Special class which may access nodes. More...
#include <uhd/rfnoc/node_accessor.hpp>
Public Types | |
| using | prop_ptrs_t = node_t::prop_ptrs_t |
| void | init_props (node_t *node) |
| void | resolve_props (node_t *node) |
| template<typename PredicateType > | |
| node_t::prop_ptrs_t | filter_props (node_t *node, PredicateType &&predicate) |
| void | clean_props (node_t *node) |
| void | set_resolve_all_callback (node_t *node, node_t::resolve_callback_t &&resolver) |
| void | clear_resolve_all_callback (node_t *node) |
| void | set_graph_mutex_callback (node_t *node, node_t::graph_mutex_callback_t &&mutex) |
| void | clear_graph_mutex_callback (node_t *node) |
| void | forward_edge_property (node_t *dst_node, const size_t dst_port, property_base_t *incoming_prop) |
| void | set_post_action_callback (node_t *node, node_t::action_handler_t &&post_handler) |
| void | send_action (node_t *node, const res_source_info &port_info, action_info::sptr action) |
| void | post_action (node_t *node, const res_source_info &edge_info, action_info::sptr action) |
| bool | check_topology (node_t *node, const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
| void | shutdown (node_t *node) |
inline |
Check topology for this block
See node_t::check_topology() for details
inline |
Mark all properties on this node as clean
See node_t::clean_props() for details.
inline |
Clears the graph mutex callback. Called when node is disconnected from the graph.
See node_t::clear_graph_mutex_callback() for details.
inline |
inline |
Returns a filtered list of properties.
The return list contains all properties that match a given predicate.
inline |
Forward an edge property to dst_node
See node_t::forward_edge_property() for details.
inline |
Initializes the properties of a node. See node_t::init_props() for details.
inline |
Fake a post_action() call from this node
This will call node_t::post_action() (see that for details).
inline |
Does a local resolution of properties on node.
See node_t::resolve_props for details.
inline |
Send an action to node
This will call node_t::receive_action() (see that for details).
inline |
Sets a callback that the node can call to the mutex to the graph it is connected to. Used for setting properties and propagation.
See node_t::set_graph_mutex_callback() for details.
inline |
Set post action callback for the node
See node_t::set_post_action_callback() for details.
inline |
Set a resolver callback for the node
See node_t::set_resolve_all_callback() for details.
inline |
Put a node into shutdown
See node_t::shutdown(), and also noc_block_base::shutdown() for details.
