <uhd/version.hpp>
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
#include <time.h>
Classes | |
struct | uhd_usrp_register_info_t |
Register info. More... | |
struct | uhd_stream_args_t |
A struct of parameters to construct a stream. More... | |
struct | uhd_stream_cmd_t |
Define how device streams to host. More... | |
Typedefs | |
typedef struct uhd_rx_streamer * | uhd_rx_streamer_handle |
C-level interface for working with an RX streamer. More... | |
typedef struct uhd_tx_streamer * | uhd_tx_streamer_handle |
C-level interface for working with a TX streamer. More... | |
typedef struct uhd_usrp * | uhd_usrp_handle |
C-level interface for working with a USRP device. More... | |
Enumerations | |
enum | uhd_stream_mode_t { UHD_STREAM_MODE_START_CONTINUOUS = 97 , UHD_STREAM_MODE_STOP_CONTINUOUS = 111 , UHD_STREAM_MODE_NUM_SAMPS_AND_DONE = 100 , UHD_STREAM_MODE_NUM_SAMPS_AND_MORE = 109 } |
How streaming is issued to the device. More... | |
Functions | |
UHD_API uhd_error | uhd_rx_streamer_make (uhd_rx_streamer_handle *h) |
Create an RX streamer handle. More... | |
UHD_API uhd_error | uhd_rx_streamer_free (uhd_rx_streamer_handle *h) |
Free an RX streamer handle. More... | |
UHD_API uhd_error | uhd_rx_streamer_num_channels (uhd_rx_streamer_handle h, size_t *num_channels_out) |
Get the number of channels associated with this streamer. More... | |
UHD_API uhd_error | uhd_rx_streamer_max_num_samps (uhd_rx_streamer_handle h, size_t *max_num_samps_out) |
Get the max number of samples per buffer per packet. More... | |
UHD_API uhd_error | uhd_rx_streamer_recv (uhd_rx_streamer_handle h, void **buffs, size_t samps_per_buff, uhd_rx_metadata_handle *md, double timeout, bool one_packet, size_t *items_recvd) |
Receive buffers containing samples into the given RX streamer. More... | |
UHD_API uhd_error | uhd_rx_streamer_issue_stream_cmd (uhd_rx_streamer_handle h, const uhd_stream_cmd_t *stream_cmd) |
Issue the given stream command. More... | |
UHD_API uhd_error | uhd_rx_streamer_last_error (uhd_rx_streamer_handle h, char *error_out, size_t strbuffer_len) |
Get the last error reported by the RX streamer. More... | |
UHD_API uhd_error | uhd_tx_streamer_make (uhd_tx_streamer_handle *h) |
Create an TX streamer handle. More... | |
UHD_API uhd_error | uhd_tx_streamer_free (uhd_tx_streamer_handle *h) |
Free an TX streamer handle. More... | |
UHD_API uhd_error | uhd_tx_streamer_num_channels (uhd_tx_streamer_handle h, size_t *num_channels_out) |
UHD_API uhd_error | uhd_tx_streamer_max_num_samps (uhd_tx_streamer_handle h, size_t *max_num_samps_out) |
UHD_API uhd_error | uhd_tx_streamer_send (uhd_tx_streamer_handle h, const void **buffs, size_t samps_per_buff, uhd_tx_metadata_handle *md, double timeout, size_t *items_sent) |
Send buffers containing samples described by the metadata. More... | |
UHD_API uhd_error | uhd_tx_streamer_recv_async_msg (uhd_tx_streamer_handle h, uhd_async_metadata_handle *md, double timeout, bool *valid) |
Receive an asynchronous message from this streamer. More... | |
UHD_API uhd_error | uhd_tx_streamer_last_error (uhd_tx_streamer_handle h, char *error_out, size_t strbuffer_len) |
Get the last error reported by the TX streamer. More... | |
UHD_API uhd_error | uhd_usrp_find (const char *args, uhd_string_vector_handle *strings_out) |
Find all connected USRP devices. More... | |
UHD_API uhd_error | uhd_usrp_make (uhd_usrp_handle *h, const char *args) |
Create a USRP handle. More... | |
UHD_API uhd_error | uhd_usrp_free (uhd_usrp_handle *h) |
Safely destroy the USRP object underlying the handle. More... | |
UHD_API uhd_error | uhd_usrp_last_error (uhd_usrp_handle h, char *error_out, size_t strbuffer_len) |
Get the last error reported by the USRP handle. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_stream (uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_rx_streamer_handle h_out) |
Create RX streamer from a USRP handle and given stream args. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_stream (uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_tx_streamer_handle h_out) |
Create TX streamer from a USRP handle and given stream args. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_info (uhd_usrp_handle h, size_t chan, uhd_usrp_rx_info_t *info_out) |
Get RX info from the USRP device. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_info (uhd_usrp_handle h, size_t chan, uhd_usrp_tx_info_t *info_out) |
Get TX info from the USRP device. More... | |
UHD_API uhd_error | uhd_usrp_set_master_clock_rate (uhd_usrp_handle h, double rate, size_t mboard) |
Set the master clock rate. More... | |
UHD_API uhd_error | uhd_usrp_get_master_clock_rate (uhd_usrp_handle h, size_t mboard, double *clock_rate_out) |
Get the master clock rate. More... | |
UHD_API uhd_error | uhd_usrp_get_pp_string (uhd_usrp_handle h, char *pp_string_out, size_t strbuffer_len) |
Get a pretty-print representation of the USRP device. More... | |
UHD_API uhd_error | uhd_usrp_get_mboard_name (uhd_usrp_handle h, size_t mboard, char *mboard_name_out, size_t strbuffer_len) |
Get the motherboard name for the given device. More... | |
UHD_API uhd_error | uhd_usrp_get_time_now (uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out) |
Get the USRP device's current internal time. More... | |
UHD_API uhd_error | uhd_usrp_get_time_last_pps (uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out) |
Get the time when this device's last PPS pulse occurred. More... | |
UHD_API uhd_error | uhd_usrp_set_time_now (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard) |
Set the USRP device's time. More... | |
UHD_API uhd_error | uhd_usrp_set_time_next_pps (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard) |
Set the USRP device's time to the given value upon the next PPS detection. More... | |
UHD_API uhd_error | uhd_usrp_set_time_unknown_pps (uhd_usrp_handle h, int64_t full_secs, double frac_secs) |
Synchronize the time across all motherboards. More... | |
UHD_API uhd_error | uhd_usrp_get_time_synchronized (uhd_usrp_handle h, bool *result_out) |
Are all motherboard times synchronized? More... | |
UHD_API uhd_error | uhd_usrp_set_command_time (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard) |
Set the time at which timed commands will take place. More... | |
UHD_API uhd_error | uhd_usrp_clear_command_time (uhd_usrp_handle h, size_t mboard) |
Clear the command time so that commands are sent ASAP. More... | |
UHD_API uhd_error | uhd_usrp_set_time_source (uhd_usrp_handle h, const char *time_source, size_t mboard) |
Set the time source for the given device. More... | |
UHD_API uhd_error | uhd_usrp_get_time_source (uhd_usrp_handle h, size_t mboard, char *time_source_out, size_t strbuffer_len) |
Get the time source for the given device. More... | |
UHD_API uhd_error | uhd_usrp_get_time_sources (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *time_sources_out) |
Get a list of time sources for the given device. More... | |
UHD_API uhd_error | uhd_usrp_set_clock_source (uhd_usrp_handle h, const char *clock_source, size_t mboard) |
Set the given device's clock source. More... | |
UHD_API uhd_error | uhd_usrp_get_clock_source (uhd_usrp_handle h, size_t mboard, char *clock_source_out, size_t strbuffer_len) |
Get the given device's clock source. More... | |
UHD_API uhd_error | uhd_usrp_get_clock_sources (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *clock_sources_out) |
Get a list of clock sources for the given device. More... | |
UHD_API uhd_error | uhd_usrp_set_clock_source_out (uhd_usrp_handle h, bool enb, size_t mboard) |
Enable or disable sending the clock source to an output connector. More... | |
UHD_API uhd_error | uhd_usrp_set_time_source_out (uhd_usrp_handle h, bool enb, size_t mboard) |
Enable or disable sending the time source to an output connector. More... | |
UHD_API uhd_error | uhd_usrp_get_num_mboards (uhd_usrp_handle h, size_t *num_mboards_out) |
Get the number of devices associated with the given USRP handle. More... | |
UHD_API uhd_error | uhd_usrp_get_mboard_sensor (uhd_usrp_handle h, const char *name, size_t mboard, uhd_sensor_value_handle *sensor_value_out) |
Get the value associated with the given sensor name. More... | |
UHD_API uhd_error | uhd_usrp_get_mboard_sensor_names (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *mboard_sensor_names_out) |
Get a list of motherboard sensors for the given device. More... | |
UHD_API uhd_error | uhd_usrp_set_user_register (uhd_usrp_handle h, uint8_t addr, uint32_t data, size_t mboard) |
Perform a write on a user configuration register bus. More... | |
UHD_API uhd_error | uhd_usrp_get_mboard_eeprom (uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard) |
Get a handle for the given motherboard's EEPROM. More... | |
UHD_API uhd_error | uhd_usrp_set_mboard_eeprom (uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard) |
Set values in the given motherboard's EEPROM. More... | |
UHD_API uhd_error | uhd_usrp_get_dboard_eeprom (uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard) |
Get a handle for the given device's daughterboard EEPROM. More... | |
UHD_API uhd_error | uhd_usrp_set_dboard_eeprom (uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard) |
Set values in the given daughterboard's EEPROM. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_subdev_spec (uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard) |
Map the given device's RX frontend to a channel. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_subdev_spec (uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out) |
Get the RX frontend specification for the given device. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_num_channels (uhd_usrp_handle h, size_t *num_channels_out) |
Get the number of RX channels for the given handle. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_subdev_name (uhd_usrp_handle h, size_t chan, char *rx_subdev_name_out, size_t strbuffer_len) |
Get the name for the RX frontend. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_rate (uhd_usrp_handle h, double rate, size_t chan) |
Set the given RX channel's sample rate (in Sps) More... | |
UHD_API uhd_error | uhd_usrp_get_rx_rate (uhd_usrp_handle h, size_t chan, double *rate_out) |
Get the given RX channel's sample rate (in Sps) More... | |
UHD_API uhd_error | uhd_usrp_get_rx_rates (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out) |
Get a range of possible RX rates for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_freq (uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result) |
Set the given channel's center RX frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_freq (uhd_usrp_handle h, size_t chan, double *freq_out) |
Get the given channel's center RX frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out) |
Get all possible center frequency ranges for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_fe_rx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out) |
Get all possible RF frequency ranges for the given channel's RX RF frontend. More... | |
UHD_UNUSED (static const char *UHD_USRP_ALL_LOS) | |
A wildcard for all LO names. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_lo_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *rx_lo_names_out) |
Get a list of possible LO stage names. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_lo_source (uhd_usrp_handle h, const char *src, const char *name, size_t chan) |
Set the LO source for the USRP device. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_lo_source (uhd_usrp_handle h, const char *name, size_t chan, char *rx_lo_source_out, size_t strbuffer_len) |
Get the currently set LO source. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_lo_sources (uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *rx_lo_sources_out) |
Get a list of possible LO sources. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_lo_export_enabled (uhd_usrp_handle h, bool enabled, const char *name, size_t chan) |
Set whether the LO used by the USRP device is exported. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_lo_export_enabled (uhd_usrp_handle h, const char *name, size_t chan, bool *result_out) |
Returns true if the currently selected LO is being exported. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_lo_freq (uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out) |
Set the RX LO frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_lo_freq (uhd_usrp_handle h, const char *name, size_t chan, double *rx_lo_freq_out) |
Get the current RX LO frequency. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_gain (uhd_usrp_handle h, double gain, size_t chan, const char *gain_name) |
Set the RX gain for the given channel and name. More... | |
UHD_API uhd_error | uhd_usrp_set_normalized_rx_gain (uhd_usrp_handle h, double gain, size_t chan) |
Set the normalized RX gain [0.0, 1.0] for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_agc (uhd_usrp_handle h, bool enable, size_t chan) |
Enable or disable the given channel's RX AGC module. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_gain (uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out) |
Get the given channel's RX gain. More... | |
UHD_API uhd_error | uhd_usrp_get_normalized_rx_gain (uhd_usrp_handle h, size_t chan, double *gain_out) |
Get the given channel's normalized RX gain [0.0, 1.0]. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_gain_range (uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out) |
Get all possible gain ranges for the given channel and name. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_gain_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out) |
Get a list of RX gain names for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_antenna (uhd_usrp_handle h, const char *ant, size_t chan) |
Set the RX antenna for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_antenna (uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len) |
Get the RX antenna for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_antennas (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out) |
Get a list of RX antennas associated with the given channels. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_sensor_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out) |
Get a list of RX sensors associated with the given channels. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_bandwidth (uhd_usrp_handle h, double bandwidth, size_t chan) |
Set the bandwidth for the given channel's RX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_bandwidth (uhd_usrp_handle h, size_t chan, double *bandwidth_out) |
Get the bandwidth for the given channel's RX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_bandwidth_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out) |
Get all possible bandwidth ranges for the given channel's RX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_rx_sensor (uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out) |
Get the value for the given RX sensor. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_dc_offset_enabled (uhd_usrp_handle h, bool enb, size_t chan) |
Enable or disable RX DC offset correction for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_rx_iq_balance_enabled (uhd_usrp_handle h, bool enb, size_t chan) |
Enable or disable RX IQ imbalance correction for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_tx_subdev_spec (uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard) |
Map the given device's TX frontend to a channel. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_subdev_spec (uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out) |
Get the TX frontend specification for the given device. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_num_channels (uhd_usrp_handle h, size_t *num_channels_out) |
Get the number of TX channels for the given handle. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_subdev_name (uhd_usrp_handle h, size_t chan, char *tx_subdev_name_out, size_t strbuffer_len) |
UHD_API uhd_error | uhd_usrp_set_tx_rate (uhd_usrp_handle h, double rate, size_t chan) |
UHD_API uhd_error | uhd_usrp_get_tx_rate (uhd_usrp_handle h, size_t chan, double *rate_out) |
UHD_API uhd_error | uhd_usrp_get_tx_rates (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out) |
UHD_API uhd_error | uhd_usrp_set_tx_freq (uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result) |
Set the given channel's center TX frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_freq (uhd_usrp_handle h, size_t chan, double *freq_out) |
Get the given channel's center TX frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out) |
UHD_API uhd_error | uhd_usrp_get_fe_tx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out) |
Get all possible RF frequency ranges for the given channel's TX RF frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_lo_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *tx_lo_names_out) |
UHD_API uhd_error | uhd_usrp_set_tx_lo_source (uhd_usrp_handle h, const char *src, const char *name, size_t chan) |
UHD_API uhd_error | uhd_usrp_get_tx_lo_source (uhd_usrp_handle h, const char *name, size_t chan, char *tx_lo_source_out, size_t strbuffer_len) |
UHD_API uhd_error | uhd_usrp_get_tx_lo_sources (uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *tx_lo_sources_out) |
UHD_API uhd_error | uhd_usrp_set_tx_lo_export_enabled (uhd_usrp_handle h, bool enabled, const char *name, size_t chan) |
UHD_API uhd_error | uhd_usrp_get_tx_lo_export_enabled (uhd_usrp_handle h, const char *name, size_t chan, bool *result_out) |
UHD_API uhd_error | uhd_usrp_set_tx_lo_freq (uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out) |
Set the Tx LO frequency. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_lo_freq (uhd_usrp_handle h, const char *name, size_t chan, double *tx_lo_freq_out) |
Get the current Tx LO frequency. More... | |
UHD_API uhd_error | uhd_usrp_set_tx_gain (uhd_usrp_handle h, double gain, size_t chan, const char *gain_name) |
Set the TX gain for the given channel and name. More... | |
UHD_API uhd_error | uhd_usrp_set_normalized_tx_gain (uhd_usrp_handle h, double gain, size_t chan) |
Set the normalized TX gain [0.0, 1.0] for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_gain_range (uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out) |
UHD_API uhd_error | uhd_usrp_get_tx_gain (uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out) |
UHD_API uhd_error | uhd_usrp_get_normalized_tx_gain (uhd_usrp_handle h, size_t chan, double *gain_out) |
Get the given channel's normalized TX gain [0.0, 1.0]. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_gain_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out) |
Get a list of TX gain names for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_set_tx_antenna (uhd_usrp_handle h, const char *ant, size_t chan) |
Set the TX antenna for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_antenna (uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len) |
Get the TX antenna for the given channel. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_antennas (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out) |
Get a list of tx antennas associated with the given channels. More... | |
UHD_API uhd_error | uhd_usrp_set_tx_bandwidth (uhd_usrp_handle h, double bandwidth, size_t chan) |
Set the bandwidth for the given channel's TX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_bandwidth (uhd_usrp_handle h, size_t chan, double *bandwidth_out) |
Get the bandwidth for the given channel's TX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_bandwidth_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out) |
Get all possible bandwidth ranges for the given channel's TX frontend. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_sensor (uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out) |
Get the value for the given TX sensor. More... | |
UHD_API uhd_error | uhd_usrp_get_tx_sensor_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out) |
Get a list of TX sensors associated with the given channels. More... | |
UHD_API uhd_error | uhd_usrp_get_gpio_banks (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *gpio_banks_out) |
Get a list of GPIO banks associated with the given channels. More... | |
UHD_API uhd_error | uhd_usrp_set_gpio_attr (uhd_usrp_handle h, const char *bank, const char *attr, uint32_t value, uint32_t mask, size_t mboard) |
Set a GPIO attribute for a given GPIO bank. More... | |
UHD_API uhd_error | uhd_usrp_get_gpio_attr (uhd_usrp_handle h, const char *bank, const char *attr, size_t mboard, uint32_t *attr_out) |
Get a GPIO attribute on a particular GPIO bank. More... | |
typedef struct uhd_rx_streamer* uhd_rx_streamer_handle |
See uhd::rx_streamer for more details.
typedef struct uhd_tx_streamer* uhd_tx_streamer_handle |
See uhd::tx_streamer for more details.
typedef struct uhd_usrp* uhd_usrp_handle |
enum uhd_stream_mode_t |
See uhd::stream_cmd_t for more details.
UHD_API uhd_error uhd_rx_streamer_free | ( | uhd_rx_streamer_handle * | h | ) |
NOTE: Using a streamer after passing it into this function will result in a segmentation fault.
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd | ( | uhd_rx_streamer_handle | h, |
const uhd_stream_cmd_t * | stream_cmd | ||
See uhd::rx_streamer::issue_stream_cmd() for more details.
UHD_API uhd_error uhd_rx_streamer_last_error | ( | uhd_rx_streamer_handle | h, |
char * | error_out, | ||
size_t | strbuffer_len | ||
NOTE: This will overwrite the string currently in error_out before using it to return its error.
h | RX streamer handle |
error_out | string buffer in which to place error |
strbuffer_len | buffer size |
UHD_API uhd_error uhd_rx_streamer_make | ( | uhd_rx_streamer_handle * | h | ) |
NOTE: Using this streamer before passing it into uhd_usrp_get_rx_stream() will result in undefined behavior.
UHD_API uhd_error uhd_rx_streamer_max_num_samps | ( | uhd_rx_streamer_handle | h, |
size_t * | max_num_samps_out | ||
UHD_API uhd_error uhd_rx_streamer_num_channels | ( | uhd_rx_streamer_handle | h, |
size_t * | num_channels_out | ||
UHD_API uhd_error uhd_rx_streamer_recv | ( | uhd_rx_streamer_handle | h, |
void ** | buffs, | ||
size_t | samps_per_buff, | ||
uhd_rx_metadata_handle * | md, | ||
double | timeout, | ||
bool | one_packet, | ||
size_t * | items_recvd | ||
See uhd::rx_streamer::recv() for more details.
buffs | pointer to buffers in which to receive samples |
samps_per_buff | max number of samples per buffer |
md | handle to RX metadata in which to receive results |
timeout | timeout in seconds to wait for a packet |
one_packet | send a single packet |
items_recvd | pointer to output variable for number of samples received |
UHD_API uhd_error uhd_tx_streamer_free | ( | uhd_tx_streamer_handle * | h | ) |
UHD_API uhd_error uhd_tx_streamer_last_error | ( | uhd_tx_streamer_handle | h, |
h | TX streamer handle |
UHD_API uhd_error uhd_tx_streamer_make | ( | uhd_tx_streamer_handle * | h | ) |
NOTE: Using this streamer before passing it into uhd_usrp_get_tx_stream() will result in undefined behavior.
UHD_API uhd_error uhd_tx_streamer_max_num_samps | ( | uhd_tx_streamer_handle | h, |
UHD_API uhd_error uhd_tx_streamer_num_channels | ( | uhd_tx_streamer_handle | h, |
UHD_API uhd_error uhd_tx_streamer_recv_async_msg | ( | uhd_tx_streamer_handle | h, |
uhd_async_metadata_handle * | md, | ||
bool * | valid | ||
See uhd::tx_streamer::recv_async_msg() for more details.
UHD_API uhd_error uhd_tx_streamer_send | ( | uhd_tx_streamer_handle | h, |
const void ** | buffs, | ||
uhd_tx_metadata_handle * | md, | ||
size_t * | items_sent | ||
See uhd::tx_streamer::send() for more details.
buffs | pointer to buffers containing samples to send |
md | handle to TX metadata |
items_sent | pointer to output variable for number of samples send |
UHD_UNUSED | ( | static const char * | UHD_USRP_ALL_LOS | ) |
UHD_API uhd_error uhd_usrp_clear_command_time | ( | uhd_usrp_handle | h, |
size_t | mboard | ||
UHD_API uhd_error uhd_usrp_find | ( | const char * | args, |
uhd_string_vector_handle * | strings_out | ||
See uhd::device::find() for more details.
UHD_API uhd_error uhd_usrp_free | ( | uhd_usrp_handle * | h | ) |
NOTE: Attempting to use a USRP handle after passing it into this function will result in a segmentation fault.
UHD_API uhd_error uhd_usrp_get_clock_source | ( | uhd_usrp_handle | h, |
size_t | mboard, | ||
char * | clock_source_out, | ||
See uhd::usrp::multi_usrp::get_clock_source() for more details.
UHD_API uhd_error uhd_usrp_get_clock_sources | ( | uhd_usrp_handle | h, |
uhd_string_vector_handle * | clock_sources_out | ||
UHD_API uhd_error uhd_usrp_get_dboard_eeprom | ( | uhd_usrp_handle | h, |
uhd_dboard_eeprom_handle | db_eeprom, | ||
const char * | unit, | ||
const char * | slot, | ||
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_meta_range_handle | freq_range_out | ||
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_gpio_attr | ( | uhd_usrp_handle | h, |
const char * | bank, | ||
const char * | attr, | ||
uint32_t * | attr_out | ||
See uhd::usrp::multi_usrp::get_gpio_attr() for more details.
UHD_API uhd_error uhd_usrp_get_gpio_banks | ( | uhd_usrp_handle | h, |
uhd_string_vector_handle * | gpio_banks_out | ||
UHD_API uhd_error uhd_usrp_get_master_clock_rate | ( | uhd_usrp_handle | h, |
double * | clock_rate_out | ||
See uhd::usrp::multi_usrp::get_master_clock_rate() for more details.
UHD_API uhd_error uhd_usrp_get_mboard_eeprom | ( | uhd_usrp_handle | h, |
uhd_mboard_eeprom_handle | mb_eeprom, | ||
UHD_API uhd_error uhd_usrp_get_mboard_name | ( | uhd_usrp_handle | h, |
char * | mboard_name_out, | ||
See uhd::usrp::multi_usrp::get_mboard_name() for more details.
UHD_API uhd_error uhd_usrp_get_mboard_sensor | ( | uhd_usrp_handle | h, |
const char * | name, | ||
uhd_sensor_value_handle * | sensor_value_out | ||
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names | ( | uhd_usrp_handle | h, |
uhd_string_vector_handle * | mboard_sensor_names_out | ||
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | gain_out | ||
See uhd::usrp::multi_usrp::get_normalized_rx_gain() for more details.
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
See uhd::usrp::multi_usrp::get_normalized_tx_gain() for more details.
UHD_API uhd_error uhd_usrp_get_num_mboards | ( | uhd_usrp_handle | h, |
size_t * | num_mboards_out | ||
UHD_API uhd_error uhd_usrp_get_pp_string | ( | uhd_usrp_handle | h, |
char * | pp_string_out, | ||
See uhd::usrp::multi_usrp::get_pp_string() for more details.
UHD_API uhd_error uhd_usrp_get_rx_antenna | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
char * | ant_out, | ||
UHD_API uhd_error uhd_usrp_get_rx_antennas | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | antennas_out | ||
UHD_API uhd_error uhd_usrp_get_rx_bandwidth | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | bandwidth_out | ||
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_meta_range_handle | bandwidth_range_out | ||
UHD_API uhd_error uhd_usrp_get_rx_freq | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | freq_out | ||
UHD_API uhd_error uhd_usrp_get_rx_freq_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
See uhd::usrp::multi_usrp::get_rx_freq_range() for more details.
UHD_API uhd_error uhd_usrp_get_rx_gain | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
const char * | gain_name, | ||
UHD_API uhd_error uhd_usrp_get_rx_gain_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | gain_names_out | ||
UHD_API uhd_error uhd_usrp_get_rx_gain_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_meta_range_handle | gain_range_out | ||
UHD_API uhd_error uhd_usrp_get_rx_info | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_usrp_rx_info_t * | info_out | ||
NOTE: After calling this function, uhd_usrp_rx_info_free() must be called on info_out.
UHD_API uhd_error uhd_usrp_get_rx_lo_export_enabled | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
bool * | result_out | ||
UHD_API uhd_error uhd_usrp_get_rx_lo_freq | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | rx_lo_freq_out | ||
UHD_API uhd_error uhd_usrp_get_rx_lo_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | rx_lo_names_out | ||
UHD_API uhd_error uhd_usrp_get_rx_lo_source | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
char * | rx_lo_source_out, | ||
UHD_API uhd_error uhd_usrp_get_rx_lo_sources | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | rx_lo_sources_out | ||
UHD_API uhd_error uhd_usrp_get_rx_num_channels | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_get_rx_rate | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | rate_out | ||
UHD_API uhd_error uhd_usrp_get_rx_rates | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_meta_range_handle | rates_out | ||
UHD_API uhd_error uhd_usrp_get_rx_sensor | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_rx_sensor_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | sensor_names_out | ||
UHD_API uhd_error uhd_usrp_get_rx_stream | ( | uhd_usrp_handle | h, |
uhd_stream_args_t * | stream_args, | ||
uhd_rx_streamer_handle | h_out | ||
UHD_API uhd_error uhd_usrp_get_rx_subdev_name | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
char * | rx_subdev_name_out, | ||
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec | ( | uhd_usrp_handle | h, |
uhd_subdev_spec_handle | subdev_spec_out | ||
UHD_API uhd_error uhd_usrp_get_time_last_pps | ( | uhd_usrp_handle | h, |
int64_t * | full_secs_out, | ||
double * | frac_secs_out | ||
See uhd::usrp::multi_usrp::get_time_last_pps() for more details.
UHD_API uhd_error uhd_usrp_get_time_now | ( | uhd_usrp_handle | h, |
See uhd::usrp::multi_usrp::get_time_now() for more details.
UHD_API uhd_error uhd_usrp_get_time_source | ( | uhd_usrp_handle | h, |
char * | time_source_out, | ||
See uhd::usrp::multi_usrp::get_time_source() for more details.
UHD_API uhd_error uhd_usrp_get_time_sources | ( | uhd_usrp_handle | h, |
uhd_string_vector_handle * | time_sources_out | ||
UHD_API uhd_error uhd_usrp_get_time_synchronized | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_get_tx_antenna | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_antennas | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_bandwidth | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_freq | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_freq_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_gain | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_gain_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_gain_range | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_info | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_usrp_tx_info_t * | info_out | ||
NOTE: After calling this function, uhd_usrp_tx_info_free() must be called on info_out.
UHD_API uhd_error uhd_usrp_get_tx_lo_export_enabled | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_lo_freq | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
double * | tx_lo_freq_out | ||
UHD_API uhd_error uhd_usrp_get_tx_lo_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | tx_lo_names_out | ||
UHD_API uhd_error uhd_usrp_get_tx_lo_source | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
char * | tx_lo_source_out, | ||
UHD_API uhd_error uhd_usrp_get_tx_lo_sources | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
uhd_string_vector_handle * | tx_lo_sources_out | ||
UHD_API uhd_error uhd_usrp_get_tx_num_channels | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_get_tx_rate | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_rates | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_sensor | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_sensor_names | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_get_tx_stream | ( | uhd_usrp_handle | h, |
uhd_tx_streamer_handle | h_out | ||
UHD_API uhd_error uhd_usrp_get_tx_subdev_name | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
char * | tx_subdev_name_out, | ||
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_last_error | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_make | ( | uhd_usrp_handle * | h, |
const char * | args | ||
h | the handle |
args | device args (e.g. "type=x300") |
UHD_API uhd_error uhd_usrp_set_clock_source | ( | uhd_usrp_handle | h, |
const char * | clock_source, | ||
See uhd::usrp::multi_usrp::set_clock_source() for more details.
UHD_API uhd_error uhd_usrp_set_clock_source_out | ( | uhd_usrp_handle | h, |
bool | enb, | ||
See uhd::usrp::set_clock_source_out() for more details.
UHD_API uhd_error uhd_usrp_set_command_time | ( | uhd_usrp_handle | h, |
int64_t | full_secs, | ||
double | frac_secs, | ||
See uhd::usrp::multi_usrp::set_command_time() for more details.
UHD_API uhd_error uhd_usrp_set_dboard_eeprom | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_set_gpio_attr | ( | uhd_usrp_handle | h, |
uint32_t | value, | ||
uint32_t | mask, | ||
See uhd::usrp::multi_usrp::set_gpio_attr() for more details.
UHD_API uhd_error uhd_usrp_set_master_clock_rate | ( | uhd_usrp_handle | h, |
double | rate, | ||
See uhd::usrp::multi_usrp::set_master_clock_rate() for more details.
UHD_API uhd_error uhd_usrp_set_mboard_eeprom | ( | uhd_usrp_handle | h, |
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain | ( | uhd_usrp_handle | h, |
double | gain, | ||
size_t | chan | ||
See uhd::usrp::multi_usrp::set_normalized_rx_gain() for more details.
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain | ( | uhd_usrp_handle | h, |
double | gain, | ||
size_t | chan | ||
See uhd::usrp::multi_usrp::set_normalized_tx_gain() for more details.
UHD_API uhd_error uhd_usrp_set_rx_agc | ( | uhd_usrp_handle | h, |
bool | enable, | ||
size_t | chan | ||
See uhd::usrp::multi_usrp::set_rx_agc() for more details.
UHD_API uhd_error uhd_usrp_set_rx_antenna | ( | uhd_usrp_handle | h, |
const char * | ant, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_bandwidth | ( | uhd_usrp_handle | h, |
double | bandwidth, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled | ( | uhd_usrp_handle | h, |
bool | enb, | ||
size_t | chan | ||
See uhd::usrp::multi_usrp::set_rx_dc_offset() for more details.
UHD_API uhd_error uhd_usrp_set_rx_freq | ( | uhd_usrp_handle | h, |
uhd_tune_request_t * | tune_request, | ||
size_t | chan, | ||
uhd_tune_result_t * | tune_result | ||
UHD_API uhd_error uhd_usrp_set_rx_gain | ( | uhd_usrp_handle | h, |
double | gain, | ||
size_t | chan, | ||
const char * | gain_name | ||
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled | ( | uhd_usrp_handle | h, |
bool | enb, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_lo_export_enabled | ( | uhd_usrp_handle | h, |
bool | enabled, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_lo_freq | ( | uhd_usrp_handle | h, |
double | freq, | ||
size_t | chan, | ||
double * | coerced_freq_out | ||
UHD_API uhd_error uhd_usrp_set_rx_lo_source | ( | uhd_usrp_handle | h, |
const char * | src, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_rate | ( | uhd_usrp_handle | h, |
double | rate, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec | ( | uhd_usrp_handle | h, |
uhd_subdev_spec_handle | subdev_spec, | ||
See uhd::usrp::multi_usrp::set_rx_subdev_spec() for more details.
UHD_API uhd_error uhd_usrp_set_time_next_pps | ( | uhd_usrp_handle | h, |
See uhd::usrp::multi_usrp::set_time_next_pps() for more details.
UHD_API uhd_error uhd_usrp_set_time_now | ( | uhd_usrp_handle | h, |
See uhd::usrp::multi_usrp::set_time_now() for more details.
UHD_API uhd_error uhd_usrp_set_time_source | ( | uhd_usrp_handle | h, |
const char * | time_source, | ||
See uhd::usrp::multi_usrp::set_time_source() for more details.
UHD_API uhd_error uhd_usrp_set_time_source_out | ( | uhd_usrp_handle | h, |
bool | enb, | ||
See uhd::usrp::set_time_source_out() for more details.
UHD_API uhd_error uhd_usrp_set_time_unknown_pps | ( | uhd_usrp_handle | h, |
double | frac_secs | ||
See uhd::usrp::multi_usrp::set_time_unknown_pps() for more details.
UHD_API uhd_error uhd_usrp_set_tx_antenna | ( | uhd_usrp_handle | h, |
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_tx_bandwidth | ( | uhd_usrp_handle | h, |
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_tx_freq | ( | uhd_usrp_handle | h, |
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_set_tx_gain | ( | uhd_usrp_handle | h, |
double | gain, | ||
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_set_tx_lo_export_enabled | ( | uhd_usrp_handle | h, |
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_tx_lo_freq | ( | uhd_usrp_handle | h, |
double | freq, | ||
size_t | chan, | ||
UHD_API uhd_error uhd_usrp_set_tx_lo_source | ( | uhd_usrp_handle | h, |
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_tx_rate | ( | uhd_usrp_handle | h, |
double | rate, | ||
size_t | chan | ||
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec | ( | uhd_usrp_handle | h, |
See uhd::usrp::multi_usrp::set_tx_subdev_spec() for more details.
UHD_API uhd_error uhd_usrp_set_user_register | ( | uhd_usrp_handle | h, |
uint8_t | addr, | ||
uint32_t | data, | ||
See uhd::usrp::multi_usrp::set_user_register() for more details.
