#include <uhd/rfnoc/mock_nodes.hpp>
| enum | forwarding_policy_t {
forwarding_policy_t::ONE_TO_ONE,
forwarding_policy_t::ONE_TO_FAN,
forwarding_policy_t::ONE_TO_ALL_IN,
forwarding_policy_t::ONE_TO_ALL_OUT,
forwarding_policy_t::ONE_TO_ALL,
forwarding_policy_t::DROP,
forwarding_policy_t::USE_MAP
| | Types of property/action forwarding for those not defined by the block itself. More...
| template<typename prop_data_t > |
| | A dirtifyer object, useful for properties that always need updating. More...
Mock Radio node
- "Full Duplex"
- Has two master clock rates: 100e6 and 200e6
- RSSI is a read-only prop that always needs updating
◆ mock_radio_node_t()
| uhd::rfnoc::test::mock_radio_node_t::mock_radio_node_t |
const size_t |
radio_idx | ) |
inline |
◆ generate_overrun()
| void uhd::rfnoc::test::mock_radio_node_t::generate_overrun |
const size_t |
chan | ) |
inline |
◆ generate_underrun()
| void uhd::rfnoc::test::mock_radio_node_t::generate_underrun |
const size_t |
chan, |
uhd::time_spec_t |
time_spec |
inline |
◆ get_num_input_ports()
| size_t uhd::rfnoc::test::mock_radio_node_t::get_num_input_ports |
const |
inlineoverridevirtual |
Return the number of input ports for this block.
This function needs to be overridden.
- Returns
- noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
| size_t uhd::rfnoc::test::mock_radio_node_t::get_num_output_ports |
const |
Return the number of output ports for this block.
- Returns
◆ get_unique_id()
| std::string uhd::rfnoc::test::mock_radio_node_t::get_unique_id |
const |
Return a unique identifier string for this node. In every RFNoC graph,.
Reimplemented from uhd::rfnoc::node_t.
◆ update_fwd_policy()
◆ disable_samp_out_resolver
| bool uhd::rfnoc::test::mock_radio_node_t::disable_samp_out_resolver = false |
◆ force_samp_out_value
| double uhd::rfnoc::test::mock_radio_node_t::force_samp_out_value = 23e6 |
◆ last_num_samps
| size_t uhd::rfnoc::test::mock_radio_node_t::last_num_samps = 0 |
◆ rssi_resolver_count
| size_t uhd::rfnoc::test::mock_radio_node_t::rssi_resolver_count = 0 |
