| | mock_edge_node_t (size_t input_ports, size_t output_ports, const std::string &name="MOCK_EDGE_NODE") |
| template<typename T > |
| void | set_edge_property (const std::string &id, const T &val, const res_source_info &rsi) |
| T | get_edge_property (const std::string &id, const res_source_info &rsi) |
| | Return a unique identifier string for this node. In every RFNoC graph,. More...
| void | post_input_edge_action (action_info::sptr action, size_t port) |
| void | post_output_edge_action (action_info::sptr action, size_t port) |
| const received_actions_map_t & | get_received_actions_map () const |
| void | clear_received_actions_map () |
| | node_t () |
| template<typename prop_data_t > |
| | A dirtifyer object, useful for properties that always need updating. More...
Mock node with configurable number of input and output ports that have an edge property associated with each. The node can source actions with key 'action' from any of its edges. Incoming actions with key 'action' are stored in a (source port --> list of incoming actions) map.
