#include <uhd/rfnoc/mock_nodes.hpp>
| enum | forwarding_policy_t {
forwarding_policy_t::ONE_TO_ONE,
forwarding_policy_t::ONE_TO_FAN,
forwarding_policy_t::ONE_TO_ALL_IN,
forwarding_policy_t::ONE_TO_ALL_OUT,
forwarding_policy_t::ONE_TO_ALL,
forwarding_policy_t::DROP,
forwarding_policy_t::USE_MAP
| | Types of property/action forwarding for those not defined by the block itself. More...
| template<typename prop_data_t > |
| | A dirtifyer object, useful for properties that always need updating. More...
Mock DDC node
- Single channel
- Does simple coercion of decimation
- Keeps output and input rates consistent with decimation
◆ mock_ddc_node_t()
| uhd::rfnoc::test::mock_ddc_node_t::mock_ddc_node_t |
inline |
◆ coerce_decim()
| static int uhd::rfnoc::test::mock_ddc_node_t::coerce_decim |
const int |
requested_decim | ) |
inlinestatic |
◆ get_num_input_ports()
| size_t uhd::rfnoc::test::mock_ddc_node_t::get_num_input_ports |
const |
inlineoverridevirtual |
Return the number of input ports for this block.
This function needs to be overridden.
- Returns
- noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
| size_t uhd::rfnoc::test::mock_ddc_node_t::get_num_output_ports |
const |
Return the number of output ports for this block.
- Returns
◆ get_unique_id()
| std::string uhd::rfnoc::test::mock_ddc_node_t::get_unique_id |
const |
Return a unique identifier string for this node. In every RFNoC graph,.
Reimplemented from uhd::rfnoc::node_t.
◆ _decim
◆ _samp_rate_in
| property_t<double> uhd::rfnoc::test::mock_ddc_node_t::_samp_rate_in |
◆ _samp_rate_out
| property_t<double> uhd::rfnoc::test::mock_ddc_node_t::_samp_rate_out |
